Question about Bunn Tea & Coffee Maker Infusion Series ITCB-DV 29
Water not dispensing with ITCB-DV series Bunn Tea Brewer
I was told by a local authorized service center in Orlando Florida that it would cost $100 service call, $90hr (min) plus parts to fix the problem. I have 2 units with the exact same problem. I use reverse osmosis water not tap water. If I add up the total cost fix the problem. Its more cost effective to buy a new unit. Any suggestions???
Problem: water does not dispense out of hot water tap. Water doesn't spray from dispensor value. The dispensing spray head is cleaned daily.
  • Bunn Master
  • 2,237 Answers
The tank is not full. the sensor at the top is being bridged and it thinks it's full. pop it out and clean it and delime the tank.
Posted on Aug 25, 2010
I have a bunn CW series brewer. I filled the reserve with water and allowed to get hot. I then add additional water (1 glass pot) and it just starts to dispense without me hitting the "start" button. I...
Sounds like the switch is stuck in the operate position. Therefor once the machine hits temperature it just brews. Your local Bunn distributor should be able to recommend an engineer to replace the switch or supply the correct t,hope of switch if your confident enought Tom replace it yourself.
May 11, 2014 | Bunn CW 15-APS Coffee Maker
The brewer is on a gravity feed system, after the initial fill, whatever you put in is what comes out. as for the start button check the water connection on the back, there might be a problem with the solenoid.
HAVE A TB3Q TEA BREWER - hooked up water line turned on - will not fill tank. Is there a special trick
If it is brand new you will need to make sure the thermostat is turned off and the unit is cold, it is located under the top cover. You will need to put the tea container in place, put the on off switch in the on position and push the start switch. This will need to be done 3 times total to fill the tank. Halfway threw the third cycle it should start to dispense from the spray head. You can now turn the thermostat all the way up.
Oct 09, 2013 | Bunn TB3Q, 29" Trunk, 3 Gallon Tea Brewer
Bunn coffee maker ITCB-DV not pouring enough water
The pulse program does not result in lower volume. The control board adds time to account for the pulses. If you are encountering less water than before clean your spray head and spray head fitting. 75% of low volume service calls are from calcified spray heads.
Mar 29, 2013 | Bunn Infusion ITCB DV Coffee Maker
Bunn automatic coffeemaker leaks water after making a pot
Tank and tank components should be delimed regularly
depending on local water conditions. Excessive mineral build-up
on stainless steel surfaces can initiate corrosive reactions resulting in serious leaks.
Feb 02, 2013 | Bunnomatic Corp. 10c Professional Brewer...
Water will not stop running when i turn on
Free tech support for Bunn Tea & Coffee Maker Infusion Series ITCB-DV 29
Feb 24, 2011 | Bunn Infusion ITCB DV Coffee Maker
When we make a pot of coffee, the water goes through to quickly and the coffee looks like weak tea, how can we fix this, we only got the coffee maker about a month ago
This is usually caused by a missing sprayhead above your filter basket. take out the filter basket, and see if there is a sprayhead up there, or if there is just a little round pipe that the prayhead screws on to. If it is missing, you can contact your local Bunn dealer, or phone bunn directly, and they will take care of you. You can get a list of repair centers in your area at www.bunn.com
Nov 20, 2009 | Bunn 10 Cup Home Coffee Brewer
Bunn pod coffee tea brewer
Visit the Bunn website on the following link: http://bunn.com/retail/service/faq.html You can download manuals, read the FAQ & get telephone support from them. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 25, 2007 | Bunn BREWER POD COFFEETEA
Coffee Makers & Espresso Machines Logo
264 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
