Question about Dell Latitude X200 Notebook
Won't boot off of the external drive
How can I get to boot of the external drive?
  • Mike Waldron May 11, 2010
    Change the boot device order in the System Bios.
    Mike @ compurepair.
  • 191 Answers
When u power on your system start tapping F2 key
you wil get system setup screen
it will be somthing like this
Boot Sequence The computer attempts to boot from the sequence of devices specified in this list.
Default Setting:
  • Onboard or USB floppy drive
  • Onboard SATA hard disk drive
  • Onboard IDE hard disk drive
  • Any add-in hard disk drives that are detected (listed in the order that they are detected with USB device usually being detected last)
  • Onboard or USB CD-ROM drive
  • Any other bootable add-in devices that are detected (listed in the order that they are detected with Onboard Network Controller usually being detected first)
Posted on Jun 05, 2008
  • Rahil Kamra
    Rahil Kamra Jun 05, 2008
    fourth option from top is i believe you have to change
Siig sc-sat212-s4, stops boot when connected
While most computers are capable of starting up properly with external drives connected, from time to time the external drive can cause confusion during the startup process. The computer may attempt to boot from the external hard drive rather than the primary internal drive. This causes the computer to fail during startup because the external hard drive does not have the operating system installed on it.
Disconnect the external hard drive from the computer. In order to minimize the risk of damage to or loss of files on the external drive, shut down the computer if possible, or hold down the power button on the computer until the computer turns off and then disconnect the external hard drive. Restart the computer with the drive disconnected. If the computer still does not start up, it is possible that the computer is attempting to boot from the external drive. Reconnect the external drive and restart the computer. Watch the screen as the computer boots up. A prompt will appear indicating which key to press to enter "Setup" or the "BIOS." Press this key when the prompt appears. On many computers the key is either Delete ,F2 or F10. Use the keyboard of the computer to navigate the "Setup menu" that appears. (Advanced Bios Features.) The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ? or using the arrow keys you can load failsafe or optimized defaults this will set the boot order. Highlight the option for "Boot Disk" or "Startup disk" and select the "C:/" or the primary internal hard drive. Press the associated key, labeled so on the bottom of the screen, to save the changes and restart the computer. This will allow the computer to boot from the appropriate drive. Hope it helps.
b>
Jan 23, 2013 | SIIG Scsat212s4 Pci Serial Ata 2 Channel...
External hard drive won't boot up.
As virtualhost said, maybe you have not initialize this disk and partition it. Additional to disk mgmt, you could use this software
Sep 11, 2012 | Buffalo Technology (USA), INC. - 500GB...
How to fix a toshiba a105-s4001 when it won't boot up from hard drive or dvd drive
You can install Win7 from an USB drive.
follow this link to find more about it and for step by step instructions.
http://forums.mydigitallife.info/threads/7850-Installing-Windows-7-From-USB-Drive-3-Steps-Easy-Process
Another option is to go for external optical drive.
Good luck...
Feb 06, 2012 | Toshiba Computers & Internet
External hard drive won't show files
If it behaves like this for multiple computers with multiple operating systems, I would think that the problem is with the hard drive or with how the files were stored. I would recommend trying a free recovery utility:
http://www.piriform.com/recuva
If this does not work, there are professionals who can do this service for you however it is generally expensive.
As a last ditch effort, boot your computer from a free Ubuntu CD (http://www.ubuntu.com/download/ubuntu/download) and see if it recognizes your files.
Dec 13, 2011 | Buffalo Technology Buffalo DriveStation...
Can i format my HD on an external bases with my laptop, then install it back into my pc. my hard drive crashed and i need to get it to boot. i dont have the boot disk
Technically, YES, the hard drive can be formatted as an external (with the appropriate equipment) on your laptop (if there are still files on it, you may even be able to extract them from it) but it still won't be bootable because it does not have an operating system on it.
That would be the part where you need the recovery disc. Windows setup programs from these boot discs already have the format utility so if there aren't any files to extract from the drive, you can skip to reinstalling Windows on the desktop and formatting it in the process.
Bottom line is that you need a Windows installation disc to make the hard drive bootable again, regardless of where you format it.
Aug 12, 2011 | E-Machines emachines (emachinees) CD-ROM...
Just yesterday my desktop pc worked fine but, today when I turned it on, it would not boot up as usual. I cant even boot up in safe mode or choose a restore point, nor can I install a new OS or repair...
It sounds like you have a bad hard drive. Your best bet is to install a new hard drive and install the OS onto it, then attempt to recover any data from the old hard drive externally using an external enclosure. Note any noises from the old hard drive like clicking (it's usually very loud and consistently timed), if you do notice anything then you won't be able to recover any data without spending a lot ($600 + ) of money.
Jul 26, 2011 | Computers & Internet
My laptop wnt boot up no matter safe mode or the other start menu's what am i to do
Do you have an external CD or DVD drive to plug into it? If so, and if you have a Windows installation disk, you can boot from the disk and do a chkdsk scan on the drive to make sure the drive doesn't have errors. If the drive doesn't have errors, you'll need to do a rebuild of the operating system.
If the drive did have errors and chkdsk says it fixed them, try booting into windows again.
If it still won't boot, do the OS rebuild.
If it reports there is no hard drive, you've got bigger issues and will need to have the unit repaired.
Jul 07, 2011 | Acer Aspire One Netbook 8.9" Notebook
My computer don't start after connect with my WD
From the FAQ section of the manual:
Q: Why won't my PC boot when I connect my USB drive to the computer before booting?
A: Depending on your system configuration, your computer may attempt to boot from your WD portable USB drive. Refer to your system's motherboard BIOS setting documentation to disable this feature or visit support.wdc.com and see Knowledge Base answer ID 1201. For more information about booting from external drives, refer to your system documentation or contact your system manufacturer.
I hope this helps! Please rate my reply. Thank you.
May 31, 2011 | Western Digital My Passport Essential SE...
Cannot boot to dos
You must be sure that the "USB boot" functionality is supported and enabled on your PC BIOS, otherwise the drive won't boot. Furthermore, be sure that the floppy disk you are trying to boot to is bootable in the first place, otherwise you can check some nice "boot disks" on (guess what?) BootDisk.com
Enjoy ;-)
Dec 31, 2010 | Teac FD-05PUB External Floppy Drive
PC won?t boot if my qmenory external drive is still plugged in?
go to bios, choose second optin, find disk boot priority, select your externel hard disk and click the minus button on the right side of your keyboard so it will be recoghised as the second hard disk. save and exit.
Apr 30, 2010 | Computers & Internet
Dell Latitude X200 Notebook Logo
263 people viewed this question
Alun Cox
