Paper Jams in the Printer ID:412
Turn the printer off and open the access cover.
Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Watch the paper as it feeds through and try to determine where the jam is occurring.
Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
Turn the printer off.
Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Leading cause of paper
jams is debris / foreign objects that accidentally fell into the paper feed
area. Please try this approach to fix the problem:
Leading
cause of paper jams is debris/foreign objects that have accidentally fallen
into the paper feed area.
1.
Remove the sheets of paper from the feeder.
2.
Grab a flashlight and look inside for any debris.
3.
If you're willing and physically able, you may also turn the printer over. Any
debris should just freely roll out from the feeder.
4.
If feeder is clear, open the printer cover and remove the cartridges.
5.
Check the cartridge area for any obstructions/debris that could cause this
error or problem.
6.
If cartridge area is clear, close the cover.
7.
Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
