Question about Toshiba TZ61V61 61" Rear Projection Television
Tz61v61 toshiba 61 rptv theaterview
Tv was working.shut self off.power button flashing red .can hear relays come in but no picture or sound.when power button pressed .
  • pyroo Apr 13, 2008
    got manual free .thanks. fuse is good where should i look next
  • Toshiba Master
  • 8,617 Answers
If the relay clicks you most likely have a leaky diode or bad transistor in the stand by or start up circuit. There is a manual available for that model called. Toshiba Power Supply and Shutdown circuit Troubleshooter. Its available at the following link. It gives step by step instructions so you can figure out exactly whats wrong with your set. The site emails it too you after you place your order and they also provide free unlimited tech support so you will have a resource for help if you need it. I am one of their on line support techs. I highly reccomend that Manual to any one with a toshiba that will not power up. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Apr 12, 2008
  • Sonny Berry
    Sonny Berry Apr 13, 2008
    The manual should show the components in the start up circuitry that should have required voltages, you will need to troubleshoot those voltages.
I have the Toshiba Theaterview. Was watching it when I heard a sound and the screen went black. The Red Light will come on and glow steady and you hear it click when you try to turn it on or off but...
Something is causing the TV shut down or go in to 'protect' mode.
It is unusual to actually hear a component inside the TV go bad, but you obviously did. Probably in the main power supply or something that normally uses a higher voltage in the TV since you heard it..
Jan 25, 2015 | Toshiba Televison & Video
Tv will not turn on and there is a red flashing light
Power supply problem.Maybe deffective regulator transistor.Need for repair and troubleshoot and replace deffective parts.
Jul 09, 2011 | Toshiba TZ61V61 61" Rear Projection...
My TZ61V61 rear projection 60 inch television turns off randomly. The red light by the on/off switch blinks. Sometimes the TV will still work though.
The blinking red light is telling you the code. Watch how many times it blinks. when it pauses for a seccond, watch again. Write down the number of times between each pause. Then repost with that info and I might be able to figure out what is wrong. Hopefully before it is permanent.
Jun 11, 2011 | Toshiba TZ61V61 61" Rear Projection...
WHY DOES MY TOSHIBA TZ61V61 loose picture but not sound. Unplug from power wait a few minutes plug it back in and it works
The vertical deflection has stopped which cuts off the picture tubes to prevent burn in. Check the vertical output or the deflection board may need replacement.
Aug 08, 2010 | Toshiba TZ61V61 61" Rear Projection...
My theaterview tz61v61 has no sound or video i checked the fuses on the on board circuit and, with the ones i could see, seem to be fine i have little knowledge of tv ciruits and tv troubleshooting. ...
U get all solid LED lights indication front of bazel panel of the tv?U got power LED light flashes or no LED light at all?Check for DM power supply board,for dying leakage bulges up capacitors on it tops or puffing up on it tops.Replaced dying capacitors."LAMP"LED light indication on stay on or flashes.The projection lamp is dead,require changing,also hear alot of clickings too.Mean the the board call the Ballast board is also dead,require changing too.This Ballast board help to ignite the projection lamp.
Aug 05, 2010 | Toshiba TZ61V61 61" Rear Projection...
My tz61v61 red and blues are out of line
It is the convergence chips in the tv. They can be replaced at a repair shop or by any one with experience in soldering. You can find them online
Jun 28, 2010 | Toshiba TZ61V61 61" Rear Projection...
Toshiba TheaterView
Called Tv tech. He said it was the power supply connectivity. common problem in rear projection Tv's. Cost to replace was anywhere between $300.00 and $400.00 dollars. Time for a new tv :-(
Feb 21, 2008 | Toshiba 50A60 50" Rear Projection...
Toshiba theaterview
What is the model number?
Jan 03, 2008 | Televison & Video
Toshiba theaterview tz50v51
my guess would be flyback however your lucky you might be able to see a burnt spot on the board giving you a better clue.
Nov 25, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba TZ61V61 61" Rear Projection Television Logo
571 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
