Question about GE WSM2780W Stacked Washer / Dryer
Both broken? Since the washer and dryer are "one unit", if one of them breaks, do they both stop working? My washer stopped working just before it finished filling for a normal cycle and won't start back up.....or drain. The dryer won't work either. Reset the circuit and breaker. So is this most likely a wiring issue with my condo or is the "entire unit" broken? Thanks
  • Tyson22 Apr 12, 2008
    Thanks Aborcass. I flipped the breaker a bunch of times. Nothing. Must be something with the condo's electrical. I'll call an electrician.
    President:
  • GE Master
  • 2,651 Answers
Sounds like an electrical issue for sure, too coincidental that both would stop functioning at asime time, they are independent units and should work separately . i would check your breakers, perhaps it has partially tripped
Posted on Apr 12, 2008
The dryer timer stopped working
Is that a temperature senor in the GE spacemaker Laundry dryer? My dryer stops spinning when it gets too hot. After it cools down, it will spin and dry again.
Jan 05, 2013 | GE WSM2700W Unitized Spacemaker Washer and...
Won't run after it fills up either small or lg. load.Just stops.
check the lid switch . unit will not work if the lid switch is not activated it's probably broken.
Jan 11, 2009 | Kenmore 98702 Stacked Washer/Dryer
My whirlpool thin twin filled with water and stopped!:(
Well if it fills then it needs the lid shut to work. So if the lid is shut it hits a lidswitch and if that lid switch is broken then nothing will work washer wise right? As far as the dryer that may be a blown fuse but nothing on the washer could stop it from running cept maybe a bad cord or breaker.
Dec 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
We have a washer dryer WD420 and the dryer has stopped working is that anything we can try and fix?
MOST TIMES WHEN A DRYER JUST STOPS AND DOES NOTHING IT IS EITHER THE DRYER DOOR SWITCH LOCATED BEHIND DRYER DOOR OR THE MAIN FUSE FOR THE DRYER IS BLOWN,MOST DRYER YOU CAN REMOVE BACK OF DRYER TO GET TO FUSE,ALSO SOME DRYER'S HAVE A SAFETY SHUTOFF IF BELT BREAKS IT IS UNDER THE DRUM,LET ME KNOW IF YOU NEED MORE HELP-MIKE
Jun 08, 2008 | Hotpoint Washing Machines
Washer dryer error code 'check outlet pipe'
the outer drum could have dropped ]it might be a shock gone or top spring] close ire bye
Oct 11, 2007 | Hotpoint Aquarius WD640 Front Load...
My dryer stopped working -- won't turn and motor makes odd noise like not engaged properly
At the rear of the unit on the lower right hand side of the dryer you will find a 6" X 6" vented panel. If you remove it you will have access to the Dryer motor and belt. Check to see if the belt has derailed or broken and you can also check to see if motor is operational.
Oct 28, 2006 | Kenmore 94702 Front Load Stacked Washer /...
Why wont my washer dryer empty the water...???
If the machine fills and agitates but does not drain, something is probably wrong with the drain hose or the pump. The fact that the washer fills and agitates tells you that the motor works and the belt is okay (though some units have a separate belt for the pump and direct-drive washing machines don't have belts). 1) Be sure the drain hose isn't kinked. 2) Check the tab on the lid that strikes the lid switch; if it is broken, the washer may stop during the drain cycle. Press and release the lid switch: if it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The water pump may be broken or clogged with a small article of clothing or the controls may be broken; call an appliance repairperson. courtesy "nagev"
Oct 24, 2006 | Hotpoint Aquarius WD63 Front Load...
GE WSM2780W Stacked Washer / Dryer Logo
136 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
