Question about HP Photosmart 945 Digital Camera
Problems with hp grlyb-0310
Camera keeps turning off when the push the on button
  • 1 more comment
  • Anonymous Jun 27, 2008
    exact same problem.....what to do?????
  • GreenLove Jul 19, 2008
    I did new battery's in it but it didn't work ,
    I'm searching for the reset button ,
    but i didn't found because i lost the discription.
    BTW the camera made beautifull pictures when he did work =D
    [ i know my english sucks ]
  • Anonymous Jan 09, 2009
    Pile cariche.
    il Display lampeggia
    Lo zoom non si chiude
    Lampeggia anche la spia rossa sopra lo zoom
    Non si riescono a fare foto
I turn on my camera and the screen just flashes. I have pushed every button but can't get it to turn on. help!
Posted on Oct 02, 2008
I have a hp model grlyb-0310 and its not reading the memory card. Its a used camera that I got from some really good friends of mine, I have tried three or four different cards. PLEASE HELP.
You often have to format the card in the camera before you can use it. Go to the menu system and look for 'Format', then follow the instructions.
Jun 04, 2016 | HP Cameras
I have a HP camera model GRLYB-0310 and it does not read the memory card . Can the camera be faulty ? How can it be fixed ?
it could be that the card is faulty, even a new item might be bad as the manufacturer only dose random sample checks and not all the chips are tested. before buying a new camera buy a new card it might also be that the card is not compatible with your camera
Nov 22, 2014 | HP Cameras
Model grlyb 0302
All cameras have a format card option, this will remove all pictures from your camera.
Sep 01, 2013 | HP Photosmart 435 Digital Camera
Camera does not read sd card
format the SD card from computer and then insert it Camera. Now see . if not reading then try other card. If the other card not read by camera then its a camera firmware fault.
Aug 06, 2012 | Sony Cyber-shot DSC-S700 Digital Camera
User Manual for HP GRLYB-0311
I have a HP Scan Jet Scanner Grlyb- 0311th. How can I connect it to my computer. The computer has no such connector.
Sincerely R. Pantic
Sep 08, 2010 | Computers & Internet
I have lost my instruction book for the model GRLYB-0310. Can I down load one from the web? Thank you C.M.Vallana
Try this link
Or go to and follow the link to 'support and drivers'
Mar 04, 2010 | HP Photosmart 945 Digital Camera
Hp M525 repair needed
My wife brought this camera home from work for me to look at. It had the sunken/broken power button problem.  The T-shaped hinge was broken where it connects to the power button section. I couldn't see any way to glue or repair it that would be strong enough so I came up with an alternate fix.
The actual power switch is below the broken button, just a touch below the "ON/OFF" text. I decided to make a button that pushed the switch directly rather than pivoting like the original.
I needed a push-button shaped object with a shoulder on it (so it wouldn't fall through the hole I was going to drill in the back). I ended up using a small green LED (3mm size I think). I drilled a hole big enough for it to move but not so big it would fall through. I cut the leads off flush with the body and sanded them flat. The hole I drilled lines up with the little bump on the original plastic switch piece.
So I put the LED in place, the original plastic piece over it and added a little bit of self adhesive felt (that you would stick on the bottom of something to protect your furniture) at the top where the silver button is (just to keep the original button from sinking inward). I put the back on the camera and checked that the power button clicked nicely. It did so I put the camera back together and it's as good as new.
And it has a snazzy green power button now.
So if you are handy you can probably fix the camera yourself.
Good luck - Greg
Jul 03, 2008 | HP Photosmart M525 Digital Camera
HP Photosmart 945 Digital Camera Logo
2,271 people viewed this question
Top HP Cameras Experts
Fred Sops
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
