Question about Samsung SyncMaster 17" TFT LCD Monitor
Noise and popping sounds
For the last month or so my screen pops and hums intermittinly. The only fix at times is to turn the monitor off. Everything seems to work otherwise.
  • 72634 Apr 12, 2008
    thanks, I'll give it a try.
  • 472 Answers
But the important question is really,does it have a good beat ?
Sorry couldn't resist.
Chances are you just have a few bad capacitors on the power supply board. Any TV repair shop should be able to take care of this quickly and reasonably cheaply. Best bet is to make a few calls to local shops first though for a rough quote, and also to make sure they do service LCD monitors there, not all do.
Hope that helps.
Posted on Apr 12, 2008
The freezer side of this unit quit freezing. Everything is thouging out. Fridge side isn't as cold as it used to be. Both controls have been set on factory recomemded settings since install. I keep...
A popping noise? Could it be the clicking of a relay? There is a relay that activates the compressor that could cause a clicking sound if it doesn't hold. A popping sound could be a bad capacitor but normally isn't a continuous popping sound, unually only one pop.
If the unit is only 4 monthes old it should still be under warranty and you should call it in for repair.
Jun 16, 2011 | Refrigerators
I have a 42" LCD Westinghouse Model# TX42F810G, it is less than 8 months old. I turned it on and it made a popping noise, now the screen has vertical red lines and it looks as though it was hit with a...
Sounds like the Display Cracked. This is not the first time I heard of a display breaking on Westinghouse and Poleroid LCD TV's as they are made in the same plant in China. Sorry to say a new display will cost more than a new TV.
Oct 09, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have had the same problem off and on with my 47LG70 for months. When the "popping" noise happens, the blue light in the corner stays on, so I know the tv is still on (sometimes I still have sound, sometimes I don't). Sometimes the screen goes black, but other times it is blue. If I turn the tv off then on again, it might stay on for seconds, minutes or hours. It's been very frustrating.
This seemed to happen right after I got my new Comcast box, which came with an HDMI 1.3 cable. I read somewhere online that this tv might not be compatible with that cable, so I unplugged it and am using component cables again. I just did this today, so I don't know if it will work, but so far the tv has been on for 30 minutes with no problems.
I'm pretty ignorant about HDMI compared to component cables. I imagine I will not get as good a picture with the component cables, but I am willing to sacrifice quality if I can just get the darn thing to work. Mine is also only 18 months old.
Hope this helps. If it doesn't, maybe someone else out there can help us both.
Sep 21, 2010 | LG 47LG70 42 in. LCD TV
19d flat hp screen monitor have some problem; when turn on is lont time to start up. Has some cure for fix it? It make a sound like pop, pop, pop then start, but it take long.
At this point I would suspect the capacitors failure in the power supply, that will be he first thing to look for, see example of failed monitos due to bad caps:
Post back what you see inside so we can guide you further.
Mar 23, 2010 | Computers & Internet
Popping and Humming noise from my audio system?
Ground Loop Isolators are nice, but if you want truly crystal clear sound, you will need to run a common ground. All electronics will need to be run close to the amp, as more than about 3 feet of ground wire from the amp can cause sound issues. When I ran my common ground, I connected my radio and satellite together, and ran one sigle ground wire to the backseat of my car, where the amp grounds are located. This will optimize the clarity of the sound coming through the speakers. For the popping sound in the speakers when the car is powered on or off, you need to see if the radio itself has a wire to power the remote connection on the amp. Most of the time, they will, and this is the wire you will use to turn on the amp itself, as it delays each item powering on and reduces the chance of popping in the speakers. DO NOT run the remote wire from the amp to the accessory wire of the radio, as this will cause the popping sound you are hearing. If the radio does not have an Amp Turn-on wire, then you may need to improvise by using an accessory wire in another location, but even this is may cause popping as well. The pop comes from multiple things turning on at once, so the Amp Turn-on wire delays the amps for just a moment, preventing the pops.
Oct 05, 2009 | Pioneer DEH-P6400 CD Player
Pop - bang noise then went dead after a period of time
You've blown a capacitor and probably the horizontal output circuity. It's time to get a new LCD monitor.
May 30, 2009 | Sony GDM F520 21" CRT Monitor
TV made humming noise for past few months and after it warmed up the humming would go away. It that same thing today and a pop noise came and the screen will not come on, and the tv shuts off and then...
i took off the back and pulled out the the fan. Then put in a fat screw between a slight gap whick kept the fan from hitting what ever is causing the noise. probably not safe but nothing bad happened yet.
Apr 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Lound humming noise and color distortion
you will be able to fix it. the sound you heard was a color wheel.. the part number is bp96-00674a
Mar 18, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Monitor turns off
Since the green light is going out the monitor's power supply could be the culprit. That popping sound is not good. I would replace the monitor all together.
Jun 03, 2017 | Acer AL1715 (Black, Silver) 17" LCD...
Computer making noise
Monitor clicks, pops, or makes other noises. Issue: Monitor clicks, pops, or makes other noises.
Cause: This issue could be caused by any of the below possibilities:
  1. Monitor degaussing.
  2. Monitor changing resolution.
  3. Monitor syncing with the video card.
  4. Monitor warming up.
Solution: Noise when turned on or off It is normal for standard computer CRT monitors to make a click, pop, crackle, hum, buzz, or other type of noises when they are first turned on or turned off.
Noise when monitor goes into standby mode When the monitor enters a "standby mode" or "power savings mode" this is similar to the monitor being turned off. It is completely normal for the monitor to make a noise when the monitor enters this mode.
Noise when opening Microsoft Windows or other operating system or when opening a game When a computer opens its operating system, for example, a computer opening Microsoft Windows or when a user runs a computer game it is very common that the monitor will need to switch its resolution of the operating system or game. When switching resolutions it is normal for the computer monitor to make some type of noise and/or for the computer monitor to flick or flash.
Noise during normal operation If the computer monitor click, pops, or flashes while it is being used this is not normal operation. It is very likely that the monitor may be failing or a component within the monitor has already failed and could also potentially be a fire hazard. We highly recommend that the monitor be repaired, replaced, and/or looked at by a qualified technician.
Additional information:
  • See document CH000302 for additional information and other noises that may come from
Jan 16, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Computers & Internet Logo
143 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
