Question about Sony KDF-E50A10 50 in. LCD HDTV
Sony xbr5 problem - colored lines of about 2 inches in the middle of the screen
I just noticed 3 colored lines in the middle of my 2 month old sony xbr5 52 inch tv.
Any suggestions on why that could happen is greatly appreciated.
  • fred2222 Apr 23, 2008
    diagonal lines on top 2/3 of screen. dasnj@sbcglobal.net
  • Anonymous Jun 16, 2008
    I have 2 vertical lines about 7 inches long in the middle of the screen. This is on the Sony XBR5. I've had the tv since December and it just started happening. I can see the lines even when the tv is off. I have called for service as the tv is still under warranty.
  • 163 Answers
SOURCE: vertical lines in screen
Are the Lines Symetrical in distance and space? Makes a diferernce..
Posted on Jan 22, 2008
SOURCE: Picture problem
raystratton
I was wondering if you were able to solve this issue. i am having the same exact issue with my tv. and i did not get an extended warranty thinking that nothing would go wrong with a sony tv. i learny my lesson the hard way. Can you please tell me what the tech told you or what you did to fix this problem. All your help will be greatly appreciated. Thanks once again!!!
Posted on Jul 23, 2009
tvservice306
  • 458 Answers
SOURCE: lines across tv
try cleaning T-CON Board to Lcd panel cable
Posted on Aug 19, 2009
SOURCE: Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Posted on Sep 21, 2009
Selvol
  • 115 Answers
SOURCE: My Sony KDL 52S5100 52 inch is great except for
Check the  user manual.  You have the Auto dark enabled.
Or so it sounds. Disable that.
Selvol
Posted on Dec 06, 2009
Hi, I have a 6 month old laptop Acer emachines E625 and turned it on this morning to find 3 thin black horizontal lines have appeared (with about 2 or 3 smaller lines above each of the 3 lines) at the...
Attach an external monitor to your PC. If the problem continues there, it's your graphics card.
If the problem disappears, you have stuck/dead pixels.
You could try a very gentle rubbing of the pixel(s).
Feb 03, 2010 | Computers & Internet
Sony wega kde-61xbr950
Can be a problem with a misplaced connection, more likely the Ysus card to be replaced.
Aug 30, 2008 | Sony WEGA KDE-50XBR950 50 in. Plasma HDTV
Noticeable line through screen picture sony KDL-40V3000
TRY USING THE COLOR CONVERSION OPTION ,,ITLL FIX THE COLOR
Mar 07, 2009 | Sony BRAVIA KDL-40V3000 Television
Vertical lines on my 40 inch lcd mitsubishi hdtv 1080
Similar problem with an eleven and a half month old LT-40148. Approx. 1 inch vertical banding line on left side of screen on all inputs. After about two weeks, same problem on the right side of the screen.
Fortunately this occurred two weeks prior to the one year warranty expiring.
Called Mits customer service and they referred me to an authorized service center who I happened to have dealt with before.
They picked up the set. The front panel (LCD screen ) had to be replaced. Set was gone for two weeks as parts were not in stock. There was no charge. I hope this screen last more than a year.
Jan 16, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Sony 40 inch lcd television
Call Sony!! It Will get worse!!! The panel has ribbons that have fine wires that are used to show each line of information on the screen. Either the panel is going or the wires are loose. Either way, the panel needs replacing. Just hope to God it's under warranty or if not, sony will help you out with a buy-out.
Aug 07, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
SONY 52" XBR5 Screen Damage
You are correct, the screen is damaged and in most cases cost mre than a replacement tv. There is no repairing a damaged LCD panel, just replacing.
Jan 31, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Vertical lines in screen
Jan 21, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Black screen, high pitched squeal
A set that has only a 1/2 inch bright line through the middle of the picture, from left to right, has a vertical output IC that is not working correctly. If the 1/2 inch line is in the middle but going up and down, then the horizontal yoke circuit has stopped working. These are problems which should be looked at by a qualified tech, but if the set was purchased 6 months ago then it should still be under the manufacturer's warranty.
Aug 29, 2007 | Philips Magnavox 20MT4405 20" TV
Sony KDF-E50A10 50 in. LCD HDTV Logo
111 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
