Harman Kardon AVR510 - At random times the volume will creep upwards. Other times it will shoot upwards. The remote works every time to turn it down, & the knob on the unit will work 50% of the time when this is happening. If anyone knows, thanks in advance
I have worked on two h/k for no sound. The only problems I have found are bad solder joints. You have to look very close to see the cracks. Most of the are found at board conectors. The last one I worked on did not look like there were any bad solder joints, but after resoldering 100 pins on boards the unit came to life. I would start with the volume control. Their is a nut that holds the control tight to the frount face under the nob. If the control feels loose, moves side to side I would suspect your loose conection to be at the control itself. Make shure to tighten the nut on the control after you fix.
Posted on Apr 12, 2008
Harman Kardon AVR 120 volume goes up all by itself. I turn it down, it goes up again. over and over ... then it stops doing it. Is it the optical cable? COMCAST?
After setting volume remove all remotes from the room. It is possible that a button is staying activated.
All in the setup of the TV if you are using the "net" option that allows for communication between devices on the HDMI connection turn off as a possibility.
Last resort is the volume control motor driven knob on receiver see if receiver is defective try with other inputs such as radio etc.
Disconnect all inputs and see if volume increases?
Hope this helps?
Nov 01, 2016 | Harman Kardon Audio Players & Recorders
How to troubleshooting
prob with the audio amph on the motherboard
Dec 04, 2013 | Harmon Kardon Harman Kardon Harman/kardon...
My HK 1005 incresases volume to max by itself
I had the same problem; got rid of it by changing the baateries of ma remote control.
Jun 27, 2010 | Harman Kardon DPR 1005 Receiver
Ipod to harman/kardon
Using a headphone to RCA adaptor plug the headphone jack into the headphone connector of the Ipod. Then plug the RCA jacks into any available Analogue input on the receiver. Increase the volume on the Ipod to 80% then adjust the receiver's volume according.
Or get a dock that will allow remote control and charging, such as Roth, DLO or Wadia.
Dec 19, 2009 | Harman Kardon AVR 35 Receiver
My Harman Kardon AVR 254 is not responding. None
I am having the same problems with my AVR 254, did you find a solution?
Thanks
Mar 15, 2009 | Harman Kardon AVR 325 Receiver
Harman Kardon Elegant 2.1 speakers problem
'Sounds' like you have overwhelmed the cone and split it or a solder joint has come adrift Don't know about repair or replacement -Check makers website.
May 13, 2007 | Harman Kardon HK695 Computer Speakers
Chances are you have wrecked the cone and movement with the overly high input. Nor repairable if this is the case. Check out the makers website for more tech info
102 people viewed this question
 Grubhead
Grubhead
