Question about Sony Playstation 3 (PS3) Console
Ps3 hiya i have put all the leads in to the back of my ps3 and in to the t.v and there is no picture when i turn on the ps3 can you help?thanks danielle
  • Blade86 Apr 14, 2008
    my ps3 wont work i plugged all the cords in correctly and pressed the button and nothing happened i have tried holding the power button down for a few seconds and it didnt do anything i have tried different cords and nothing works please help me.
    Problem Solver:
  • 6 Answers
When the ps3 is off and the red light is on hold down the power button for a few sec untill you hear a beep then let off
Posted on Apr 13, 2008
  • nickwht Apr 14, 2008
    ok make sure the red light is the only thing on. press the power button do not let off it takes 5-10 sec the system should restore its self and find your components. if not you have an internal problem. give a bit more info. what cords are you using? is it a sdf or hd? do you hear sound from the tv?
My ps3 picture dont come on
are all your leads plugged in right? and also what colour is the light green or yellow?
Aug 05, 2012 | Sony Playstation 3 (PS3) Console
Nothing show up on tv screen after plugging in the cables. the HDMI and the AV cables too.
Hi, try the following
1 using the av lead and not the hdmi so plug the av lead into your tv and make sure your tv is on the correct input
2 turn the ps3 on at the back
3 now press and hold the on button down until the ps3 switches itself back off
4 then press the on button again, doing this resets the video mode from hd back to standard av so once you have done this you should have a picture on the tv, if not check your on the correct input
if you have done the above and it still dont give you any video than please let me know then ill do my best to assist you further ok
please rate this solution, thanks
Dec 13, 2010 | Sony Playstation 3 (PS3) Console
I have just brought ps3 and when i plug the leads into the tv ie red white and yellow leads i can not find the channel on my tv i have tried other tvs and same thing so i done away with the lead and just...
Hi, try not using the hdmi lead and plug the other lead back into the ps3 the normal av lead with the 3 color wires, now plug it into your telly now switch the ps3 on at the back so the red light is on at the front, now hold down the one button and it will bleep once then bleep twice and keep holding it down till it switches back off
so basically you switch it on at the back then press and hold down the on button until the ps3 turns itself back off, now what this does is reset the video mode so its not set to hdmi settings, now press the on button again and wait for it to come on if you still dont have picture on the telly make sure the video lead is fitted correctly and then get the telly remote and find one of the following buttons
av
source
input
or a rectangle with an arrow facing to the right.
once you have found this button make sure the ps3 is on and then press this button on the tv remote, you may need to press it more than once depending on how many inputs the telly has on it.
now when you press the button on the tv remote press it once then wait 5 sec before pressing it again just to give it chance to pick the signal up.
hopefully now you have the ps3 working through the normal av lead
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Nov 28, 2010 | Sony Playstation 3 (PS3) Console
Hi i bought call of duty. i updated my ps3 when i first put the game in and it worked fine , but now when i turn my ps3 on ,nothing happens. the power is going to the ps3 , but nothing comes up on the tv ,...
This will be something to do with the av cable or the HDMI lead. try replace them. if it still doesn't work, Message back to me and i'll have a in-dept look at your situation.
Have a great day. Thanks
Nov 20, 2010 | Sony Playstation 3 (PS3) Console
I get no picture on the tv when i turn the ps3 on. i have tried changing scart leads and scart sockets in the tv with no luck.
put your old av cables in you got with the ps3. turn system off, turn it back on using the button on the console not the control but hold the button down until you hear it beep once, keep holding it down until you hear a second beep, this will reset the ps3 back to the av outputs. you can change it to scart afterwards in the video menu settings
Jun 20, 2010 | Sony Playstation 3 (PS3) Console
When putting dvd in there is sound but no picture.
Turn your ps3 off and turn it off at the back of the console. Disconnect either your HD lead or AV lead then re-connect. Turn the power on at the back then turn the console on by the sensor standby button on the front. Once booted up and on xmb screen (making sure there is no dvd in the console) press and hold the standby button on the front for 4 sec, after that you should here two beeps and the console will turn off . This resets the picture and sounds settings that the playstation would have automatically adjusted to when you first connected it to t.v . Turn the power off at the back again , then turn it on , turn console on and it will automatically adjust to that t.v again . Now try your dvd again and it should work. If it still doesn't then it possible you might need a new lead.Hope this was of help to you . PK
Feb 05, 2010 | Sony Playstation 3 (PS3) Console
My optical in the back turns red when the PS3 turns on, no screen
put a game in put it on standby hook your controller with the usb lead in (red light) press and hold power it will beep ,beep , double beep shutdown by itsself turn it back on it should default back rf
if not do the first instructions again but power back on by holding down again beep, beep, double beep but let go of the button b 4 it shuts down and there will be a dev mode this is something sony dont want you to know if helps give me a tick so to help others
Aug 26, 2009 | Sony Playstation 3 (PS3) Console
Cant get picture
Turn the power on at the back of the PS3 and the red light will apear at the front, press the on button on the front and the light will then go green, then press and hold the power button on the front until the PS3 beeps at you and this should reset the PS3 from HDMI to standard Scart Cable...
Let me know if this is helpful to you :)
Mar 30, 2009 | Sony Playstation 3 (PS3) Console
PS3 hook up to sony reciever
its in the sound settings on your ps3, change to hdmi out put, this should sort it, if not you can use your scart lead for the sound, just use red and white lead straight into your sound system or sony reciever. but you will need to set it up in the sound settings in your ps3. hope this helps
Feb 11, 2008 | Sony Playstation 3 (PS3) Console
Canon powershot s1 is
looks like a lot of us have this same problem, Danielle. Consensus is it's a problem with the CCD chip. I'm contacting Canon about ours. Hopefully they'll fix for free as one guest posted. Let's be optimistic!!
http://www.fixya.com/support/t224203-black_screen
Nov 08, 2007 | Canon PowerShot S1 IS Digital Camera
Sony Playstation 3 (PS3) Console Logo
29 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
