Question about Samsung CLP 300 Laser Printer
Low heat CLP-300 fuser low heat problem!
  • 74 Answers
Depending upon how old the printer is, if it is less than a year call up samsung and they will send out a technition within about 2 days to your house to replace the fuser unit, i had the same problem, if older than a year, you can probly order one, but be warned, i think they are like $120 but appear easy to replace, just undo the two screws at the front cover to pop off the top cover, then there should be 4 screws holding the fuser in place, remover and then slide the end of a roler on the left over to remove.
Hope this helps
Mitch
PS don't forget to rate me
Posted on Apr 14, 2008
5 Suggested Answers
  • 526 Answers
SOURCE: Samsung clp-300 Error message is
The problem is that the Fuser is not heating up. Its possible you have a broken heat lamp.
The Fuser will have to get replaced, if you want to spend less but more labor, the heat lamp can be ordered.
Posted on Mar 11, 2010
SOURCE: Engine Fuser Low Heat Error on Samsung CLP-600N?
i have samsung laserprinter 1610 problom low heat error ple telme anw
ser
Posted on Oct 24, 2010
  • 525 Answers
SOURCE: have samsung CLP 510 printer
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Posted on Jan 21, 2011
  • 525 Answers
SOURCE: Samsung CLP-600N displays message -
I have an error message 'fuser low heat error' and the printer does not work. I have cleaned it up but can not get it to work
This is going to be a fuser replacement, or a dc power supply. The error you are getting is a direct result of the fuser temperature not reaching minimum temperature for fusing toner to the paper. This needs to be seen by a technician, as the current needs to be tested in order to figure out which part it is.
Sep 30, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP-600N displays message - engine fuser low heat error. Machine is out of warranty.
Aug 10, 2010 | Samsung CLP-600N Laser Printer
Fuser low heat error
Hi and thank you for using fixya:
This happens when the fuser is not getting hot enough to start the printing process. This could be happening because the fuse is already failing. Try calling samsung see how much is a new fuser
good luck
Mar 23, 2010 | Samsung CLP 300 Laser Printer
Samsung clp-300 Error message is "fuser low heat error
Mar 07, 2010 | Samsung CLP 300 Laser Printer
Samsung clp-300 Error message is "fuser low heat error"
your printer toner is not installed properly. pls shake the toner & fix again.
Sep 01, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP-315 system error
Low heat error comes from the fuser unit, there is a thermostat on the fuser change that and it will work
Mar 29, 2009 | Samsung CLP 315 Laser Printer
My samsung clp-300 printer is very hot
low voltage power sully and fuser need replacing.fuser is overheating.
Oct 15, 2008 | Samsung CLP-300N Laser Printer
"Low Heat Error"
Thats probably the best way to solve the solution. Sometimes if there is a thermistor that is causing the problem that can be serviceable in the fuser unit, that can be replaced instead of purchasing a whole new fuser assembly. It's less expensive replacing the thermistor.
Jul 16, 2008 | Samsung CLP-600N Laser Printer
I have just replaced cartridges and am now getting fuser low heat error.
Yes, either the lamp in the fuser is burnt, the thermistor (heat sensor) on the fuser is burnt, or the low voltage power supply is not providing enough voltage to the fuser lamp. Your safest bet is to replace the fuser.
BUT!!!! The printer itself is let than $150 new with warranty, so if you like this printer I would buy a new one. A fuser will be between $90 and $150 and could be difficult to replace. If you get a service person to replace it you could expect two hours of labour at least which will be about the price of a new printer.
Jun 16, 2008 | Samsung CLP 300 Laser Printer
Heat and electrical smell
The smelland heat is probably from the fuser as it gets extremely hot, if the printer's new it might settle down. No you shouldn't have to turn the printer off when not in use.
May 11, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
257 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
