Question about Dryers
Dryer smelled of burning plastic, smoked stopped turning on
After being used for about 4 loads the edryer turned off and at about 2 am filled the basement with smoke and smelled of burning plastic. We took the dryer apart and vacumed out all the lint, cleaned everything out, did not see any burnt wires but it still will not work. We have unplugged it because now when plugged in it smells of burning plastic
  • Anonymous Mar 19, 2014
    I was drying clothes two loads the third load it made a loud noise and stopped it and then i smelled something burning. A couple of days later and started it and it began to tumble soon after that I smelled something burning so I unplugged it and have not used it since do you think is a belt.
    Genius:
  • 1,073 Answers
Check the power cord itself, if you see on the back side of the cord a burnt or blackened spot then the cord is the issue
Posted on Apr 12, 2008
I got a toaster about a year ago and a couple weeks ago it would start smoking and smell like burning plastic whenever I used it. My dad's a cheapskate and won't get a new one so I kept using it and now...
Please stop using this thing. You are working with deadly voltages and a very high risk setting your house on fire.
Keep in mind, if the thing starts to burn you can't use water to put the fire out.
The heating element must be broke lose of its settings, or someone dropped his or her toothbrush in the apparatus. Never try to repair kitchen equipment when it is connected. Not even when you think it is switched off.
Oct 30, 2013 | Washing Machines
Maytag washer MAV6650aww burning smell
OK, this model has a known issue with a bad pump design. The bearing on the pump goes bad and will lock up. The burning smell is the belt trying to turn the pump. Look under the unit and see if you see rubber residue at the pump. Here is the pump to order. To replace the pump, tilt the unit back and remove the belt. Remove the back lower left side access panel. Remove the 2 hoses, then the 3 bolts that hold the pump down. Replace in reverse order. The pump is a new design it looks completely different but will last you the life of the unit.
Dec 09, 2012 | Washing Machines
The dryer makes a loud noise and also a rubber smell develops after a 1/2 hour of use
My dryer did the same thing. I had to replace the front support glide assembly and needed 4 teflon glides.
The front part of the dryer runs over this plastic piece seen here upside down.
this part is about $50 CAN there are 4 plastic or teflon glides that fit into this.
My dryer had worn through the teflon glides and start wearing away this piece.
My dryer is a GE front load dryer. And I did get a burning smell because the dryer was wearing away the plastic. After the teflon strips wore down.
Hope this helps
Jun 01, 2009 | Kenmore Dryers
Maytag Neptune Dryer smells like burning rubber or plastic...
The drum belt could be rubbing on something inside. Does the dryer make a squeeking noise? Se if there are small rubber particles on the bottom, this will indicate a deteriating belt.
May 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Winding sound, with a smell of burning
I recommend to stop the use of the dryer immediately and call an expert repairman to your home. The smell of burning can only mean bad things, so better safe than sorry.
Dec 29, 2008 | Indesit WA 125 Front Load Washer
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
Washer stopped filled with water, smells like burnt plastic
REPL/ PUMP BURNT PALSTIC SMELL ,AND RUBBER SMELL, ONCE REPL./ SHOULD FIX
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer just stopped
I would check the drainpump ans see if there is something jammed inside like a coin or screw,nail etc before doing anything else .Unplug the machine first though . A burning smell will occur with a load of water trying to spin .
Nov 06, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Dryers Logo
529 people viewed this question
Top Dryers Experts
