Question about Technics SL-1200MK2 Turntable
Technics dj deck 1200mk2
All electrics working but platter suddenley stopped spinning? please help driving me nuts
  • 515 Answers
So the unit powers up still? First and foremost check to make sure there is nothing forcing the platter to not rotate. If the platter is fine, and there is nothing holding it back, then you have a drive issue. More than likely one of the IC's (Integrated Circuits) failed, or it could be one or some of the other resistors which control the drive/platter on this unit.
Unfortunately, this is not an easy fix. You will need to take it to a qualified service center for repair. Make sure you ask the service center if they are familiar with the drive of the Technics SL1200MK2, many service centers are not.
- Optic.
DJ PRO LAB
Posted on Apr 21, 2008
Platter stops when back-cueing
? so you take whole the platter with you when back cueing ..... i would buy some good suzuki slipmats and don't stop and spin the platter backwards , that's allways bad and why pushing that hard....
Dec 06, 2013 | Technics SL-1200MK2 Turntable
The platter on my Technics SL 1200MK2 stopped spinning. The power works fine... the platter doesn't want to turn. It feels like it just wants to be stuck?! Never had this problem with any of Technics...
If you remove the rubber pad from the top of the platter then you should be able to lift the platter off the servo drives' center shaft,
from memory the unit is not attached just held on by gravity,if the servo magnet is gone the take it in for a service and pay the man for his time,
My first problem on my 1200s was a pitch control issue and easy to fix,with a little cash,never use second hand parts unless you know what you are doing because when they fail on you while playing to a packed dance floor then youll get more of a supprise than you barginned for,
Misterdj
May 03, 2010 | Technics SL-1200MK2 Turntable
Motor problem?
If its still working then GREAT! The direct drive system uses magnetic frequency to drive the table platter. If you havnt already....Remove the platter and clean the coke off the magnet under it. Not sure at this point but hope that helps!
Apr 04, 2010 | Technics SL-1200MK2 Turntable
How to replace target bulb in 1210?
Instructions on replacing your pop-up bulb can be found here: <a href="http://1200s.com/Service/Tech/Settings/pop-upbulb.php">REPLACE TECHNICS POP UP LIGHT / BULB</a> - OPTiC The ORIGINAL 1200 TECHNICIAN. www.1200s.com www.djproaudio.com www.djprolab.com Technics DJ Repair Videos Technics DJ Repair Technics DJ Parts DJ Parts DJ Equipment Sales Audio Video Accessories
Jun 03, 2009 | Technics SL-1200MK2 Turntable
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Mar 26, 2009 | Technics Audio Players & Recorders
Platter changes directions or stops
More than likely either an issue with an IC (integrated circuit) on the main PCBoard such as IC301 (Pitch Control IC) or one of the Regulators like Q2 and Q3. While your at it, you might want to check IC201 (Turntable Control IC), and IC101 (Turntable Drive). Doesn't sound like anything is busted just yet, if it comes and goes. This means something is about to fail, and your just seeing the failure in action.
Good luck.
- OPTiC
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Feb 01, 2009 | Technics SL-1200 Turntable
Technics SL-1600MK2
Tonearm lift is probably a deteriorated belt. Google it, it's pretty common. The platter spinning might be due to a bad control board. You'll probably have to go to a repair shop to diagnose it.
Oct 13, 2008 | Technics SL-1200MK2 Turntable
Technics 1210s mk2
You have a short somewhere on your main PC board that is causing this. You will have to take it to a qualified service professional for testing.
There is no 'motor' per say on this model. It is direct drive, so there is no moving parts. A drive coil rotates the magnet that is located under the metal platter. This in turns causes the platter to rotate. You can stop the platter, and nothing will happen to the drive system. It's basically just not going to turn. There is no resistance occurring, which is the beauty of these turntables, and which is why DJ's prefer them to other models on the market - especially the Turntablist community.
More than likely there is something on the main PC board that is causing a short, blowing out the fuse. Look at R213 - see if there is a discoloration around it, also take a look at Q2 and Q3.
If you have no idea what I am talking about, then don't try to figure it out. Take it to a service center.
- OPTiC
The 1200s Expert
www.REPAIRNYC.com
Aug 18, 2008 | Technics SL-1200MK2 Turntable
1200 platter drag
the platter should have two holes on it,my 1210 does. put your thumb on the spindle and a finger in each hole and prize the platter off. theres no screws holding the platter on just a tapered spindle shaft. it is quite heavy so a good pull will do it. as for the scraping it might be as simple as packaging placed under the platter to secure it for shipping, technics are built really well so i cant imagine it could be anything major. i hope this helps you out, if you need any more help let us know. please also let us know how you get on. darren
Oct 05, 2007 | Technics SL-1200MK2 Turntable
Platter will not spin....
Um, why did you clean off the magnet with rubbing alcohol? Is this other DJ a service technician? Please be cautious when taking advice from friends or colleagues. Consult a professional, otherwise, you might cause more damage to your unit. Now, on to the problem at hand... This is a common problem with the MK2's, and not a power issue. This is a drive issue, and you will need to get it professionally serviced by an authorized Pansonic/Technics service center. There are various components which control the drive of the MK2's, so it's not easy to determine which is the culprit. 95% of the time it's one of the IC's (integrated circuits) or a few, or all. Which is why you will need to take to a service tech to get it looked at... Now, I know that's easier said then done, as many service centers do not provide support for turntables, especially the 1200s. So make sure you ask if they are knowledgeable with the Technics SL1200MK2 series. A lot of times, many of these places will be factory authorized to repair Technics/Panasonic items, but none have ever seen a Technics SL1200MK2 turntable, or worked on a direct drive unit. Many work on CD Players, Cassette Decks, etc. Our company offers free return shipping for all Nationwide service, and if your in NYC, we offer free pick up. Oh, and we are masters with the 1200s. Unfortunately, I don't think we can post our company information here, as I do not want to violate any agreements. So, with that said, do a search using the REPAIR SERVICE search option in FIXYA.com and go to the following section-> HOME AUDIO -> Audio Shelf Systems - we are listed.
Aug 04, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
246 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
