Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint WD 23
Programmer cycles when switched on.
Have checked the pressure switch and the outlet filter.
  • 57 Answers
IT MAY BE WORTH CHECKING HEATER ELEMENT OR THE THEMOSAT
Posted on Jul 16, 2008
Hotpoint 720 part fills but goes no further and no faults show
Hotpoint 720 incorporates a fill pressure switch, it monitors the fill level and passes instructions that sufficient water level has been reached, and instructs the programmer to continue to the next stage of the cycle.
Accepting, that enough water has entered the drum, the level switch could be faulty, however it is most likely to be the programmer.
To test any of the fault finding to cure this fault requires removing panels and I would not recommend you doing this unless you are qualified.
If you are however qualified and satisfied that you can proceed safely, with concerns for your own safety, I will send you, a process on how to proceed, checking out weather it is the pressure switch or the programmer.
Trust you find this answer helpful
Adam
Jan 14, 2018 | Hotpoint Washing Machines
How do I start my washing machine,as soon as I switch on at the plug the lights all flash and it wont start.
Is it an old machine with physical switches (push to hold etc) or electronic ?
As a starter....make sure cycle on switch is off then plug in..... wait for few minutes while it sets its programmer... the light should settle. Attempt a wash. If it's still flashing erratically... main board might be blown or motor burnt out......or the rubber band may be disconnected from drum. ...
Dec 03, 2014 | Washing Machines
Hotpoint aquarius WD740 F13 Drain issue?
Your problem is with the pressure switch to locate it try to find a thin pipe going from the tub to the pressure switch it's a round machine having a thin pipe and some electrical cables, try to remove the pipe and blow air in it if there is dirt it will goes in the tub also check the filter if there is no filter it will not drain
Feb 10, 2014 | Hotpoint Washing Machines
Error message f-05
Possible that the pressure switch is struck up in full, It will be best to remove the switch and clean or release the jamming. Also check the drain for clogging , check the INLET flow, if not clean the inlet filter as well as the outlet filter on the drain pump.
Sep 04, 2012 | Hotpoint Washing Machines
Machine runs wash cycle but fails to drain and spin. When door unlocks I remove and replace wet washing then switch on rinse and spin cycle. This seems to work but is no long term answer.
Hi, The washer will fail to spin if there is too much water in the machine, check the filter on the machine is not clogged or blocked if it's not then the pump could be suspect, normally you can hear it running on the spin cycle. it could also be the motor brushes are worn.
if its none of the above I would suggest that it maybe the pressure switch or pressure switch tube blocked other than that the last resort is the programmer or motor control panel.
Hope this helps.
Feb 09, 2011 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMA45, not spinning
New door lock needed, about £15.00 Spin problem may be motor brushes,
Feb 12, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Error code f5
I think you mean error F05 for a Hotpoint washer.
it means the pressure switch is jammed on full, check pump is working o/k and if there is a filter, remove and clean it, see user instructions..
If still no joy, then you will have to call an engineer..
Plz rate this solution.
Thanks.
Jan 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860T
Alarm
code Description of fault User
code Effect
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Jan 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
29 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
