Question about Toshiba Satellite A135 Notebook
Adding bluetooth printer to Toshiba laptop
I'm trying to add Canon bluetooth printer with a Kensington adapter. The computer is not reconizing any bleutooth devices. It says printer is on LPT1. What should I do?
  • Darrell Kittle Jr
    Darrell Kittle Jr May 11, 2010
    What is the part number of your laptop, and is there a bluetooth module listed in the device manager? Also Toshiba laptops have a sticker on the base if the laptop has a bluetooth module installed. Is it listed and is there a sticker on the base?
    PAeasop
  • 12 Answers
Install printer as a network(TCP/IP) printer instead of LPT1.
Posted on Aug 26, 2009
How to turn on bluetooth
Hi.........
Hello........
Try looking around in the Control Panel. The "classic view" might help you find exactly where it is located.
These computers can be made with Bluetooth, but it is still an option, so you may or may not have it. If you don't, small USB adapters are available anywhere that sells electronics (Target, Wal-Mart) for about $20 if you really need it. Bluetooth is slower than a direct USB connection, so if its not too much of an inconvenience, a direct USB connection might work better anyway.
Regardless, here are the instructions I found for installing a Bluetooth device on your laptop:
To install a Bluetooth enabled device:
a. Set up the device so that your computer can find it. To do this, you must:
i. Turn the device on.
ii. Make it discoverable.
b. Click the Start button Picture of the Start button, click Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
c. Click Add, and then follow the instructions.
To install a Bluetooth enabled printer:
a. Open the Add Printer wizard by clicking the Start button, clicking Control Panel, clicking Hardware and Sound, clicking Printers, and then clicking Add a printer.
Good luck.......
Sep 21, 2011 | Amstron Dell Studio 1537 Laptop AC Power...
How do you connect printer to laptop with bluetooth
Hi friend,
follow the given below instructions-
1-Make sure your printer is Bluetooth enabled. Some printers come this way (read the manual to verify) but others require adapters. Shop online or visit an electronics store to find an inexpensive Bluetooth printer adapter.
2-Set up your adapter. All you need do is connect one end to your laptop and the other end to your printer and it will install itself.
3-Turn on the printer. Make sure it is connected to a working electrical outlet and the printer power is on correctly.
4-Open Bluetooth devices on your laptop. After installing your Bluetooth adapter, go to the control panel and open "Bluetooth Devices."
5-Add printer automatically. This is less secure, but easier. From the options tab, make sure the options "Turn discover on" and "Allow Bluetooth devices to connect to this laptop" are checked. Your printer and laptop should then find each other automatically and begin working. If you'd rather not let other devices discover your laptop, follow steps 6 and 7 instead.
6-Add device manually. From the devices tab, select "Add Device" and run the installation wizard to find your printe
7-Use the "Add Printers" wizard. You can also add the printer by clicking "Start" and "Printers and Faxes" and then "Add a Printer." When the wizard pops up, select "Bluetooth printer" and Windows will search for your printer automatically.
please rate me........
Thanks,
Mar 24, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Does the satellite L25-S121 have bluetooth capability?
No, it does not have the bluetooth capabilities.
You can use a USB bluetooth adapter like the following
http://us.kensington.com/html/9403.html
Mar 10, 2010 | Toshiba Satellite L25-S121 Notebook
My Laptop Dosen't Reconize my Canon MF4360 - 4390 Printer
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-11
Jul 31, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Adding Bluetooth
Go to a computer/electronics store. Ask for a Bluetooth USB Adapter , they shouldn't cost more than 10$
May 26, 2009 | Acer Televison & Video
Adding bluetooth to toshiba laptop
Well,I'm not really an expert on Bluetooth, but let me try...
Which version of Windows are you running? If you have Windows XP SP2 or above, the Microsoft Bluetooth stack should be installed on your system. First make sure that the Kensington bluetooth adapter is compatible with the printer and the OS. From what I heard Canon sell a separate Bluetooth adapter for about $80 for this, but I'm not too sure.
Secondly, ensure that the built-in Bluetooth Stack or Software has the required Profile for your printer.
Next, put your printer in "discover" mode (see printer manual for more info ). Use the Bluetooth Connection Utility software that came with the built-in Bluetooth stack to "discover" the printer. Follow the instructions by the Bluetooth stack manufacturer on how to pair and connect Bluetooth devices to your built-in Bluetooth stack.
Please also see THIS article. although it is meant for the Logitech DeNovo keyboard, it can be used for any Bluetooth enabled devices. (Just replace the DeNovo wit your printer in the article.
But mainly, make sure that the Kensington adapter is compatible...
Hope that helps..
IrishDruid
May 04, 2008 | Toshiba Satellite A135 Notebook
How to get a Canon MX310 series Printer working with bluetooth connection
u need a bluteooth adapter dongle, but pick the right one because some dont work.. I have the half moon shaped mini usb dongle, it practically got stuck in the front USB port, but i wiggled it out. It didnt work!! The screen showed 'incompatible camera'.. Im trying some other dongles soon, starting with the kensington 33348 bluetooth adpater. Ill post back with some news soon..
If anyone has any input on this particular device, and which bluetooth dongle is working, please put the info into the Solve this problem box!! Lets go experts!!
Apr 15, 2008 | Office Equipment & Supplies
Bluetooth not found by computer
Hi Bryan,
if you installed the printer by USB, the computer will have installed the drivers for that connection. ( Although USB is Plug and Play ) I,d refer to your user manual regarding bluetooth connectivity, also your printer.
The bluetooth device ( printer ) usually has to transmit signals, to be detected by the Computer. You,ll probably find that if you enable bluetooth on the Laptop. And turn the bluetooth on the Printer ( if Applicable ) by turning on/off or other function ( sync et,c ) the laptop will sense the Printers signal.
Once you have a communication between the two your setup.
I,d suggest unplugging the USB, as the laptops software/hardware, will assume that the printer already has an adequate connection, and will look no further.
Hoipe this resolves your questions regarding Bluetooth Connectivity.
Mike @ compurepair.
Mar 07, 2008 | Canon PIXMA iP90 InkJet Printer
Printing wirelessly to a Canon MP600
1) you need it to print from a laptop if you do not want to have to set up another computer, and mobile phone have bluetooth buit in
2) YES
3) set up the printer on another computer, and set it for sharing. Then make sure that you laptop is recognized in the network connections wizard, then on the laptop select add new printer and select the bullett that say a network printer. the rest is pretty easy, select browse for a printer or something, it is the first option, select it, say yes to all dialogue boxes, and let the computer do the rest.
EASY PEAZY LEMON SQUEAZY
Feb 05, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Toshiba Satellite A135 Notebook Logo
95 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
