Question about Brother HL 5250DN Laser Printer
All LED lights flashing
We have had this printer for less than a year. Our power went out and when it came back on all of the LED lights were flashing. We turned the printer off and unplugged it as well. After waiting a short period of time, we plugged it back it and turned it on and all the LED lights were still flashing. I believe this means that a "service call" is needed, but I wanted to know if there is another solution.
Thanks.
  • bblunt May 09, 2008
    Exactly the same problem and the same cause. Any ideas?
I read somewhere else over the net and the solution I found worked like a charm: just plug it back on and wait about 10-15 minutes.
Posted on May 13, 2008
How do I get the picture back on my LG LED 50 flat screen? Sound works, no picture.
-You have a bad panel. Led arrays internal to the panel are defective. Replacement cost exceeds economical repair.
Apr 27, 2015 | LG Televison & Video
I have been using my Acer Aspire 4520 laptop for four years. Recently while working, it turned off abruptly, and when I tried to restart it, it didn't turn on. Upon pressing the power button to start...
Have you come up with a solution yet? Mine does the same exact thing nothing seems to be helping. I'm at a loss here and I feel helpless, and hopeless!!!
Sep 10, 2011 | Acer Aspire 4520 Notebook PC
Sound but no picture; little red light showing instead of green led power indicator. less than two years old. original owner
Tv LED light indication"LAMP" is flashing or staying on?Yes 2 years old projection lamp and watches tv daily 4 or 5 hours a day?Yes,it is time to replaced the tv projection lamp.
Feb 18, 2011 | Mitsubishi WD 65837 65 in. HDTV
I have a pentair intelliflo 4 x 160. It was running, I turned it off to clean my DE filter, I tryed to start it right after I put the filter back to gether, it turned just a second then the alarm light...
Check the wiring connections, and count how many times the alarm light blinks upon start up. It is probably a loose or broken connection, but the alarm blinks will give us more information to go on if its not.
I install these regularly for 3 years and the only time I saw this incident was when I had a bad connection inside the J-box.
Jan 11, 2011 | Pentair 4-Speed 230v IntelliFlo 4x160...
We Dont Kno!!!
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop power it up then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 02, 2009 | Dell Inspiron 6400 Notebook
Hp desktop wont start
I think you have more than one problem there. Take it to a local PC repair shop and have them check it out. Five years is a good age for a computer though so you may want to think about buying a new one. Best of the Irish Luck to yer.
Sep 16, 2009 | HP Computers & Internet
TV Exploded
Sounds like the DLP lamp failed. You can decipher the Hitachi flashing red light. That should help to be sure.
The DLP lamp replacement is fairly straightforward and can be done with minimal tools
Sep 10, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Replaced drum on Dell 1720dn printer. Where is
This should fix the drum light being on that 1720
Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
May 13, 2009 | Dell 1720dn Laser Printer
OKI c3200n "COMMUNICATION ERROR"
try switch off, unplug, hold up and down & reset button at the back, swith on
Jan 30, 2009 | OKI C3200n Led Printer
Red light flashing while green light stays on
I have the same TV, your projection bulb has quit/failed.
A loud pop was heard and the picture has gone followed by a red led fault light clicking on and off.
if your tv is less than 1 year old, and you registered it with Toshiba, you could qualify for a free replacement.
otherwise expect to pay 200.00 for a new bulb from Toshiba.
only good thing is you can replace it yourself, only tool needed is a phillips screwdriver.
you can check EbaY for prices less than 175.00 to 150.00
i am on my 3rd bulb within 4 years....
good luck!
Aug 19, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Brother HL 5250DN Laser Printer Logo
320 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
