Microsoft LifeCam VX-3000 Web Camera Logo
Posted on Jun 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cam isnt hooked up to monitor
The cam is hooked up to the usb port but it isnt hooked up to the monitor.
Anonymous
Level 3:
  • Master 1,851 Answers
  • Posted on Jun 13, 2010
Anonymous
Master
Level 3:
Answers
1851
Questions
Helped
512982
Points
5186
You will need to install the cam software - open that and choose to film a video.
Hook up to home pc
Today's laptops and desktop computers are more user-friendly. As more people start use computers, operating systems, software and hardware accessories are coming with better instruction manuals and streamlined interfaces. Here are a few basic steps to hook up your computer no matter which brand you bought.
Connect the power cable to the back of the computer tower. The male end of this plug is often on the computer, but it is recessed into the casing. Once this power plug is connected, you don't want to plug it into an outlet until the entire computer is set up. Attach the monitor cables to the back of the monitor and then to the back of the computer tower. This cable will probably be the VGA type, which has a wide set of prongs in the middle and two screws on the outside. Be sure to twist the screws in to ensure the cable has a solid connection. Secure the monitor's power cable to the back of the monitor and then plug it into an outlet or power strip. Attach the mouse to the USB port on the back of your keyboard. The keyboard then plugs into another USB port on the back of the computer tower. Turn on the computer and the monitor.
If the computer powers up but the monitor doesn't display anything, make sure the VGA monitor cable is secured. If the status light on your monitor doesn't turn on, check the power cable connection. Check that the mouse and keyboard work once the computer turns on. Now you can hook up other devices, such as a printer or a web cam. A printer often can connect to a USB port and also may have its own power cable; a web cam usually just plugs into a USB or firewire port.
b>
Webcam does not turn on
that is a very good hypothisis that may be why cam isnt working, try the front usb plugs
2answers
Monintor does not read sd card or usb with inserted on monitor.
you need to connect a usb cable on it and attache the otehr end on the usb port of the comp
3helpful
The monitor has 2 USB ports on the left side of
It is basically 2-port USB powered HUB built into the monitor, did you hook up the USB cable from the monitor USB Input port to the USB port on the PC?
46helpful
Enabling USB ports on Dell monitor
On the back side of the monitor, next to the power connector, you'll find a USB "B" connector (the boxy, square one) You need a USB A-to-B cable to connect your PC to the monitor, not a male-to-male (A-to-A) cable.
Hook that up, and you should get the boo-deep sound from your PC as it adds the new USB hub that's inside the monitor.
If this helps, please be sure to hit the "thumbs-up" button for me!
1helpful
Dell 1704fpt usb ports: how do you find the
you should not need drivers for a usb port is the cable hooked up ? if so they are probably broken
1helpful
All USB ports on my Toshiba A60 laptop are dead
If your laptop isnt recognizing anything hooked up to the usb ports then the mothreboard is bad and needs to be repalced cause its a motherboard issue at that point.
Phillips 32
No. USB doesn't send any images. Its a data line.
That said, I can't see that your TV does have a USB port.
However, the TV does have s-video in which COULD be used to show your PC on the TV. However, it won't look very good. (Certainly not as good as a computer monitor).
2answers
Help me
1:)Do you have installed driver?
2)The green light on webcam working???
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
