Question about Hitachi CP-S860 Multimedia Projector
Reset lamp timer
Please tell me how to reset lamp timer on Hitachi CP-S860WE?
Thank you!
  • 1 more comment
  • Marc B Apr 12, 2008
    There is no menu for the lamp hours or reset.
    It is no written in the instruction manual.
  • prunevet Dec 02, 2008
    I don't understand. I replaced the lamp module, but the "replace Lamp" message still appears, and now the projector turns off after a few minutes. Did I not purchase the proper part? The lamp I replaced was in a framework that slid into the unit. Should the timer reset just by putting the unit in? Should I keep turning it on until that fuse blows? Thank you!
  • mdlemmer Jan 16, 2009
    replaced lamp with new unit the message still appears now what?
Found a solution... hold the reset and left arrow untill message appears on bottom of the screen then release then use arrow button to return timer to 0
Posted on Jan 16, 2009
  • 563 Answers
Hi Marc B
Take out your lamp . on the lamp's bracket you will see a small chip board on the side. The only way you can reset this unit is to either get a new board ( that they don't sell separately ) or to replace the lamp as a whole.
The chip on the side has a fuse that blows only once and then resets the lamp timer.
Posted on Apr 18, 2008
After turning on the projector, I get a message that says clean the filter and reset the timer. How do I do that? I have cleaned the filter.
Procedure for resetting filter time.
Pressing the RESET button for about 3 seconds displays the FILTER TIME menu. Select the RESET using button to reset the timer. : RESET <- CANCEL Selecting the RESET resets the count of the lamp timer to 0. memo Perform this function only when you have cleaned or replaced the air filter. The filter timer counts the used time of the air filter after cleaning or replacement, to display the messages about the air filter. Incorrect performing causes incorrect operation of the messages. memo About caring for the air filter, please refer to the section "Air Filter".
Users manual located here.
Good info deserves a good thumbs up! Thank you!
Mar 01, 2011 | Hitachi CP-X1250 Multimedia Projector
To replace a bulb in the Hitachi CP-S235 LCD Projector, do I just unscrew the two screws under the plate underneath the machine? Are there any precautions I should take, like not handling the bulb? I have...
Yes to replace the lamp you need to remove the 2 screws. You can touch the lamp but I try not to. After the lamp is in you need to reset the hr timer for the lamp. to do this you need to look in manual on page 34.
If you do not have the manual you can get it here at link below.
Good luck
Oct 05, 2009 | Hitachi CP-S235 Multimedia Projector
Hitachi cp-rs55 not working,tic.tic.... noise coming from project
make sure you reset the lamp timer. Manual has the steps. Hitachi Performa CP RS55 3 LCD Projector
if the timer is reset, try cleaning the color wheel. Optoma HD20 Projector Cleaning this video is for an optoma but the color wheel is cleaned the same way in most DLP projectors. Dirty or dusty color wheel sensors cause the projector to shut down and act like its the lamp.
Feb 02, 2018 | Hitachi Performa CP-RS55 Multimedia...
Can't reset lamp timer
Turn on the projector, and reset the lamp timer.
(1) While the projector running, press the MENU button to open the menu.
(2) Choose the “OPTION” on the menu using the / button, then press the
button or ENTER button.
(3) Choose the “LAMP TIME” using the / button, then press and hold the
RESET button for 3 seconds.
(4) Choose the “RESET” using the button.
memo When the lamp has been replaced after
Dec 11, 2008 | Hitachi CP-X1200 Multimedia Projector
Please tell me how to reset lamp timer on Hitachi CP-x960?
After switching on, on the main unit press reset button and left button at same time. After a few seconds text at the very bottom of the display will show something like LAMP (1751). then release and select the same two buttons again, and then again (I think) and the LAMP (0) should appear and it is reset. if this sounds a little vague its because this is what I remember doing as I was trying different things out on my cp-x960.
May 15, 2008 | Office Equipment & Supplies
Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
Hello Wardens wife
What you want to do is go to the advanced menu, find the filter time and using the remote hold down reset button for 3 seconds or so while the filter time is selected. This will bring up a reset menu and reset the timer.
Mar 23, 2008 | Office Equipment & Supplies
Hitachi CP-L850W lamp reset (No Remote)
easy on botem vent unscrew it then u see screw in ther holding balest of the bulb unscrew it litte pull up action on its arm as u will see lift it all out to get new in then reset timer ok
Feb 03, 2008 | Hitachi CP-L850W Multimedia Projector
Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
Oct 19, 2007 | Hitachi CP-X250 Multimedia Projector
Hitachi CP-S860 Multimedia Projector Logo
1,414 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
