posted by Danny Yang on Apr 12, 2008
My friend give the mobo to me. then it works fine with P4 3.0 , two sticks of DDR2 512 MB Ram.But when i change another Power supply adapter (very old), then switch on the power, the onboard LED light was flicking, and i hear some strange sound from the power supply adapter, so i turn off the power immediately, the mobo and the power adapter do not had anything bad smell , but when i use the original power supply adapter , the LED light was still bright but the mobo cant turn on anymore.
P.S. i had tested the CPU (P4 3.0) and two sticks of ram still working fine with ECS mobo. May i have any solution to fix it because the warranty of the mobo is expired. THX...
Best Solution
posted on Apr 23, 2008
Did you try to unplug all AC Power; remove internal surface battery; and then jumper the 'reset' pins from 1-2 to 2-3 ?
Leave in this state for about 5 minutes- then replace battery; re-jumper back to pins 1-2- replace AC power cord.
Sometimes wiping out the BIOS setup information and restarting/re-setting it up will do the trick!
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 12, 2008
There are chances that the old power supply adapter has damaged the capacitors and power circuit of the board got damaged.
Try powering on once again .. if still the problem persists.. there is no way you can fix it.. you might probably need an expert to see to the circuits!
Rating Locked! (?) Danny Yang has rated this solution as Thanks for Trying
Suggest a new solution for this problem
Post a New problem for ASUS P5LD2-VM Motherboard
Email this problem
Email this problem
Can you Help with these Motherboards problems?
P5LD2-VM replaced Power Supply...
now switches off right after... Answer This...
Linspire 6.0 deleted &...
I cannot get my emails and when... Answer This...
Repair Service
Find Motherboard Repairman Near You:
