Question about Sewing Machines
Sewing machine I need a diagram showing where to lube the machinel
  • 3 Answers
Open the needle plate and remove your bobbin casing. Then oil at the movement near the hook and again in the round spot underneath where the bobbin sits. Your owner's manual should have a diagram. If you don't have a manual, search for one online.
Posted on Apr 13, 2008
Bernina 930 record oil diagram
Yes, your Bernina 930 does need regular and thorough cleaning and oiling. Liquid Tri-Flow Synthetic Lube (from the local hardware store or bike shop) is great!
Wiggle the handwheel and apply a drop or two every place where metal rubs against metal. Red arrows below show the oil port locations, but if you miss a couple, you will get them by using the "wiggle" method. Do NOT oil the nylon gears or belt, and STAY AWAY from the basting stitch mechanism in the middle of the needle bar. Be sure to wiggle the stitch selectors and dials and oil those too. There are some very important oil ports on the take-up lever that will require the handwheel to be rotated slowly to see them all. And don't forget a very important oil port behind the bobbin case/hook mechanism next to the machine's metal case. Also, get the feed dog mechanism--a frequent part that seizes without oil.
_930 oiling-midqa4xt2jjuv4lxb4gbt5zn-2-0.png Of course, a drop of oil at the base of the hook every 8 hours of sewing is a necessity to keep your machine sewing happily.
Nov 09, 2017 | Bernina Sewing Machines
Older Emdeko machine. Push power pedal hear motor but wheel not going around or needle going up and down problem?
Probably needs lubrication and a new belt. A good sewing machine shop will have it in stock and may even show you how to oil it. Yes, older machines needed to be oiled regularly!! It's not hard, but there are some 'ports' tha are easily missed. The manual is likely this one, or similar enough.
http://pages.suddenlink.net/maryhwa/emdeko/index.htm
Apr 03, 2017 | Sewing Machines
NEED DIAGRAM FOR THREADING A KENMORE 158.19802 SEWING MACHINE
The threading on these Kenmores is pretty consistent from model to model (good machine, by the way!). Be sure to ALWAYS raise the presser foot when threading the upper thread--insures the thread seats in the tension disk.
14 Kenmore Top Threading FREE SAMPLE
How to thread Sears Kenmore Sewing Machine 158 12270 158
By the way, the metal projection at the top left of the machine regulates the amount of pressure the presser foot applies to the fabric and feed dogs. Push it down to increase the pressure--important when changing types & weights of fabric. To release the pressure, push down on the ring that surrounds the center projection piece. AND, when finished sewing, it is a "great" idea to always release this pressure button before walking away from the machine. Leaving it pushed down over a long period of time will eventually compress the spring and the pressure will no longer work like it should. Also, be sure to clean and oil your older Kenmore regularly. Use only fresh, good quality sewing machine oil or liquid Tri-Flow Synthetic Lube. Open the top, side, and bobbin area. Gently rotate or rock the handwheel and apply only 1-2 drops of oil every place metal rubs against metal. You can also lube the specific lever and dial mechanisms to keep them operating freely. Do NOT oil belts or plastic gears/parts. Doing this regularly, ie every 40-60 hours of sewing time, will keep your machine running smoothly and quietly and preserve the motor from over stress and possible burn-out.
Dec 31, 2016 | Kenmore Sewing Machines
Machine binds up
Seems you need to clean and lube your machine. remove the top and bottom cover cover open the front cover brush out all lint check bobbin for thread lock and lint. lube all moving metal parts with "non petroleum " light oil. Do not lube plastic parts unless there is apparent fiction. " DO NOT USE PETROLEUM BASED LUBRICANT " as it will dissolve or soften plastic parts!
Mar 02, 2015 | Singer 4166 Sewing Machine
How do I thread a mylock 434d
Do you not have your instruction book? It will have the instructions in it. Often there is also a diagram on the front cover flap of the machine. How far away from any sewing machine dealer are you? They should be able to show you how to thread at no cost.Let me kNow how you go.
Jul 01, 2014 | Janome MyLock 634D Mechanical Sewing...
How To Oil A Singer 3810 - Diagram
Singer no longer allows us to oil and grease. You won't find a diagram. Sorry. You'll need to take it in for Lube and adjust.
Oct 25, 2012 | Singer 3810
How to oil my shark sewing machine model 801B
Sorry but you'll not find that information. Home sewing machine manufacturers no longer allow the home users to do their own machine maintenance. And finding any info on Shark machines is next to impossible.
My advice is to take it into to a qualified sewing machine repair guy and ask him to show you how to lube your machine. (you might have to pay extra for this info)
Good luck.
Oct 25, 2012 | Sewing Machines
How to oil a kenmore sewing machine 158.19411
Remove bobbin and presser foot, and tip machine on its side onto a towel. Remove bottom plate w/ screw driver. Oil moving parts with Zoom Sewing Machine oil, one drop, and lube up gears that show dryness with Singer lubricant in tube. One drop oil top of needle bar, one drop on oscillating hook in race shuttle. Jimmy
Apr 06, 2012 | Kenmore Sewing Machines
How to oil my sewing machine
Kenmore machines may have parts and manuals available on searspartsdirect.com -- have the correct model number usually a 3 digit a dot and the rest of the numbers (i.e., 158.xxxx or 385.xxxx1). You will see a list, and if you click on parts or attachments list and scroll down into the parts list, there should be a manual listed as either available or not.
As to the new machines, Euro-Pro or any other, if really cheap, then my personal feeling is that they are planned to not last for a long time -- which may account for the lack of oiling instructions in their manuals. The other possible reason 'may' be that like some Viking Husqvarna machines, the metal parts could be infused with oil and the heat from running them produces the oil needed as it runs. Somehow I doubt that could be the answer in an inexpensive machine. If a lot of the parts inside are plastic, then no oil is needed, and they will run until the plastic breaks, necessitating a trip to the repair shop.
Only use sewing machine oil which can be bought at any JoAnn's, Walmart, sew and vac, or sewing machine dealer. Never use household oil or the yellow/blue can of spray that is a water displacement solution which ultimately will gum up the works. You could use Tri-Flow Superior Lubricant.
Basic oiling procedure is to oil wherever metal parts meet (possible friction points) or slide past each other -- a drop or two usually. No grease needed on plastic gears. If you have an old machine with metal gears, then use sewing machine lube (grease) or Tri-Flow lube (can get it at a bicycle shop if no where else).
Oct 20, 2007 | White Sewing 1300DE Sewing Machine
Sewing Machines Logo
83 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
