I cannot change the screen resolution or the color quality
Screen resolution is at 800x600 and color quality is at 8 bit.
I cannot change it
  • Anonymous Mar 18, 2009
    The screen resolution is at less and i have to move it to more,but i can't. I tried moving it,but it doesn't move. The same goes for color quality,it's at low,but it needs to be at high. what should i do? i need help please!!!!
  • 472 Answers
Make sure your drivers for the video card are installed or installed correctly.
Goto your video cards website and download the latest version from there. The drivers installed by Windows are more a generic version, and extremely trimmed down.
Hope that helps
Posted on Apr 12, 2008
Adjusting pcoutput signal with windows xp
The only 'output signal' you are going to adjust is the video signal.
The only adjustment there is the Screen Resolution, and Screen Quality.
Right-click on an empty area of your desktop screen.
Left-click on Properties at the bottom of the drop-down list.
In the Display Properties window left-click on the Settings tab.
In the middle of the window, and on the left side, is Screen resolution.
Move the Slider to the left to Decrease the resolution.
To the right to Increase the resolution.
(The Slider is the arrow that has a green tip on the top and bottom. Sits on the line in-between Lee and More.
Put your mouse cursor on it, press the left mouse button down, and hold it down.
Now drag the Slider back and forth, by moving the mouse left to right. Set it to the Screen resolution that you desire)
Color quality:
It should state - Highest (32 bit)
If not click on the blue down arrow to the right.
Then click on Highest (32 bit)
After you set the Screen resolution and/or the Color quality, be SURE to go below, and click on Apply.
Then click on OK.
The above not what you had in mind? Post back in a Comment.
Regards,
joecoolvette
Mar 17, 2012 | Computers & Internet
My computer screen has error message Frequency out of range. This happened when running Google Earth, it changed the color quality from 32 bit to 8 bit. When I tried to change the bit back I get this error...
Right click on the free space in the desktop and select properties. Then go to display properties and change settings to 32 Bit and Change the screen resolution to 1024 by 768 Pixels.
Apr 05, 2010 | Gateway GT5220 PC Desktop
Only getting extra large picture
Please right click on your monitor desktop
Click on "Properties"
Click on "Settings"
Look for "Screen Resolution" down at the bottom.
see if the resolution is "1024 by 768"
if not then make it "1024 by 768"
Also check "Color Quality" is set to "Highest (32 bit)"
If not then make it "Highest (32 bit)"
Click apply and screen resolution will be changed.
If it does not change then please check your graphic card drivers.
Cheers
Nov 04, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Monitor lost resolution
itz probably corrupted software/driver or graphic adapter..
try reinstalling the drivers..
but 1st open control panel->display->click on the 'Settings' tab->Color Quality= (Highest) 32 bit; Screen Resolution= 1024x768 pixels (atleast)..
..try contacting ur system admin/vendor....
Oct 27, 2009 | Computers & Internet
Animated resolution and 4 bit color quality
go to the support site for your computer and download the graphics drivers from there then you can switch it
May 27, 2009 | Compaq Evo D300s (269124-051) PC Desktop
Screensize of acer 5670 laptop
Yes the TV could have changed your screen settings (probably to 640X480 resolution).
Go to the Control Panel, then click on Display, then the Settings TAB, then change the Screen Resolution to at least 1024X768 pixels or higher to suit your requirements.
NOTE :- The higher the resolution the smaller Icons and text will be displayed also a lower color quality display ie the best is 32 bit color.
Jan 13, 2009 | Acer Aspire 5670 Notebook
Blurred images on the acer 5315 laptop how to make them clearer permanently and also speed up connection on windows vista for free
Try setting your laptop to a higher resolution. Press Start, go to Control Settings, click Appearance and Themes, choose Change the Screen Resolution, choose screen resolutions of at least 1024x768, and color quality of 32 bit.
Aug 30, 2008 | Acer Computers & Internet
Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Jul 11, 2008 | Acer X193W LCD Monitor
Computers & Internet Logo
583 people viewed this question
David Payne
David Payne
