Question about Acer X193W LCD Monitor
Acer X193W Monitor / screen image
The image appears flattened, stretched and slow to respond. Also, when scrolling down a page, the refreshed image slowly appears as a 'wave' down the screen. Please advise.
  • Anonymous Jul 17, 2008
    same
  • Anonymous Nov 15, 2008
    same
  • 472 Answers
Check your video card drivers are installed correctly.
If unsure, the reinstall them again, it won't hurt the system and there are probably new drivers out for it anyway.
Posted on Apr 12, 2008
Input not supported acer x193w
Hello Shaul
Hints:
1) Change to Plug and Play monitor driver
2) try changing the screen resolution on the PC, and driver.
3) try changing to 60Hz the refresh rate of the monitor on driver section or options on the monitor driver.
Carl
Apr 05, 2016 | Acer X193W LCD Monitor
Hello, I have installed a new 18.5 acer monitor, X193W C but the screen turns blank when I scroll over the task bar. Any suggestions? I have windows xp. Donna
I would check Acer's website in the support section. I suspect you have the wrong driver for your operating system.
Jan 20, 2011 | Acer X193W LCD Monitor
I have a Samsung NC10 notebook hooked up to an Acer x193w monitor and up until today it has been working perfectly. Now the display will not fill the monitor's space. Horizontal is fine but vertically the...
Do you have a spare computer to hook up to the monitor to see if the monitor's settings are off vertically?
Can you adjust the vertical size of the image of the monitor?
Are the letters squashed down vertically?
If the letters are squashed down vertically, did the setting for pixel size of the screen get adjusted to another size accidentally in the control panel under display settings?
Can you reset the Acer monitor from the menu?
Jul 29, 2010 | Acer X193W LCD Monitor
Hi, I am Barbara Acer X193W LCD Monitor. I
If the screen is side ways, it is caused by unintentional pressing Ctrl-Alt plus a left or right arrow.
Restore by pressing Ctrl-Alt plus up arrow
If the screen is upside down
Caused by unintentional pressing Ctrl-Alt plus down arrow.
Aug 23, 2009 | Acer X193W BD 19" Wide 1440x900 LCD...
Acer x193w LCD Monitor repeatedly auto configures.
Here is a link to get the manual:
http://www.acerpanam.com/synapse/data/7117/documents/X193W%20(Qisda)%20user's%20manual.pdf
Starting on page 15 are the directions for the monitor controls. Page 17 indicates a "RESET" feture to Clear the Old-Statuses of "Auto-Configuration". There are quite a number of setting for this monitor.
Jun 11, 2009 | Acer X193W LCD Monitor
My monitor displays images in stetched full screen format
the description you gave was the long way right click on my computer, select properties then device manager, you will be in the same place but lots faster, plug and play does not identify the monitor or its compatible display resolutions, right click on the desktop select properties then display settings, go into advanced tab and look at the monitor, and the adapter, you can play with the setting until you find one that works, 1400 x 900 may not be supported by the video card(adapter) so that may be why your loosing the video settings.
hope this helps.
Mar 15, 2009 | Acer X193W LCD Monitor
Rapid shuddering of icons, pix on Acer X193W monitor (10 mo. old)
in very first you have to check the pc with another display monitor
if display problem still available check the graphic card and video driver. remove the driver and reboot. check display resolution and refresh rate
Apr 12, 2017 | Acer X193W LCD Monitor
Acer P193W monitor stretched image
What service pack of windows xp are you running? Also, do you have your old monitor, if so, then plug it in and see if the same problem occurs. If not , go under the settings for your graphics card (not windows display options) and see if there can be a correction made to the settings for your monitor. Also, try going to microsoft.com and updating your computer (it's free) and you'll probably get the required driver to fix the problem from them. Check under your control panel and see if you have automatic updates turned on, if so you may want to limit what updates are to be installed by allowing updates but you choose which one's to install. Hope I could help. My e-mail
tallcoolone@yahoo.com .
Jan 04, 2009 | Acer X193W LCD Monitor
Windows XP Pro. driver for the acer LCD Monitor X193W
To my knowledge, it is compatible and certainly would work with XP. Since this monitor has both DVI and VGA inputs make is compatible for most video cards or even a built-in video of the PC. If for some reason the Acer X193W would not work with your Windows XP PC, possible reasons are:
  • Screen Resolution and/or Screen refresh Rate of the PC's Display Properties too high, try lowering them down;
  • hardware fault either on the monitor or video card;
  • incorrect/missing drivers of the video card;
  • it is being hooked as a secondary monitor and the dual/twin view is not activated.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Acer X193W LCD Monitor
Acer X193W LCD Monitor Logo
243 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
