Question about GE Spectra JGBP30 Gas Kitchen Range
Oven temp the oven on this range will not maintain temp you have to keep turning up the temp to get it to work. acts like when it reaches temp and shuts down it does not relight. thanks
  • 135 Answers
You could have a weak oven ignitor. If it has a "glowbar" style ignitor they get weak after while and will light once or twice nd then wont be drawing enough energy to open the gas valve on subsequent attempts. You can check only with a clamp on amp meter. If under 3 ampa replace the ignitor.
Posted on Apr 12, 2008
Kenmore wall oven model 911.4088816
i believe this oven was designed to reach a set temp and then interm shutdown to keep that set temp..If oven elements turn back on when temp is raised higher than previous temp ..then there is a good chance its working properly.this is a saftey feature to keep elements on stove from overheating..
Dec 18, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Gas oven dosen't maintain set temperture
My experience on the direct spark ranges is that the gas valve is usually at fault for this problem. The regulator valve and the burner shutoff solenoids are all built together in one valve assembely. The valve will work properly until it gets hot then it will stick and not open when the oven calls for heat again.
Please post back with the complete model and serial numbers if you need further help in troubleshooting it. There have been many updates and design changes on these ranges.
Thanks/Mike
Oct 28, 2007 | KitchenAid KGRS807SSS Gas Kitchen Range
GE profile Spectra gas range/oven is taking approx.20-30 min to preheat. Once it finally reaches temp. it seems to hold at that temp and maintain it. I have noticed occasional puffing sounds when it...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 17, 2011 | Ovens
I have a kenmore self cleaning gas range. For some reason, when I turn on the oven (ie bake), a lot of heat is coming out from the ''exhaust'' between the range and the panel. And the oven inside is not...
this is normal allowable temps are upto 180 degrees
i know it sucks but it is normal for that model
that is as long as your oven reaches and maintains temp
Sep 29, 2009 | Kenmore Kitchen Ranges
GE Xl44 does not reach or maintain setpoint . Display indicates increases of 5 degrees/second, but temp is not reached or maintained.
Have your oven ignitor checked. If they do not get hot enough quick enough the oven will light intermit. Usually when it does light you will often get a scent of gas or a poof. If that's the case, change the ignitor
Sep 11, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Oven does not maintain temp.
It sounds like a thermocouple problem. While using the broiler, you gave the gas set to full and the thermostat is basically out of the loop.
Feb 20, 2009 | Frigidaire FGF316 Gas Kitchen Range
Oven will not maintain temprature
This is a parts problem, I think called the burner ignitor. It is a pn oven part. We have had it in the past and are experiencing it again. We have had our stove for about 15 years, so I guess it is not too bad a problem, but not inexpensive. The oven is letting the gas be off too long between reignitions, so it does not maintain temperature. The first time we realized the probelem was with the Thanksgiving turkey (pink in the joints.)
We had to have the part replaced about 7 years ago and the part was about a $200 part plus service call. I am sure it more costly now. Hopefully you can get yours under warranty.
Dec 01, 2008 | Viking VGSC306-4B Gas Kitchen Range
Amana over
as far as the elementy working, if it glows red, its working. if the unit is preheating within 12-15 min, id say the elements are fine. as far as not maintaining temp, thats strange, if the elemnt turns on the control is sendinding power, and its shuttin off so its stopping power, sounds as if a relay is geting stuck on the control board, strange thngs happen when you short things out like that.
Nov 25, 2008 | Amana ACF4265 Electric Kitchen Range
Open Questions:
See all GE Spectra JGBP30 Gas Kitchen Range Questions
GE Spectra JGBP30 Gas Kitchen Range Logo
224 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
