Question about Dell Inspiron 8200 Notebook
Dell inspiron 8200
I keep getting an error message that says no bootable devices. press f1 to
reboot or f2 for setup utility. please help.
  • CYRINAH Apr 12, 2008
    THIS IS THE LATEST CONDITION FOR THIS LAPTOP
It happens when your laptop does not recognize the hard drive, look in bios as suggested it will say hard drive not found. Sometimes taking hard drive out (remove power and battery 1st) and putting it back in works; otherwise, do os complete reinstall, delete old partition and install windows. Of course you will have to have a good hard drive and boot from cdrom as suggested by prior person-
Posted on Jul 03, 2008
    President:
  • 2,351 Answers
Hi CYRINAH, please make sure you did not leave a CD in your cdrom drive. Go ahead and press F2. This will take you into the notebooks main bios menu. (If you have never been in a bios before, seek guidance from you're manual) or help from a friend who know how to move about in a bios. To find out how to move around in you're bios, instructions are shown at the bottom of the menu.
At the main menu in the bios you will find you're time settings, also you will see reference to you're cdrom (It will be listed & have a name), you should also see you're hard drive, again it will show it's name. If you do not see you're hard drive in the list than you're Primary Master hard drive may be defective. If you do see the Primary Master hard drive listed we need to re-check the boot order. Find, the title, " Boot" within your bios.
The boot order should be,
1st boot device = CDROM drive. (Name of cdrom)
2nd boot device = Hard drive. (Name of hard drive)
If this is not the case (correct it). Save you're changes & exit the bios. If there is no referance to you're hard drive, it may be defective.
If you're Dell still gives you the same error message as before. Than load either you're restore CD or you're Windows CD into your cdrom drive. Re-start the notebook. Allow the notebook to boot to the restore cd or windows cd. As the Dell boots you should see "To load from the CD press any key...."
" Do press any key". Windows or the restore CD should begin to load. You should have the option to re-install windows, (over writing you're current windows). Choose that option - reinstall.
(If windows or the restore CD does not see you're primary hard disk drive), than again it may be defective & you will need to replace it with a new drive. However the hard disk drive may be able to live again. You will need the drive's name written on a sticker on the drive. Once you find the name & serial number you can go to the drive's Mfg's web site & download software to creat a bootable CD with tools utilitys that you burn to a cd drive. This Mfg's software will test & possibly repair the drive allowing you to re-install windows or you're restore cd. Below is the link to you're Dell Inspiron 8200 PC Notebook driver software.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INS_PNT_P4_8200&os=WW1&osl=en&catid=&impid=
To download you're manual, click Manual listed on the left of the page. Bios information found on pg. 119
To find hard drive go to pg. 108
Good Luck! & Take your time.
Have more questions, feel free to ask.
Mike
Posted on Apr 12, 2008
    Problem Solver:
  • 10 Answers
2 Suggested Answers
Agent LaMora
  • 14 Answers
SOURCE: dell inspiron laptop 8200
Sounds like the hard drive failed. If you have any super-important files on there, your local GeekSquad should be able to point you in the right direction to recover those items.
Posted on May 22, 2008
Error code: 1000-0143
I would suspect hdd errors and replace the drive.
Sep 06, 2014 | Dell Computers & Internet
Starting my laptop i get this message internal hard disk not found To resolve this issude . try to reseat the drive "which i did" no bootable devices stike f1 to retry boot , f2 for setup utility...
Hi ajmedina89,
If your system wont boot up and has a no "bootable devices" message, is often caused by a defective harddrive. I recommend to try a different HDD before replacing your system HDD to isolate the issue.
Hope it helps.
Thank you for using FixYa.
Apr 25, 2011 | Dell Inspiron 1545 Notebook
Have a Dell Inspiron 1525 laptop and every now and then it is shut down for no reason with this message on the screen: internal hard disk drive not found To resolve this issue, try to reseat the...
The link below is supplied by Dell, for checking Hard drives on Dell machines, try this.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=126A722713F6D0D0E0401E0A55174AE6
Aug 04, 2010 | Dell Inspiron 1525 Notebook
No Bootable Devices
Hard drive is toast
You will have to change it out and reload the "OS"
Feb 13, 2010 | VIA Bootable IDE Compact Flash Reader for...
Dell inspiron 1300 won't reboot. HELP!!!
Your Hard Drive may have failed. to be sure. enter setup (F2) then run the hard drive diagnostic utility. a scan can take up to an hour or more and will tell you if your hard drive has failed. if it has you will need to replace it and reinstall your operating system
Apr 21, 2009 | Computers & Internet
Windows will not start
try reseating the hard drive. Unscrew two screws on bottom right of laptop, where it IR window is. Slide the cover down, then out. Make sure the bottom connector is flush, then slide it back in
Jun 17, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
No boot device available
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Apr 27, 2008 | Dell Latitude C640 Notebook
Dell inspiron laptop 8200
Apr 12, 2008 | Dell Inspiron 8200 Notebook
Dell Inspiron 8200 Notebook Logo
383 people viewed this question
Alun Cox
