Question about RIM BlackBerry Pearl 8100
Tomtom 500 not been used for a year, charged up,reset, but only the start up screen appears, will not let me go any further, please help, its a tom tom 500
When i entered the site, it said that you would fix the problem for free, how is it now that there is a charge to get advice.
Posted on Apr 13, 2008
Tom sat nav
You will probably find that your internal BATTERY is now well past "its useful lifetime" [around 2 -3 years plus]. The same thing [and symptoms] happened with my 10 year old TOMTOM OneXL.
I was quoted $80.00 [by TT here in Australia] to possibly fix it + the cost of the battery ???
SO I purchased a new TT Via 280 with LIFE-TIME FREE MAPS for just over AU $240.00 ... Works GREAT and better maps as well !!!
Nov 18, 2013 | GPS
Tomtom still charges but traffic receiver stopped working
I'm using the TomTom Go 730T - I think this is the latest and the last TT with Traffic because TT stopped supplying this option. I'm having the same problem from time to time but a reset helps. Just press the Reset button and after restarting the traffic option is back. Janos
Jul 09, 2010 | Tomtom Tom Tom RDS-TMC Traffic Receiver...
TomTom Navigator 6 and HTC Touch Pro 2
Start
Settings
System
External GPS
Programs tab - select COM4
Hardware tab - GPS hardware port = (None), Baud rate = 4800
Access tab - Check the box for "Manage GPS Automatically"
Hit OK
Then open TomTom
Touch the signal bar then the signal bar again
OR
Go to Preferences then Show GPS status
Hit - Configure
Select - Other NMEA GPS receiver
Ensure the baud rate is set at 4800
hit Done
Select COM4:
Feb 16, 2010 | Computers & Internet
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
Tom Tom Go 730
trying to find how to got pin tom tom go 730
Jun 27, 2009 | Tomtom GO 910
Tom tom wont turn on.
turn device over and look for tiny reset button near to power connect strip. then use a blunt safety pin to reset,this should allow you to then turn it on,this works on 500 ,700 ,900 , 510 , 710 , 910 , hope this helps .
Jun 06, 2009 | GPS
Tom tom one not turning on used 3 months
I had some problems with the 920. It started to not turn on. The it just died completely. After opening the case and testing the battery. I concluded the battery was dead and Un-chargable.
Which is most likely the case with yours.
Try this first. Then contact customer support.
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card
Unless you are good with electronics. Then id change the battery myself. I used a cell phone battery.
It has worked for the last year.
Regards and I hope this helped.
James
Sketchlab.com
May 28, 2009 | Tomtom ONE GPS Receiver
Tom tom 500
leave on charge for two hours, then with the SD card out hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
Jan 17, 2008 | Tomtom GO 300 GPS Receiver
Freezing on start up
I have had a aproblem with my digiwalker Mio, which also was freezing up. The only way to sort it is a HARD RESET. The problem in my case appears to be due to the start up program initiating GPS/Tom Tom at the same time. good luck
Aug 28, 2007 | Mitac Mio 168 Pocket PC
Tom tom go 500 wont power up
Press the power button for 15 seconds and your tomtom will turn on with the drum sounds yor tomtom will now reset but nothing will be deleted off it and it will now hope fully work.
Bye
Apr 27, 2007 | Tomtom GO 300 GPS Receiver
RIM BlackBerry  Pearl  8100 Logo
26 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
