The refrigerant line is actually supposed to condensate, but if you mean "freeze up", thats a problem. The condensation occurs because the line temp is lower than the outside temp, kinda like a soda can outside. From what you described, Im pretty sure you are either over or under charged on refrigerant. The reason it will not come back on for a couple of hours is because the compressor is in "protection" mode and has to cool down before coming back on. When you are low or high on refrigerant, the compressor has to work harder which over heats and trips the internal overload switch. Have the unit charged properly and you shouldn't have a problem.
This is return air filter dirty or air not flowing over the evaporator coil do to dirt an debris. Also the reason could be low on refrigerant! Connect hoses only as a last resort once air flow is checked out!
Many times a freezer and/or refrigerator do not work right because of
a dirty condenser coil...there are also many other things that can go
wrong.
If
you are hearing a clicking or buzzing then check out the last two
tips.
If your refrigerator is running but warm, then...
Check
out these tips that I wrote about that... it is a great place to
start trouble shooting your unit...and something that you can do
rather then calling a repair person to do a simple thing for
you...
Refrigerator Condenser
Coil Cleaning
Refrigerator Repair
Refrigerator
Troubleshooting
Refrigerator Compressor
Refrigerator
Compressor
Start Capacitor and Start Relay
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
wrong.
If
tips.
Check
you...
Coil Cleaning
Refrigerator Repair
Refrigerator
Troubleshooting
Refrigerator
Compressor
Refrigerator
heatman101
