Question about HP iPAQ H5450 Pocket PC
Syncronising with pc
I have recently got a gift from my friend a used HP ipaq 5450, but has no installtion disc.
I downloaed the active sync 4.5 version from net
Some times it does get syncronised and some times not
When it does not get syncronised the USB port shows unknown device
with lack of drivers
Kindly help
  • Kevin Jones Apr 29, 2008
    I also got a used h5450 without an install disc and Activesync will not recognize the device. I keep getting an error message that says the USB driver is not installed. Where do I get the install disc?
I have a 5450 , it will recognise and find my wifi but will not connect to it . any ideas , thanks in advance
Posted on Aug 30, 2009
  • 33 Answers
Go on google and download activesync. if you need anymore help email me a dubcars101@yahoo.com... i could also send you a link
Posted on Aug 09, 2009
I cant get wireless on my handheld hp ipaq 2200
change the security settings if any in the wireless router.... use 64bitWEP password for the router and if it is a BELKIN wireless router then WiFi protected setup should be disabled in the roter....
contact router's technical support to do settings in it....
Apr 28, 2010 | HP Computers & Internet
Ipaq h2210 won't sync with desktop
Usually the simplest solution with Microsoft software such as active-sync is to uninstall it and install it again from scratch. When you reinstall it will ask you what programs you want to sync with, your old PIM software has been lowered in priority in favour of Outlook because MS think everyone should want to use it, so it's often easier to start using Outlook as your main PIM.
Aug 13, 2007 | HP iPAQ H2210 Pocket PC
How do I enter data through my PC to my iPAQ 2210
You have to check the synchronization settings. Select " Keep data on my pc" rather "keep data on my devce " fo rthat matter.
Sep 10, 2009 | HP iPAQ H1940 Pocket PC
Ipaq 4700 active sync problems
i can try to help you , first are you using xp or vista ? and which version of active sync ? i found that after upgrading to active sync v4.5 my ipaq 4700 refused to sync , i have xp home , so by trial and error i learned several things , i tryed my usb cable in every usb slot i had , only to find some usb ports are more friendly to certain devices , for a lack of better terms , i deleted all partnerships in active sync , found that i needed to make sure active sync is not running on ipaq , go to settings / memory / running programs on the ipaq , stop all running programs , turn the ipaq off , then on the pc made sure firewall not locked , plug usb cable into pc , i leave mine in a port permanently , plug into the ipaq , it automatically turns the ipaq on , then i see 2 icons in pc system subtray start blinking , at that point i know sync is going to work , then active sync icon starts turning , lit up in green , and asks do you want to create a partnership , yes , follow prompts , and thats what has been working for me , now if i was to put the usb cable into a different port , no doubt it would give me grief , and the same thing with my phone and active sync , make sure active sync is not running on the device , sometimes i have to reset the unit , ipaq or phone , make sure unit is turned off them make the connection , give it a try .
Jan 02, 2009 | Computers & Internet
HP Ipaq h5550 does not connect through cradle
First sorry for my bad english.I have a same PDA (acually its dead :-( ) And me too had this problem.Try moving a little bit your pda on cardle, or (this looks like crazy but actually worked for me) do not fully put in the cardle into pda.I mean dont stick in into cardle, just a little bit.
Jun 30, 2008 | HP iPAQ H5550 Pocket PC
Does the ipaq 2215 work with Outlook 2002?
Active Sync will work with many version of outlook. Your PDA interfaces with Active Sync. Certain versions of Windows Mobile software and/or PDA's require higher versions of active sync to sync correctly.
Sep 12, 2005 | HP iPAQ H2215 Pocket PC
Syncronisation problem
I have managed to sort it by doing a soft reset.
Sep 12, 2005 | HP iPAQ H1930 Pocket PC
Sync Problems
Reinstalled Active Sync and Outlook.
Sep 11, 2005 | HP iPAQ RX3715 Pocket PC
Reinstallation of app onto iPAQ upon hard reset
In activesync under Tools/Add REmove programs you can check the box and click "ok" that will install the program. For the most part it's best to do it one program at a time. Obviously your PDA should be cradled or this. Most programs will re-install fine this way. Some programs though do require you to re-install from the installtion program directly since active sync doesn't pick up some important parts of the program. The two programs I have that require the special install are: CLC Journal since it has an outlook component and sets up a sync for the Outlook Journal. The Stowaway Keyboard driver since it had to ask me what language (the new driver doesn't do this...) The other 30 odd programs I have install straight from active sync.
Sep 11, 2005 | HP iPAQ HX2110 Pocket PC
IPAQ 1715 not recognized
All you should need is Activesync. Try the following... From your PC .......... with IPAQ cradled click on Start, Control Panel Double-click on System Click on Hardware, then Device Manager Click on '+' to left of Universal Serial Bus Controllers Click on '+' to left of Windows CE USB Devices Right Click on HP USB Sync Select 'Uninstall' Uncradle IPAQ Reboot PC
Sep 08, 2005 | HP iPAQ RZ1715 Pocket PC
HP iPAQ H5450 Pocket PC Logo
167 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
