Question about ASUS P4S800D-X Motherboard
Sage line50 on asus ee pc
I would like to know how to install sage line 50 on my asus. I have tried but haven't really got anywhere so far. Also I am not the most technical person around....
    President:
  • 2,351 Answers
Saga is software, you load it into you're cdrom & it will install.
If you're asking how to setup the Saga software? I suggest you go to Saga's web site. Click the link below.
http://www.sage.co.uk/productsandservices/home.aspx?tid=131865&stid=131870
I am sure you're Asus can handel running Saga's software.
Mike
Posted on Apr 13, 2008
  • Mike Peluso
    Mike Peluso Apr 14, 2008
    How to vote you're expert.
    Also how to repost more questions.
    Enter FixYa.com site.
    Sign in to your FixYa account.
    Locate My Profile on our FixYa's homepage.
    Under My Problem locate your problem and click on it.
    Under the solution given by the expert, choose.
I can not install sage line 50 11 verson. please help me
Hi charuka, try going into control panel and delete all things sage then restart, reinstall, restart = play. Best of luck, Greg.
Dec 20, 2014 | Microsoft Windows 7 Ultimate for PC
Trying to install windows 7 from flashdrive and get as far as "no driver for hard drive" to install OS and one can't be found anywhere on line. All I need is the driver and I'm home free. I
I had a look at the specifications of your computer and it might not meet the requirements to install windows 7
If your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7 http://windows.microsoft.com/en-AU/windows7/products/system-requirements hope this helps
Jan 10, 2013 | ASUS Eee PC 900 Notebook
Hi all I am gettig the following with my sage line 50 v7 'sage report says unable to connect to data sourc, check configuration' I then get a system error coded 2 Its on windows 98 Can anyone...
Try removing Microsoft.net framework 3.5 sp1 from add remove programmes has known conflict with sage. If this does not work then try removing the .net framwork 3.0
Oct 05, 2010 | Sage Instant Financial Suite v8.0 CD Win...
Sage sbd platform installation update has stopped working
To download the Sage SBD Desktop Installer Utility (Build 111)
Access the Updates page on the Sage website: http://www.sage.co.uk/support > Downloads > Updates.
Note: You must log in to view this page. To do this, click Log in, enter your email address and password for the Sage website, then click Log in.
From the drop-down list, choose Line 50 & Sage 50 Accounts then click Go.
Locate the Sage SBD Desktop Installer Utility (Build 111) then click Download.
From the File Download window, make a note of the file name, for example, sbddesktopbuild111.exe, then click Save.
From the Save As window, browse to the required destination, for example, your Windows desktop, then click Save.
The Download window appears showing the progress of the download and the estimated time to complete.
Once the download is complete, if required, click Close.
You have now successfully downloaded the Sage SBD Desktop Installer Utility (Build 111). For instructions on how to install this, click the Install it tab.
Mar 23, 2010 | Computers & Internet
I have just upgraded to sage line 50 accounts professional, yet when i try to run it it tells me the data file could not be found.my data is held on another networked computer and i can see that the path...
Hi allweatherra
Sage 50 has a file called company. that holds the path to the sage Data. From version 2007 onwards this is held in c:\documents and settings\all users\application data\sage\accounts\2010(or whatever version you have)
Hope this helps
Feb 10, 2010 | Sage Instant Accounts 8.0 (013604ug)
Email Remittances - Report Designer Problem
Sage Line 50 Addpurch Utility
In Sage Line 50 V5, you could only produce remittances for the
supplier accounts you had set up in your Sage Line 50 program.
The information that appeared on your remittances was taken
from the supplier ledger.
In newer versions of Sage Line 50 you can produce remittances for suppliers
who do not have a corresponding supplier record. This allows
you to produce free-format cheques for one-off payments. To
enable you to produce free-format cheques, Sage Line 50 no
longer takes the information for remittances from the supplier
ledger. This means that you can produce remittances whether
there is a corresponding supplier record or not.
If you want to include additional information from your
supplier records on your remittances, for example bank sort
codes and account numbers, you should convert the layouts
you require using this utility.
Note: This utility is installed automatically into your
Sage Line 50 program directory when you install Sage
Line 50.
>> To use the Addpurch utility
1. Open a Command Prompt by clicking on to your Windows Start Button
selecting Run, then type the word COMMAND and click on to OK.
From the command prompt (for example, c:\windows\desktop>) type cd\ and
then press ENTER.
2. At the c:\> prompt type cd "Program Files\Sage Accounts\layouts"
and then press ENTER.
The prompt should now read c:\Program Files\Sage\Accounts\layouts
Note: If your Sage Line 50 program is installed in a different
directory replace the above instruction with your own directory
name. The directory path can be found within your program by
clicking on to Help and then About and choosing the System
Information Tab. Your layouts will be held on the same path
as your data directory.
3. Before you can convert your remittance layout you will
need to save this with a new filename. (maximum of 8 characters).
For example, to rename one of your existing layouts from
the c:\Program Files\Sage\Accounts\layouts prompt type:
copy remita4.sly newrema4.sly
Jul 07, 2009 | Sage Computers & Internet
Invalid Path error
I get this error when trying to run Financial reports in Sage line 50 financial controller verson 10: C:\PROGRAM FILES\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid path No matter what financial report I try to access I get the same error including audit trail. My computer is window Vista. Please help me and also let me know how much is it cost for on line chat?
Thank you
from selvi
Apr 14, 2009 | Sage Instant Accounts 8.0 (013604ug)
Sage LIne50 2008 and Vista
Run the program using administration rights,,
Right click on the exe and choos run as administrator
Dec 14, 2007 | Computers & Internet
ASUS P4S800D-X Motherboard Logo
76 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
