Philips VR550 VHS VCR
Problem for Philips VR550 VHS VCR
Can't record Freeview
By Bashstkid2 on Apr 12, 2008
I have worked out how watch Freeview via the video, but cannot record freeview. It just records the 5 main channels. I have 2 scart connections on the TV (which I'm using.
Help Please?
Comments:
Apr 12, 2008
- Yes I have it connected that way via the Scart. As I said I can recieve Freeview but the recorder is not picking it up when ask to record? Is there some other setting I'm missing?
also "If you are using scart socket AV2 (DECODER), Select programme number 0.0.2." ??
Apr 13, 2008
- I do have it on AV2, which I can watch the Freeview channels Mark but why isn't the video picking it up on record? I hope you can bear with me Mark. Here is the Handbook.
http://www.p4c.philips.com/files/v/vr550_07/vr550_07_dfu_eng.pdf
Apr 13, 2008
- The TV is a Ferguson FTD2100T
The Freeview is Matsui DTR1.
Thanks again Mark.
Apr 14, 2008
- Mark It's done! It was that 0.0.2.! After I did all you said i had a feeling it must be a setting up problem. As I said this 0.0.2. bit was confusing. In my opinion the handset is too fussy. I didn't realise that the 'TV-Prog' on the handset is seperate from the numbers. The TV-Prog buttons just adjust the channels on the TV NOT on the Video. I pressed 0.0.2. straight after trying the TV-Prog buttons and nothing happened because (I presume) inwas still in TV mode. When I tried it after Eureka. Thanks Mark.
You might like to have a go at my other similar problem with my DVD Recorder.
http://www.fixya.com/support/t501053-crown_cdvdrw300_dvd_recorder
Thanks Anyway.
Roy
Best Solution
posted on Apr 12, 2008
Very Helpful)
Mark_Webber
Rank: Wiz
Rating: 85%, 383 votes
You should have the Freeview box connected to the VCR, then the VCR to the TV
Hope that helps =)
Comments:
Apr 12, 2008
- If you have Freeview connected to the AV2 port on the VCR, then you would have to select AV2 to see it.
If this is connected as I suspect then you should not have to change any channels on the TV to watch inputs from either the VCR or Freeview (aside from changing the TV to AV or whatever when you first turn it on)
Program 002 should be a normal TV channel, not an AV input. If your remote for the VCR only has one AV button, then pressing it multiple times should cycle through the AV inputs.
Apr 13, 2008
- I see the 002 reference now. There is one thing that is still miffing me though is you say in the original question that you have 2 scart connetions to the TV and you are using both of them.
Can you send the model numbers for the TV and the freeview box along as well so I can get all 3 manuals. As far as I can figure you have it correct and there is no reason for it to be acting like this.
  1. Aerial from socket to Freeview input, Loop cable from Freeview to VCR input for normal channel viewing (non digital)
  2. Freeview Scart out to VCR Scart2 (AV2)
  3. VCR1 to TV scart input.
That is all that should be required with the addition of setting the VCR to AV2 to set the input.
Apr 14, 2008
- LOL, glad it's working.. I was starting to run the wiring pattern over in my sleep =)
Was this helpful?
Yes
No
Popular Solutions for Philips VR550 VHS VCR
Questions and Unsolved Problems for Philips VR550 VHS VCR
Do you recommend Philips VR550 VHS VCR?
Answer
Answer
trying to tune it into our digital television and it seem to find random channels,both digital and... (More)
Answer
I have misplaced the set up manual Is there a website that can give this to me. I can play tapes... (More)
Answer
We've tried cleaning, new tapes etc but jumps badly on playback and sometimes ejects with tape still... (More)
Answer
my vcr keeps shutting down and spitting out the tape. It also reads that there is no tape left even... (More)
Answer
My Philips VR550 has suddenly started recording colour images in black and white. What has happened?... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top VCRs Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
