Question about Refrigerators
Fridge not cold. freezer frosting up. fridge running all the time . Something sounds like it is trying to start but it will not start
  • 135 Answers
If you are getting a hum for about 5-10 seconds followed by a click, tht is the compressor short cycling. You may have a bad compressor relay, or the compressor itself could be bad. If the frost your seeing is on the back wall of the fredezer that could indicate a defrost problem.
Posted on Apr 12, 2008
I have an amana bottom freezer fridge. 3 years ago ,y freezer was frosting inside and the fridge temp was not getting cold enought. a repaiman replaced the thermostat. now the freezer is beginning to...
To fix up a frosted up vents, I had a control board replaced for $180. Then 6 months later, the bottom freezer frost up AGAIN. rather than dumping more money to fix it, I was about to buy a new fridge, but had a crazy idea: I disconnected the water to the freezer, bought plastic trays for ice cubes for $3 at walmart. Fridge has worked like a charm for 6 months. no signs of frost. Saved $1000's.
Dec 12, 2011 | Amana ABB1927DE Bottom Freezer...
My freezer and fridge shows signs of frost and it is running (seems loud) all of the time. I had a problem with the fridge not staying cold enough, but now there is frost.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 13, 2011 | KitchenAid KSRS25IL Side by Side...
We have a Kenmore Fridge. The freezer will not freeze anymore but the fridge works fine. We did unplug the fridge and let it sit for 24 hours to see if that would help the freezer to work again. it...
IT'S FUNNY THAT THE FRIDGE SIDE IS WORKING AND THE FREEZER ISN'T,ALL THE MACHINE DOES IS GET COLD IN THE FREEZER AND THE EVAP FAN BLOWS COLD AIR FROM THE FREEZER TO THE FRIGE SECTION.IF THE FRIDGE IS COLD AND THE FREEZER IS RUNNING WARMER THAN IT SHOULD YOU COULD HAVE A SEALED SYSTEM PROBLEM,SOMETHING WGONG WITH THE COMPRESSOR OR A LEAK IN THE SYSTEM.THE GAS WILL CONTINUE TO LEAK AND THEN BOTH SIDES WILL GET WARMER AND WARMER.YOU CAN REMOVE THE INSIDE FREEZER WALL,LOOK AT THE EVAP COIL AND CHECK THE FROST PATTERN ON IT,WHEN IT'S RUNNING CORRECTLY THE WHOLE COIL WILL FROST UP BUT IN YOUR CASE YOU'LL MOST LIKELY FIND THE COIL PARSIALLY FROSTED OR JUST THE TOP OF THE COIL WILL HAVE ICE ON IT,THAT MEANS NEW FRIDGE TIME,IT WOULD BE TO MUCH MONEY TO REPAIR IT.LET ME KNOW WHAT YOU FIND WHEN YOU LOOK AT THE COIL AND WE CAN GO FROM THERE
Nov 23, 2010 | Kenmore 14.8 cu. ft. Top Freezer...
Fridge/freezer running, but not blowing cold air
sounds like compressor has failed remove the fridge and put your hand on the black unit at the back (compressor) it should be quite warm if running if not its not starting compressor are at there most stress when starting up and if failing this defrost may have killed it completely
Nov 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Freezer is not freezing its cold like the fridge but thats it. tha fridge is running
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Refrigerators
Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Dec 22, 2008 | Frigidaire FRT18FS6C Top Freezer...
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge & freezer no longer cold
if you only removed the ice you can see without removing the back panel then you need more defrost time yes. but the frost will come back, something in the defrost system has failed. so the answer is yes to both questions off for longer and something more serious too.
Apr 06, 2008 | Freezers
Fridge running but not staying cold
you have a defrost problem, if SxS ref. most likely bad defrost heaters. They are behind interior back wall. Sounds like you have a GE.
Jan 05, 2008 | Refrigerators
Refrigerators Logo
141 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
