Unable to get chart software(Memory-Map) to connect with integral GPS
My Mio P550 runs TomTom correctly- TT is connected to GPS via Com2
But Memory-Map chart software will not connect with GPS, either using Com2 or(as MM makers say using the hardware port Com4).
Any suggestions please?
  • 9 more comments
  • pobble Apr 12, 2008
    hadn't considered that possibility.
    M-M comes on CD which I've downloaded to the PDA (blank) SD card, so I suppose it could be that the card I bought for this purpose is faulty or incorrectly formatted?- I'll try another and see what happens
    I've now reloaded the MM charts onto a new 2Gb Kingston SD card ( same brand as before but different batch).
    The software still shows 'Unable to open COM port', so it seems unlikely that the storage card is at fault
    Having reloaded the chart software onto a new SD card, the 'Unable to open COM port' legend pops up on screen
    Replace the PDA?
    Thanks for the various further comments.
    The Mio P550 is known to be compatible with Memory Map- it was recommended by others who use it with that software.
    It is also known that Tom Tom and Memory Map use different COM ports and I have previously uninstalled TomTom and still couldn't run Memory Map.
    Memory Map makers say that COM2 Program and COM4 Hardware(connect MM to this one) are the correct settings but not for me it seems.
    replacing the PDA is simply not an option- this is the second PDA I've tried with similar lack of success.
    Interestingly I am also struggling to get MM to work using a laptop- and serial port(COPM1) connector with a handheld Garmin GPS.screen displays 'Unable to open COM port: error 5
    In conclusion I reckon this software, for me at least, is a waste of time and a lot of money too, so it's probably time to move on and forget the idea.
    Thanks for your thoughts and efforts though
    I must treat this a lost cause
    I'm using TT5(which is not a supported product-TT6) and MM 2004 BUT the makers told me to use COM4(hardware)port. If I try COM2 I then get 'No GPS'
    I don't run the two programs together and as i said I've previously uninstalled TT and still could not connect MM with the GPS
    Baud rate is 4800
    I don't have access to any other MM version
  • pobble Apr 13, 2008
    M-M OS Edition Version 5
    Vewrsion 5.1.3, Build 716
    Copyright 2005
    But shouldn't MM work if, as I did, I removed TT5 completely from the device?
    By the way I cannot remove TT again as I don't have the product code and last time it took over two weeks of effort to get that programme up and running again- I can't face a repeat!
    Don't see any options for PDA Comm 4 driver and MM updates have been checked- however you may well be right since I'm having trouble getting the MM programme to work with GPS on this PDA and a clean, reformatted laptop too.
    Maybe an idea to flag this as an issue with MM makers
  • pobble Apr 20, 2008
    Apologies for this late response but, after much ado the MM manufacturers now tell me that the COM" port is the correct one and having sent them a data txt. file from the PDA they are confident that it will work.
    However, I've done a very silly thing, in that it was so slow and to be sure to get a good signal I left it out on the patio for a couple of hours, but then forgot about it and it rained overnight.
    Now I've got a dead P550 -problem solved!!!
  • 4,889 Answers
Can you tell me which MM version you were using before so that we can atleast get it working.. And yes it is possible that your TOM TOM cannot connect through COM PORT 4 which is the cause of the problem
Posted on Apr 12, 2008
  • eagle338
    eagle338 Apr 20, 2008
    Damn.. thats bad..!
    Scholar:
  • 170 Answers
Works seamlessly with TT6 and Memory map 2004
what version memory map are you using?
Mitac Mio P550
Manufacturer: NMEA
Model: N/A
Port: COM2
Baud: 4800
is your baud set to 4800?
Also have you restarted and without running tt, try memory map.
  • Scott Henderson
    Scott Henderson Apr 13, 2008
    I'm sure you can tell what port to use. did you try a lower bit rate? maybe there are some settings to try in the com4 driver. but if your other program works with it, then it sounds like a software problem.
    maybe you need an update to get it to work correctly.
  • Scott Henderson
    Scott Henderson Apr 21, 2008
    LMAO!!!!
    President:
  • 1,944 Answers
Did you try other versions of the MM software?
  • 472 Answers
It is possible that the software is not compatible with the GPS reciever you are using. A visit to your local hiking/off road store etc maybe able to plug another type of GPS unit into your PDA with a different chipset in it.
Just a thought =)
  • Peter Thompson
    Peter Thompson Apr 20, 2008
    I prefer the gentle touch of a large sledge hammer to correct issues.. Water just dosn't do it for me =)
  • 156 Answers
The card is not the problem here.... in most occasions Tomtom and memory map seem not to coincide in their operations... these are due to usage of ports... so replacing card will not help.. Try to install them seperately and see if they both work that way
If they work you can atleast make sure that card has no probs
  • 3,037 Answers
Yes I would replace the PDA or take it and the software to a dealer and have them put it on for you and see if they get the same problem
Please update me on the situation
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri Apr 12, 2008
    take it to a dealer and have them get the software working, wherever you bought it, have them service it
  • Benjamin Patri
    Benjamin Patri Apr 13, 2008
    Have you tried getting a dealer to get it working for you? They should help you out especially since everything that you tried still hasn't done anything. Let me know what the dealer says.
  • Benjamin Patri
    Benjamin Patri Apr 20, 2008
    Is there anything else I can do to help you?
    If not, please have a good day don't forget to rerate this solution
  • Benjamin Patri
    Sorry to hear that, is there anything else that we can do to help you out with this problem?
    Genius:
  • 3,422 Answers
The only way to fix this problem is to get it replaced..
  • Priya darshan Apr 12, 2008
    I suggest you again to replace it.
  • 19,396 Answers
If memory map card is new ask replacement , it may be faulty
  • 1 more comment
  • Ginko
    Ginko Apr 12, 2008
    When I told you about a possible bad map card I was refferring to a bad map file inside, not a bad media support. If the card is faulty usually you cannot even open it. If the file is bad, even copying won't resolve the cable. If you have an old map file, or a map file on a different sd, try it opt, if it works, then is the file.
    Before deciding to replace or bring the devices to service you should pass through several steps.
    First try an elementary hard reset by pulling out battery (with device not connected to charger/adapter).
    After this a System reinstall on PDA may solve the problem.
    To troubleshoot further I need find more info on your devices system software, I will come back to you within next 24 hours.
    In meanwhile, if any of the above worked, remember to accept my solution.
  • Ginko
    Ginko Apr 12, 2008
    I just forgot, if it is the software in the card, just get the map software replaced.
  • Ginko
    Ginko Apr 12, 2008
    Try the following reset procedure:
    1. Press the joystick up, while pressing the soft-reset button.
    or
    2. Turn off the device on the switch next to the soft-reset button.
    Press the joystick up, while turning on the again.
    Release the joystick when device gets to the MIO splash screen.
TomTom stuck on homescreen
Connect TT to PC, open it by Explorer, create a new map, copy all data from TT to the new map, format the device, disconnect it from PC. Download and install TomTom Home program, install it, connect TT thru the program, make all installations that the program requires, close TTHome, open the device thru explorer, copy from the saved files the map containing the maps and the Voices map. Thos will take around 30 minutes. Then disconnect the TT, Power on, wait 5 minutes, power off and power on again. That's it.
May 15, 2011 | Tomtom ONE 3rd Edition GPS
MIO P550
oprn that folder and there you find the licence detail and fill in the licence detail and then turn off and turn on device and it will be done.
Dec 05, 2007 | Mitac Mio P550 GPS Receiver
I have a Mio P550 with Tom tom 6 installed, when I try to run Tom Tom all I keep getting is no valid GPS
Hi Dave,
First off, go to your GPS settings. Make the GPR Program Port: COM4. In the Hardware tab, make the GPS Hardware Port COM2 and the Baud Rate 4800. In Access, have the Manage GPS Automatically checked.
Download the VisualGPSce freeware program from this site install and run it. Make sure you're outside (sorry), you should see the to bars filling and after a while the red light in the bottom corner will turn green meaning you have a lock.
Hopefully now when you turn TomTom on, you will have your position shown. I always need to start VisualGPSce before kciking TomTom off.
Jul 07, 2010 | Mitac Mio P550 GPS Receiver
I formatted my p550 and I don't know how to bootup or reinstall the O/S
You'll need to find the firmware (ROM) image file (Google) and then: Connect the mio p550 to PC
1.put the Button of the PDA in ON position
2. hold the joystick downward and press the reset button
3.choose "Image Upgrade tools"
4.choose "0=Image by USB"
5.intall the usb driver (PC require the drivers). The driver in the
folder "USB driver"
6.open the software "dnw5.0e"
7.(if you want to make a test of connection USB, click the" USB
port/Statute". If all is ok go to step 8
8. click "USB port/transmitted" and to show the way of the file
"MioP550 - Osc260A R05_P09.nb0"
9.press the reset button to restart the mio p550.
Feb 22, 2010 | Mitac Mio P550 GPS Receiver
Flashing X on TomTom but cant get it off on spotlight on my mac!
Make a full backup onto your computer making sure all files are shown. Do not use tt home. Make sure you have a copy of your map in your backup. Do not format. Delete everything on your tt. Connect to tt home and tt home will reinstall the navcore for your device. Copy and paste your map from your backup onto your tt. You should be set to go. A reminder you will lose all your preferances and favorites when you do this.
May 31, 2009 | Tomtom ONE GPS Receiver
Mio p550 wireless N security connectivity problem
Had the same issue with my Mio P550's using an Airlink680W Wireless N Router and security mode WPA-PSK, TKIP & Password. I had to disable "Block WAN Ping" on the firewall and life is good.
BSL
Oct 03, 2008 | Mitac Mio P550 GPS Receiver
Mio P550 reboots but does not take any touchscreen inputs
I had the same and contacted MIO (use the phone number for your country,
http://www.mio-tech.be/EN/support/support-overview.php
). It was related to the shock the screen got and they graciously changed it for me (it was during the second year of the warranty). If the warranty has expired, you are probably looking to about a hundred bucks expense.
Courage,
Jul 02, 2008 | Mitac Mio P550 GPS Receiver
TT Home does not recognise connection
You definitely need software and maps on an SD card. The TOMTOM will not work without a card inserted. The card will contain MAPS , Map authorisation codes ( to show they are genuine TOMTOM maps bought and paid for ) , POI ( points of interest ), GPS fix data , voices ( for spoken navigation ) etc etc etc. ....................
PLEASE NOTE , TRYING A CARD FROM ANOTHER TOMTOM is very unlikely to work. Each card has an authorisation code that is generated via an algorithm inside each TOMTOM and is device specific.
However , trying a card from another tomtom might produce a diferrent result but still not work , at least this might prove that the tomtom is working OK before you rush out and buy a tomtom card.
Feb 02, 2008 | Tomtom ONE GPS Receiver
Problem with gps not connecting.
I have Google maps for Mobile working on Mio P550 with GPS Program Port: COM9.
GPS Hardware Port to COM2, baud rate 4800.
http://blogs.msdn.com/windowsmobile/archive/2006/06/07/620387.aspx
Dec 24, 2007 | GPS
Mio p550 USB devise not recognized.
Try a other usb cable had same problem new cable fixed it of other device
Nov 09, 2007 | Mitac Mio P550 GPS Receiver
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
