Question about Kyocera Mita FS 3800 Laser Printer
Installing a kyocera fs 3830n printer on applemac
I have been given this laser printer and downloaded the drivers yet I still cannot get it to print a single test sheet. When i o to print the printer is illustrated but prints out 3 pages of what looks like numeric data. any advice would be welcomed.
    Problem Solver:
  • 6 Answers
See if this is set to pcl6, make take care of it.
(from manual)
Changing the Emulation
To change the emulation mode, proceed as follows:
1 Press the MENU key.
2 Press the or key repeatedly until Emulation appears. One of
the emulation modes shown below appears, indicating the current
emulation.
PCL 6 (default)
KPDL
KPDL (AUTO)
Line Printer
IBM Proprinter
DIABLO 630
EPSON LQ-850
KPDL is the Kyocera’s implementation of the PostScript page
description language.
3 Press the ENTER key. A blinking question mark (?) appears.
4 Press the or key repeatedly until the desired emulation mode
appears.
5 Press the ENTER key.
6 Press the MENU key. The message display returns to Ready.
Posted on Apr 17, 2008
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
Where is the waste toner box on the Kyocera FS-3830N printer?
facing prnter look on left side. midway of side panal theres a door. push tab on door to the rear of printer a bit and door should open. depress plastic tab on neck of toner coleection bottle and pull out full bottle. replace or empty an dreinstall and cloe door. should reset and restart to ready condition.
Feb 07, 2011 | Kyocera Mita FS-3830N Laser Printer
Mac OS10 print driver for Kyocera FS 3830N
Go to kyocera's website to download, ckick this link and it will take you to the driver you need.
OS 9
OS 10.2 and 10.3
OS 10.4 and 10.5
List of other drivers for this model printer.
Jan 08, 2011 | Kyocera Mita FS-3830N Laser Printer
Printer kyocera 3830n will not print..display reads clean tonner waste bottle..i have emptied it and also cleaned it
Try to reset the printer.
Factory reset on Kyocera FS-3800 printer:
Connect the printer via paralell and type the following in at the command prompt:
ECHO !R! FRPO INIT; EXIT;
Aug 25, 2010 | Kyocera Mita FS-3830N Laser Printer
Kyocera fs-3830 cutting off print on top of page
check the margin settings and outline settings because minor things worries us too much
May 01, 2009 | Kyocera Mita FS-3830N Laser Printer
My Kyocera FS-3830N isn't printing certain letters
Updating the driver will solve your problem. Go the Kyocera web page and look under legacy printers in the download area
Jan 21, 2009 | Kyocera FS-3830N Laser Printer
KYOCERA FS-1900 ERROR MESSAGE CALL SERVICE 2000:0137037
the 2000 part relates to a laser unit problem the other numbers are the print count.
You will need to have this serviced by a tech and if you are a tech you will need to order a new laser unit
Dec 21, 2008 | Kyocera Mita FS-3830N Laser Printer
Kyocera FS-3830 with error F030
Try www.kyocera.com and look around for links to software upgrades.
Nov 30, 2008 | Kyocera Mita FS-3830N Laser Printer
Kyocera Error
Signifies comunication error between mainboard and engine.
Only hope would be check and reinstall printers firmware via flash card in side socket.
Check connections on the boards.
Replace main board.
Error is stated as for F040: the .0183044 is just page count.. no match for just 040 in service manual.
Cheers
Jan 03, 2008 | Kyocera Mita FS-3830N Laser Printer
Kyocera Mita FS 3800 Laser Printer Logo
241 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Henry Gertcher
Soulvisitor
Soulvisitor
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
