Question about Olevia 237T 37 in. LCD TV
Factory reset was reset---now we have a no signal on the screen
  • 10,594 Answers
Please go to tuning menu and select Auto Scan/ Auto Tuning to tune all available channels to store in tv memory.
Factory reset actually delete all data/ settings in memory chip and set tv as it was in-box.
Thanks.
Posted on Jun 13, 2010
  • dklacampbell Apr 23, 2011
    What if it won't tune after that?
SOURCE:
Seiki TV randomly goes black then to a blue screen says not support or no signal. Whatever is playing continues. If I turn the TV off then back on it goes right back to whatiwas watching.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory ResetF (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jul 24, 2016 | Seiki Televison & Video
I have astron tv 14 inches. when i connect outdoor antenna the. tv screen turn black. no signal. no reception but when i disconnect the outdoor antenna it turn to blue screen.
blue screen means 'no signal' or 'signal level is too low' whereas black screen means that there's a signal. Check your antennae, do a factory reset to your unit and then try initial setup.
Feb 26, 2015 | Televison & Video
How do I 'reset' on the sanyo tv
If it do not receive any signal, the tuner to this TV should be suspected. Anyway, if you wish to make it to factory reset, you have to enter its service mode option, and should select the Factory Reset option, to go further.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 21, 2014 | Sanyo CE32LD08-B 32-inch Widescreen LCD TV...
No longer receives GPS signal
Does this unit have an input for an external antenna? If you get/borrow another antenna you could see if it starts working. That might isolate the problem to the antenna.
Jan 23, 2010 | Lowrance iWAY 250C GPS Receiver
Acer pd100d does not receive signal from pc or laptop, changed cables too. only shows white screen with acer logo and no signal, worked until yesterday, buttons dont respond and cannot reset the unit to...
acer pd100d does not receive signal from pc or laptop, changed cables too. only shows white screen with acer logo and no signal, worked until yesterday, buttons dont respond and cannot reset the unit to factory defaults. please help
Dec 24, 2009 | Acer PD100 Multimedia Projector
My tomtom300 turns on but wont get signal
try to restore or reset to factory settings in the menu
Nov 18, 2009 | Tomtom GO 300 GPS Receiver
Waiting for valid gps signal
Go to TomTom Home on your computer and do a update for your unit. In the update list you should see a GPS quick fix which helps the TomTom's aquire a signal faster. Hope this helps.
May 21, 2009 | Tomtom One XL GPS Receiver
Black screen after factory BIOS reset
Have u connected signal cable to the monitor? Is it ON?Try with different monitor
May 07, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
I need to know how to reset my monitor to factory defaults
Factory Setting & EEPROM Initialization Method
Factory Setting Method
- Connect the signal cable and power cable to the LCD monitor.
- Press Power switch with pressed MENU key.(Menu key + Power key).
- Then, a User can change the factory setting value in OSD menu.
- Save changed value and Turn off the power s/w.
- Turn on the power, adjust the screen.
Apr 15, 2009 | Hyundai ImageQuest 19 L19T LCD TFT 19" LCD...
Olevia 237T 37 in. LCD TV Logo
774 people viewed this question
Top Olevia Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
