Help! Hi my wireless stopped working tonight..i have had it for months and its been working fine. Everything is plugged in, the power, modem and internet lights are on (on the wireless device) but the wireless light is not on. Is there a simple solution to this? It was working fine this morning!
    Sergeant:
  • 221 Answers
First, unplug the power cord from the back of the router then plug it back it, check the lights. If wireless light stays off, log into the device and check the wireless settings to make sure that wireless services have not been disabled. You will need to know the default username and password used to log into the device, so if you have the manual, it would be helpful. If you do not have the manual, reply to me with the make and model of the wireless device and I will search for the default login id.
If wireless has not been disabled, and resetting the device does not work, then you will probably need to replace the device. Make sure it is not under warranty first. If it is still under warranty, let the manufacturer replace for free.
Any more questions please ask.
Posted on Apr 12, 2008
Its saying my wireless internet is connected but when i plugged the internet cord into the router, it doesnt work anymore! its been like that for about a month & a half now.
Make sure all the wires are connected properly. 1.-Unplug your modem and router from the power supply. Wait 1 minute. 2.-Plug your modem back to the power and wait for all the lights to stop flashing. 3.-Plug your router back to the power and wait for the lights to stop flashing
Follow these steps and your internet should be working again!
Jan 14, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Power was turned off to the house. When power came back the router is blinking blue lights and can't see the modem. Disconnected the computer from the wireless and plugged directly into modem and it's...
just as a guess try unplugging power to both modem and router, then plug only modem in first until connection light stops blinking and goes solid. then plug in router.
Dec 23, 2010 | Linksys WRT160N Wireless Router
Hi, I'm an idiot! PLEASE HELP
you may be suffering from mixed Cat 5 and Cat 6 cabling.
The wiring is slightly different and they don't work well when mixed in routers and modems etc. One or the other will work , but when they're mixed it'll do what you have going on here...
I would recommend wiring everything with cat 6 ethernet cabling. Look on your cable and you will find the labeling on the outer casing.
Sep 20, 2009 | Computers & Internet
Router -> Modem Connectivity: I am fine if I'm hard-wired to the modem but if I connect wirelessly through the router I can't get WAN. I can get the modem page wirelessly. This just started tonight. I...
Have you check your DNS settings within your Wireless Network Adapter TCP/IP properties settings? Or it may be a proxy server or firewall settings wich may block internet access to the internet. Try testing it with your LAN cable first and see if you are able to connect to the internet using that cable from the laptop/pc to the modem. If it works using the network cable then it might be a DNS related issue on your wireless network adapter tcp/ip properties.
Jul 29, 2009 | Belkin (F5D5231-4) Router
Linksys Power cut problem
With regard to power cuts, i highly suggests you to buy a UPS (Uninterruptable Power Supply) to prevent further damage to your router. You can simply reconfigure the wireless settings of the router by accessing the router's Setup Page. Go to http://192.168.1.1, go to wireless tab and you can change the network name as well as enable the wireless security.
Jan 19, 2009 | Linksys Wireless-G WRT54G Router
Cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Jan 15, 2009 | Linksys Wireless-N WRT150N Router
I have had a wireless router for over a year and it was working fine. Now I can't get my laptop to connect? I'm not sure everything is plugged in properly. The digital phone that is hooked up has...
Hi have you tried unplugging the power from modem and router wait a minuet then plug the modem in,wait for lights to settle, then plug router in. Hope this helps
Sep 28, 2008 | Computers & Internet
Can't connect via my wireless router to the internet - but my cable modem is fine!
Hi!
Do you know how to check the IP address of your computer?
Maybe you need to reconfigure the router.
May 04, 2008 | NetGear RANGEMAX WNR834M Router...
Computers & Internet Logo
David Payne
David Payne
