There are several areas to check for possible exhaust leaks. i will list them below.
1. Exhaust manifold gaskets - This will be the most common area. There is a gasket that separates the block from the exhaust manifold. these gaskets can fail, thus, causing a exhaust leak at the manifold.
2. Lower manifold gasket(donut gasket) - This will be a possible leak spot as well. This small circular gasket is placed in between the upper exhaust pie and the lower side of the manifold. It basically separates the pipe from the exhaust manifold.
3. Exhaust pipe - The entire pipe can rust overtime, thus, creating small holes along the pipe structure. These holes will cause the exhaust to leak ,thus, filling the vehicle will moderate fumes and causing louder than normal engine sounds during revving.
4. Muffler - This component can also deteriorate to the point that it cannot filter out the noise. It will also cause leaks as well.
You will find the leak in one or all of the areas stated above in the list.
