Question about Danby DCD5505W Electric Dryer
Danby DCD5505-w1 Tripping Internal Breaker "Limit Switch"
Machine works normally otherwise, but randomly trips the limit switch that is behind the rear panel. Lint screen is clean and so is the lower clean-out that is under the dryer.
  • mikee72 Apr 12, 2008
    Thanks for the help. I've got the vent unhooked to eliminate that variable and it doesn't help. (Was totally clean, anyway.) Do you have a suggestion on how I might locate this possible lint clog? Also, I don't smell anything that would indicate anything getting close to burning. It doesn't have that "lint burning" smell that I've smelled on other dryers. Thanks again for taking the time to respond!
    Sorry for not being clear. I have the outside vent unhooked from the dryer, (dryer venting straight into the room) and am still having the tripping of the limit switch. Is there another clean-out (or way to access the exhaust path) inside the dryer? The owner's manual only shows the one on the door and the "trap door" on the underside. I wish it had a bit more information or an exploded view.
  • 135 Answers
Sounds like you may have a lint clog somewhere either in the dryer, or if if you have it vented in the vent. The limit switch is tripping due to an overheat situation. The dryer must have proper airflow to function properly.
Posted on Apr 12, 2008
  • Michael Thibodeau Apr 12, 2008
    Next is to check the vent as it exits your house. Find the vent outlet outside (may be on your roof) and check the air flow as the dryer is running. You may see lint right at the vent outlet. Or if you feel no airflow you may have to have the vent cleaned by a vent cleaning company.
No power, great lakes hot tub hear click like breaker tripping,down below in hot tub could it have bad internal fuses?
Charles, sorry I just re-read your question. The click you hear is likely a contactor if its an older model, and if it clicks its probably not the problem, just means its getting voltage. I would start by looking at the high limit switch. Look for a little reset button. A high limit switch trips when it senses high temperature, often from heater trying to run with Inadequate water flow.
Feb 22, 2017 | Pool & Spa
My tub keeps tripping the breaker, but after it kools down I can trip the breaker back on, but it hits 100 and trips the breaker again, could this be the heater?
What Trips?
  • the "Actual" electrical circuit breaker?
    • Is it GFCI Style?
or...
  • Is the high limit switch tripping?,
    • which isn't actually a breaker.
  • A circuit breaker is a breaker that toggles as a switch, and to reset it you have to switch the toggle switch ALL the way to Off position to reset, then switch it to on.
    • Same thing if it were a GFCI style, it just has a 'Test' button on the body of the breaker, that button is usually a white rectangular button.
  • Some systems have a GFCI breaker that looks totally differnent from above... It's located on the control system itself, very similar to what you may have in your bathroom or kitchen of your home! It will have a 'Test' button AND a 'Reset' button.
A High Limit Switch, acts like a breaker, as it will trip when it senses a temperature greater that it is set for as a safe temperature. Once that temp is breached, it will trip.
So... Which one is tripping for you? What are you resetting to turn it back on?
if circuit breaker, it has nothing to do with the 100 degree temp you mentioned. If that trips,= electrical problem, either a short or overheated electrical appliance (internal wires) aging motor pulling too much current, loose electrical connections generate heat, etc.
if High Limit, then possible overheat of water? Many times, failed thermostat. I already know what you're thinking... But I never saw water get Hot! But... Many times that IS just the case , it's just you never noticed the water hot, and it has been cooling down when you saw it.
Apr 14, 2015 | Pool & Spa
I have a goodman model gms80703ana the burner comes on and when the blower comes on the burner goes out.
This can be due to a dirty flame sensor or a high limit switch tripping. Clean the flame sensor first, this is a metal rod on the opposite side of the igniter, take steel wool and scrub it, then reinstall. If this does not work then the limit switch is tripping due to dirty filter, dirty blower wheel, weak blower motor. Aything that restricts airflow will cause the limit switch to trip.
Nov 30, 2012 | Goodman GMS807034ANA Heater
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
Breaker keeps tripping when I use Amana NED5500TQ electric dryer.
Heating element or motor. Usually heating element. Replace limit switch (inside dryer) during repair. Limit switch should shut off before breaker if working correctly.
After repair clean or replace plug/wire. Inspect or replace receptacle in wall.
Sep 28, 2009 | Amana NED5500TQ Electric Dryer
Rollout Limit Switch Keeps Tripping
have someone check the gas presure most likely too high no more than 11
Dec 14, 2008 | Coleman Propane Forced Air Heater...
My dimplex electric heater is tripping the electricty supply
it louds like a limit switch is tripping because something is getting overly hot,the limit switch is a safety device looks like a little black part with a push reset button in the middle
Nov 16, 2008 | Heating & Cooling
Frequent tripping of the hight limit switch
The high limit switch itself is getting weak , replace it and problem solved!
Sep 12, 2007 | Wells F-49 21148 Deep Fryer
Danby DCD5505W Electric Dryer Logo
208 people viewed this question
Top Danby Dryers Experts
Tim Whalen
SHARCNET-USA
SHARCNET-USA
Are you a Danby Dryer Expert? Answer questions, earn points and help others
