Hi my dv6000 laptop screen just stuffed up i cannot see the screen hardly at all its dimed pretty badly, the only way i can see the screen is if theres direct light on it.
  • 472 Answers
Your inverter has died. They can be replaced quickly and easily at any laptop repair center or you could do it yourself if you are keen to get inside of your screen.
If you want to get into the screen, you will still need to find a replacement inverter anyway.
Hope that helps.. Just post back if you need more info.
Posted on Apr 12, 2008
Can I switch out the screen to my hp g60 535 dx laptop with a screen from an hp dv6000 laptop
That will be impossible. The screen from the HP Pavilion G60-535dx is a 15.6 CCFL LCD while the one of the DV6000 is 15.4.
I suggest buying a new screen for the DV6000 if you need to. Or go online and trade the screen of the HP G60 and use the fund acquired to get a screen for the DV6000.
Hope this helps.
Oct 28, 2014 | Computers & Internet
HP Pavillion dv5-1113us laptop lcd screen backlight malfunction. My LCD screen is dark. There is no illuminated light to view browser, desktop, backgrond etc... Laptop boots up and runs but no screen...
I had same problem with HP DV6000. I ordered a new backlight on Ebay from Hong Kong cost $10 found a video on youtube on how to do it by typing in "replacing dv6000 backlight" apart from soldering a couple of wires was pretty straight forward and took less than an hour. Shop had quoted $400 to do this and fine is now working like new again. Good luck from Scott and please dont forget to vote
Jul 15, 2010 | HP Pavilion dv5-1113us 15.4" Widescreen...
Laptop keeps cutting off seems to get hot fast
The DV6000 series of notebooks have a problem with motherboard issues, to include WiFi Failure, video problems, and other issues. You can do your own research on this, but it is pretty widespread, to the dv2000, dv6000, and dv9000. Many HP owners were offered enhanced warranties, and at the minimum, received a discount on repair.
See what you can do, as it won't get any better for you.
Nov 10, 2009 | HP Pavilion dv6000z Notebook
Laptop Pavillion DV6188eu doesn't start up
From what you are describing, the motherboard has failed. I would however like you to try a couple of things though. First remove the hard drive and see if the computer will go to the BIOS screen. If it does not, then the Motherboard has definately died. If you can get to the BIOS, then you might consider a hard drive failure, or your windows installation is so corrupt, it is causing this problem. I would however lean toward a bad MOBO....seems this model, the DV6000 and the DV9000 have serious cooling issues and tend to burn their mobos up. HP recently started updating the BIOS files for these models so the fans and processor run more efficiently to keep the laptop cooler.
Nov 08, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
there are 2 possibilitys 1 the conector to the mainbord is falty or 2 wich is far more common is that the graphics chip is stuffed
Aug 23, 2009 | Compaq Presario M2000 Notebook
HP Pavillion entertainment dv6000 - Power goes
it is problem your laptop ram is rough position or demage change it then your laptop is active
Jul 17, 2009 | Computers & Internet
My laptop lights turn on but screen won't show nothing
I have the same case with my laptop. I heard that if you run it with the battery out it could fix it! Try it I have not yet!
May 20, 2009 | HP Pavilion dv6000t Notebook
Dim screen, burning elec smell, fan/ht snk foil blistered
DV6000 was recalled by Hp for a video connector problem. you need to remove your video connector and put a electrical sealant tape. If you have already problem with your GPU you need to make a mayor work to restore your system.
We can repair your laptop for $80:
10001 buckwood ave 79925 el paso tx
Apr 21, 2009 | HP Pavilion dv6000z PC Notebook
Broken HP Pavillon dV6000
Explain, (endured a hit). Electrical or physical?
For the hard drive (a clicking sound means a spindle problem). Suggest you get a new drive if it's no longer under warranty. Once you install a new drive you can slave your old bad drive into the system & pull your data off it before it stops working.
As for the laptop it's better off with a pro.
Mar 15, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
