Hard to turn on sometime,s with remote ,then when it come,s on it has a buzzing sound for about 2 min,s, then the buzzing sound fades out. WHAT IS CAUSING THE BUZZING SOUND?
Sounds like the display is going bad.. it may need replacing. I they are very hard to find them and the dealer only wants you to buy a new machine. Sometimes you can find them on eBay. Good luck.
The buzzing is typically gonna be the compressor trying to start and failing. Am I right in saying the fridge is at least 12 or more years old?
Maytag used to use a compressor made by Tecumseh and they had a problem with starting. They would buzz and sometimes start back up. Sometimes in a few tries or a few days or never. It would continue to re try every couple minutes and last 5-10 seconds.
I would verify if it is a Tecumseh or an Embraco compressor then make your decision.
A service tech should be able to figure this out pretty easily! Normally what I would do is if I go in and it is running then I would turn it off and back on right away. the fridge will go through its restart sequence and typically make its noises then. Hopefully you are not being charged every time they come out
Compressors are the most expensive repair! and on these I always replace the discharge tube since they tend to rot out from sitting in the drain pan.
either the noise is coming form he ice maker fill valve( but if its of and still aking noise i doubt it. it also possible that the noise is coming from the compressor itself, overheating nad trying to restart in which case would give a slight "buzz" noise for 5secs or so then "click" off, and wait maybe 3 min to restart again. look for melted ice andperhaps your ice dream ont as hard as it should be???
check your ribbon connections coming from power supply board there is 2 of them it will be the second one,theses ribbions connect to signal board.Sometimes causing set not to come on.
