Question about KLH BB-II Subwoofer
Need a product manual for a klh 9906 home theater system with 4 satellite speakers a center speaker and a bassbite II
  • 27 Answers
Try the KLH site. I have downloaded (for free) info on KLH products. Not much on technical stuff, but set up info and connections.
Posted on Jun 12, 2010
SOURCE:
Someone is trying to sell me a Panasonic Home Theater system SC-HT900 from year 2005 for $200.00 Is it a good system, is it also good for listening to classic and jazz or just for movies? how is the CD...
here it is some tech info ..it is a fair price for 2.hand unit...
as ebay has the similar prices..it seems to be a good deal...
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Product Features and Technical Details
  • Dolby Digital, Dolby Pro Logic II, and DTS-decoding home theater receiver with 5 speakers and a powered subwoofer
  • 35 watts per channel x 4 "tallboy" speakers, 140 watts for the center channel, and 150 watts for the subwoofer
  • High-resolution DVD-Audio playback; JPEG, MP3, and WMA CD playback
  • Magnetic shielding for distortion-free placement near a TV or computer monitor
  • Includes digital FM/AM tuner and a universal remote control
Technical Details
  • Brand Name: Panasonic
  • Model: SC-HT900
  • Output Wattage: 390
  • Component Type: Home theater system
  • Audio Output Mode: Surround Sound
  • Surround Sound Effects: Super Surround Sound
  • DVD Type: DVD changer
  • Built In Decoder: Dolby Pro Logic II, Dolby Digital, DTS decoder
  • Remote Control Description: Universal remote control
  • Optical Digital Input: Yes
  • Audio Input: None
  • Tuner Technology: Digital
  • Radio Bands Supported: AM/FM
Jun 21, 2011 | Panasonic Home Theater System System
Can I hookup a Sony receiver STR-DE505 to a Bassbite 2 KLH Audio system and how??
Yes.
It's frustrating that KLH manuals seem impossible to find anywhere online BUT a simple picture will suffice...
Go here and supersize the picture of the rear of the sub...
http://cgi.ebay.com/KLH-Audio-Systems-Bassbite-V-Model-E214708-Speaker-/110673631693
Run your front channel speaker wires to the CLEARLY-MARKED connectors on the sub and daisy-chain your front speakers to the CLEARLY-MARKED connectors on the sub.
Adjust the sub volume to match the front speakers levels. This will give you local volume control at the Sony.
Jun 04, 2011 | KLH BB-II Subwoofer
Center speaker is louder htan satellite speakers
Get into the manual and adjust it.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-DAV-FR1-Home-Theater-Systems-manual/id/350bh741/t/2/
Page 51-ish
Mar 28, 2011 | Sony DAV-FR1 System
How do i connect my klh bassbite V subwoofer to my sony receiver model str de335?
http://www.docs.sony.com/release/STRDE335.PDF
I am basing hookup on my Bassbite !! manual. The procedure should be the same as on your Bassbite V
I have given you a link to your Sony Owner manual. It looks like you will connect your sub to the sub output on the rear of your reciever using the rca cable. Woofer out on the Sony to the R/Mono input on your Bassbite. If you have the front and rear speakers hook your rears into the rear speaker outputs then connect your front speakers to the front speaker outputs of your Sony. Your speaker jacks on the Bassbite will not be used for this configuration.
Now, adjust your speaker size setting for "SMALL" or "LARGE" speakers as appropriate for your setup (this is for the front and rear speakers and will not effect your Bassbite). Now set your Sony subwoofer output to "ON" You access this setting through your menu. That should be located on your remote for the Sony. You will want to refer to the manual to find the exact method to access your system menu.
If the link to your manual doesn't work for you then go to http://esupport.sony.com/US/perl/model-documents.pl?mdl=STRDE335 and click on Operating instructions.
Hope this helps. Let me know okay? By the way, if this works for you you should be very pleased with the sound quality :-)
Kindly, DAVID (sean1dave)
Feb 26, 2011 | KLH ASW10-120 Subwoofer
I have a KLH bassbite II sub, not sure how to connect it to my receiver. Can you help? There are 4 wire amp inputs and 4 speaker wire outputs which I am assuming are right and left channels. There are...
Forget the 4 wire inputs on the sub as you have pointed out. use the low mono input only.this can be plugged into any audio out connections at the amplifier.so it is one rca/low wire from sub to amplifier then plug in power cord and adjust volume as desired.
Mar 06, 2010 | Audio Players & Recorders
KLH subwoofer Model BASSBite V. Has a bad 60Hz buzz
Before you go throwing money at this problem, try to eliminate any external influences like track lighting. I myself am trying to figure out why mine makes a buzz throughout my system when the lights are on. I already replaced the variable light control with no improvement.
Bad cable ground can let airborne electronic noise into the Sub's amp.
Jan 31, 2010 | KLH ASW10-120 Subwoofer
Bose PS 3-2-1 II speaker exspansion
Unfortunately this is impossible on the 321 series II systems. There also is no audio output on the media center to send to another amp either. As you may know, the 2 speakers are actually 4 speakers. Each small speaker array has 2 drivers. The 2 on the outside will project rear-channel audio to the sides, so placement of these speakers is important. Honestly, adding speakers would not make this sound very good. If the sound isn't too great as is, make sure you're using digital audio cables (optical or coax) from any external sources like a cable box or Blu-ray player. (if you don't see a Dolby Digital 5.1, DTS 5.1 or PCM 2.0 read-out on front of the media center, you'll know it's not digital. DVDs the exception)
Jun 18, 2009 | Bose 3·2·1 II System
No sound
you may have a blown fuse. check that first. Very if it still has a power.
Sep 12, 2007 | KLH SE-6000 System
Subwoofer VERY weak
According to the KLH manual for the 9906 "6 pack" with the BassBite sub... it says "if your sub is connected via the speaker - level terminals, your reciever must be set for "NO" subwoofer - even though you are using one. VErify proper polarity on your speaker connection wires. (red or gold to +, black or silver to -). Depending on how you have your woofer connected to the reciever, if connected to a reciever without a subwoofer out then set your reciever for LARGE speakers and turn the subwoofer setting "OFF". Failure to do so will result in little to no bass. If you do have a subwoofer out from your reciever adjust your speaker size setting to small or large speakers as appropriate. Set the recievers sub output to ON. Connecting small speakers to a reciever set for LArge speakers can result in damage to small speakers.
Hope this helps.
Jan 14, 2007 | KLH HTA-4100 System
KLH BB-II Subwoofer Logo
921 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
