Question about Microsoft Windows XP Professional for PC
To you now when i started my pc my windows live care asked me that,it had blocked c:\windows\system32\rundll32.exe, to allow it or not, then i had searched on net about it.... it seems that it is worm/virus like that then my fire wall blocked it.. but still i have the problem of opening my c..and also i cant downlaod any thing, the speed is too poor, this all are i m telling to ur information.. thanks n may the gret god bless you.......
  • 983 Answers
Rundll32 is a system file ... as i told you previously due to virus attack some system files have damaged ...
it can solved only by reinstall the windows Xp as i told in earlier post ...
any doubts reply me
i am always here to assist you
thank you bye
Posted on Apr 12, 2008
Error rundll32
at pc? more info? i think wrong section ^_^
What is rundll32.exe (rundll32.exe error)?
rundll32.exe (rundll32.exe error) Description: Rundll32.exe is a program which would have been on your pc since the day you purchased your pc. Always verify the exact disk location as many virus and spyware writers will attempt to fool you by using a similiar name or same name in a different location. This file is part of the Microsoft Windows operating system. Rundll32.exe will actually execute functions in DLLs. If you are deleting files on your computer as a spyware removal protection method, then note that this is a required system file. Note that rundll32.exe can also be running many different other DLL or EXE programs, so you may want to check the programs listed after it in your startup list also, as these may be executed by it. Rundll32.exeis considered safe and is not spyware, adware, or virus related and does not need to be removed.
rundll32.exe error: rundll32.exe error. Be sure to always double check your spelling if you are concerned about spyware, as often spyware will use a very similiar spelling of system processes or other common tasks. rundll32.exe error
Click here to remove rundll32.exe virus
remove rundll32.exe virus: Remove rundll32.exe virus. Remember that although many files are always in default file locations, some files can easily be moved to different locations or change names like many spyware, adware, or popup programs do. If you suspect you have spyware or adware, check to see if you see a similiar names stored elsewhere. It always helps to check your tasklist also to see what is currently running on your computer. You can always view the tasklist on your computer by pressing ctrl-alt-del to view your "task manager", and then click the "processes" tab. This will show you all tasks running on your computer. Dll files will NOT show on your computer tasklist, as dll files are actually part of other processes. You may see similiar program names running if spyware or adware is on your computer, for example, ati2evxx.exe may be slightly misspelled to keep you from finding it, or spyware and adware may be named very similiar to a system file. Make sure always check the location of tasks or processes if you are concerned.Remove rundll32.exe virus
rundll32.exe Common Path(s): This will be found in your windows\system32 folder. You will see it starting up programs like: RUNDLL32.EXE C:\WINNT\System32\NvCpl.dll,NvStartup
^_^
Apr 20, 2014 | Nokia Asha 201 Blue Unlocked Dual-Band GSM...
Tip
How do I fix rundll32.exe on Windows XP?
Rundll32.exe is an important process for the Windows operating system. The process rundll32.exe take the dll file and put their libraries in the system memory. Without this process, the computer should be unstable and very slow.<br /><br />The process runs from your system directory C: \ Windows \ system32. If it executes or runs from elsewhere is most likely a virus or a Trojan. You should scan your computer immediately with a virus scanner. Viruses using the name rundll32.exe are W32.Miroot.Worm. Backdoor.Lastdoor and Trojan.StartPage (among others).<br /><br /><span style="font-weight: bold;">Fix rundll32.exe</span><br /><br />If a virus, such as Netsky, destroys rundll32.exe or, if for any reason, your rundll32.exe is corrupt or is accidentally removed, you must do the following:<br /><br style="font-weight: bold;" /><span style="font-weight: bold;">Find rundll32.exe DC system</span><br /><br />Check if you find a copy of rundll32.exe in the folder C: \ Windows \ system32 \ dllcache or in C: \ Windows \ Service Pack Files \ i386. If yes, go ahead and copy rundll32.exe to the system directory C: \ Windows \ system32<br /><br />If you can not find a copy on your system, try to locate the file on your Windows installation disc. Finally, you just reinstall Windows. It would be time consuming, and you may lose all your data. So what would be the last resort.<br /><br /><span style="font-weight: bold;">First, run a system repair tool to fix rundll32.exe</span><br /><br />There are various tools on the Internet that scan, analyze and fix your computer. In addition to solving your rundll32.exe these tools to remove all registry errors, remove invalid shortcuts and duplicate files, repair DLL files, and remove the errors start-up and running.<br /><br />
on Mar 07, 2011 | Computers & Internet
La maquiina me pide el archivo windows/system32/rundll32.exe para poder acceder a quitar o agregar programas
Ir a la http://www.dll-files.com/dllindex/dll-files.shtml?run32 para descargar lo necesario.dll
Descomprima este archivo y el lugar en C: / / windows/system32 /
Mar 02, 2011 | Computers & Internet
How would i fix with my icon default,, everytime i open an application... open in suggested file... i want to return it to default... application,, and my rundll32 is not working, system32
***Find a copy of rundll32.exe in folder c:\windows\system32\dllcache or in c:\windows\servicepackfiles\i386.
If you find this, go ahead and copy rundll32.exe to the system folder c\windows\system32.
Otherwise you need a windows disc to expand this file (see below).***
1.
Put the Windows XP CD ROM disk in the CD ROM drive.
2.
Click Start , and then click Run .
3.
Type expand X :\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
4.
Restart the computer
Jan 25, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Can't get into any folder because c:Windows/System 32/rundll32 .exe keep popin up
To resolve this issue, follow these steps:
1.
2.
3.
4.
2.
3.
4.
1) Put the Windows XP CD ROM disk in the CD ROM drive.
2) Click Start , and then click Run .
3) Type expand X :\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
4) Restart the computer.
Oct 27, 2010 | Computers & Internet
Cant get automatic updates from mirosoft.cant down load .cant find rundill 32 exe.cant find help suport .
What is rundll32.exe? Is rundll32.exe spyware or a virus?
This program is part of Windows, and is used to run program code in DLL files as if they were within the actual program. However, many viruses also use this name or similar ones. This file is also commonly used by spyware to launch its own malicious code.
Note: The rundll32.exe file is located in the folder C:\Windows\System32. In other cases, rundll32.exe is a virus, spyware, trojan or worm!
If you don't have this file in System32 then you have other problems. Possibly a virus is onboard.
Oct 06, 2010 | HP Computers & Internet
I Have somehow lost the following file c:\windows\system32\r undll32.exe which is stopping me from getting into control panel etc
try this :
  1. Put the Windows XP CD ROM disk in the CD ROM drive.
  2. Click Start, and then click Run.
  3. Type expand X:\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
  4. Restart the computer.
Mar 07, 2010 | Sony VAIO GRZ610 Notebook
Rundll32.exe is missing
Check if you find a copy of rundll32.exe in the folder C:\windows\system32\dllcache or in C:\windows\ServicePackFiles\i386. If this is the case, go ahead and copy rundll32.exe to the system folder C:\windows\system32If you don't find a copy on your system, you can try to find the file on your windows installation disks.
Insert the windows OS CD and repair the XP, that should reload the copy of rundll32.exe.
Rundll32.exe is vulnerable to virus, so the file might have been deleted by the anti-virus you are using.
Good luck and please do rate my solution.Also post comments in case of any doubts related.
Jan 20, 2009 | Microsoft Windows XP Professional With...
Rundll32.exe
check immediately for any virus (especially w32).your rundll32.exe files in the /windows/system32 is missing or affected.try replacing the same from some other computer.or repair the windows using the CD
May 23, 2008 | Computers & Internet
Microsoft Windows XP Professional for PC Logo
54 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
