Water is coming out of the bootom of my washine machine when its filling
  • 135 Answers
What make and model do you have? Try to get in there with your flashlight and see where that leak is originating from.
Posted on Apr 12, 2008
Whirpool awm5100 machine not getting rid of washine powder in despenser only filling water alittle then stopping cycle
The most likely fault is the water inlet valves are blocked or only partially opening , pull off the pipe coming from the inlet valves and put the machine into cycle the flow of water should be full of the pipe and at mains water pressure, if this is not the case replace the inlet valves. Thanks tk
Mar 10, 2014 | Whirlpool Washing Machines
Dirt like substance coming out from the washine during wash cycle
Possible that there is dirt in the drum that comes up when the drum revolves. This can be due to dirt that had accumulated within and needs to be removed. Please try to watch this link and get some tips to clean the drum.
click on : cleaning the drain
Jan 01, 2013 | Washing Machines
Hi I have a problem with my Kenmore washing machine,in particular I can not use hot water anymore. When I use my washing machine hot water does not stop at set water filling level (law, medium,high)...
Please post the model number for your washer. It sounds like your hot water valve has failed and is not closing. Unplug your washer's power cord and turn the hot water spigot that comes out of the wall on. If you still get water filling your washing machine, it's definitely the washer's valve and you will need to install a new set (hot and cold valves are both part of the same assembly).
Mar 11, 2011 | Kenmore Washing Machines
Machine over flows and does not stop filling
The part that the two hoses are connected to is an electric valve that shuts the water off when the machine is full. It seems like it is time to replace it.
Nov 07, 2009 | Fisher Washing Machines
Fisher & Paykel Washine Machine is filling up hot and not cold?
As nice as these machines are, I've read bad things about Fisher & Paykel reliability. It sounds to me like you have a bad solenoid.
FYI, you should leave the water lines on (both hot and cold) all the time, no need to shut them off unless you're unhooking the machine to move it or work on it. The machine should control the temperature itself.
Jun 14, 2009 | Fisher and Paykel (IWL12)
Water runs contiuously... tub never fills...cycle doesn't start.
Hi, You need to reset the drain hose. It needs to be over the water level in the machine. If you have it in a sump pump, it needs to be out of the water in the sump. If I can help you further, please let me know
Thanks
Vic
May 16, 2009 | Roper RTW4100SQ Top Load Washer
Washin machine not filling
The problem is probably the water fill valve is defective. Make sure that the door is shutting properly, as it will not fill if the door isn't shut.
Post a comment if you need more help.
Thanks,
Tim
May 08, 2009 | Indesit W 123 Front Load Washer
I have a hotpoint bc1450 no water coming into machine
Did the problem start directly after the washine machine was fixed ? I wonder if when the washing machine was moved back, the hose to the dishwasher has become trapped and kinked behind the washing machine. Or maybe the supply to the dishwasher is separate to the washing machine and has been turned off by mistake.
Dec 30, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
