Question about Belling XOU492 Electric Double Oven
Noisy fan when either oven on belling xou492 is turned on there is a noise from a fan from the top section of the cooker behind the controls. It is not the main oven fan from the lower oven as that is working correctly but still generates noise from a fan behind the main controls. I presume this is the cooling fan but how do i change it? Regards barry mason
    Problem Solver:
  • 10 Answers
It has to be replaced the bearings are shot on it I'm afraid well knowen problem in are trade.
Posted on Apr 12, 2008
I have a belling double oven. The bottom is fan assisted. It all works okay but when it is turned off it is making a drumming noise after the fan has stopped. This lasts for at least 5 minutes. Any...
Sounds like the cooling fan bearings are worn, hence the noise after you turn the cooker off.This fan is in the top of the oven and helps to keep the inside cooker electrics cool and often keeps going for a while after you have turned the cooker off. Best to call an engineer to check this out for you!
Nov 30, 2014 | Ovens
How to diagnose, fit and change a Belling fan oven element
If your fan oven is not heating up properly the Fan Oven Element for your Cooker is usual culprit. Fitting an oven element is generally very easy, as demonstrated by The Apart4u video on How to change repair and replace your fan oven element:this fan oven element can usually be changed without taking the appliance out of situ. Belling Elements
on Aug 25, 2010 | Belling XOU492 Electric Double Oven
Beko oven fan catching element everything secure making dreadful row
Your oven must be fairly level for the fan not to make a noise.
Jun 28, 2014 | Belling XOU492 Electric Double Oven
Belling 492 bl short out when oven turned on
Sounds like the oven element is broken, replacement at
Check dimensions with the one shown
Mar 16, 2014 | Belling XOU492 Electric Double Oven
Beko fan oven making noise
If you have a problem with your cooker or oven then this diagnostic video will help you find the fault on your beko oven and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jan 08, 2014 | Belling XOU492 Electric Double Oven
De dietrich range cooker very noisy when oven on?
Have you checked the exhaust fans within the oven? These can make a lot of noise if something has come lose. They should be located at the top of your oven or on the back. I would check that.
Good luck
Dec 05, 2013 | De Dietrich Ovens
Belling double electric fan oven lost instructions
Get similar instructions here
Dec 27, 2009 | Belling XOU492 Electric Double Oven
How do i take out the old cooker element on my belling xou252 cooker
If it is a fan assisted oven, then the element should be behind a removeable cover at the rear of the oven,
Be careful not to lose the wires behind the oven compartment.
Hope this helps.
Dec 19, 2009 | Belling XOU252 Electric Single Oven
We have a belling format oven - when we turn the top oven on it is making a sound like a helicopter
The noise is probably cominbg from the externally mounted cooling fan. to access it, you will have to remove the side panel and rear cover, and top cover if it is bullt in.
If it is free standing, you should be able to get to it by removing the top cover/hob.
Hope this helps.
Dec 07, 2009 | Belling XOU492 Electric Double Oven
My fan doesn't work
fan not fixable - replace. possible be that there is crap jamming the fan.check that the fan blade turns freely
Mar 13, 2007 | Belling XOU492 Electric Double Oven
Belling XOU492 Electric Double Oven Logo
973 people viewed this question
Top Belling Ovens Experts
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
