Question about Refrigerators
Ice maker hatch not opening - Refrigerators
  • 1 more comment
  • kvennis Oct 09, 2008
    My ice machine is making ice. However, when I place a glass next to the hatch and push in, no ice comes out.
  • m_smile May 21, 2009
    The ice maker is making ice. Whe I place a glass under the dispenser for getting ice, the hatch does not open. Ice collects in the chute area. If I manually open the hatch with my hand, the ice then falls out into the glass.
  • Michael Thibodeau May 11, 2010
    Hatch? Please clarify the problem. What make and model is the refrigerator?
  • 135 Answers
No reply
Posted on Apr 15, 2008
Water does not come to ice maker
Is this the reason you replaced the solenoids and ice maker? If so please see suggestions below.
Is the replacement ice maker an exact replacement? Non exact replacements may not work.
Ice maker may not be cycling to call for water, ice maker fill tube may be frozen, bad connection from ice maker (at the ice maker connector) to solenoid, or open wire from ice maker connector to solenoid. Ask for details for the above possibilities.
Aug 16, 2014 | LG Refrigerators
Ice maker on/off light?
ice bucket full and/or door open so ice maker does not dump ice when you have door open.
Apr 04, 2014 | Refrigerators
When I try to dispense ice from my door, the hatch thing opens and then nothing. I thought the noise was the motor trying to go but the more I try it, it seems to be the hatch/flap. is my motor dead? any...
Have you checked for ice in the basket? Provided there is ice, when you apply pressure on the switch do you hear the typical grinding? If yes then check to make sure ice is not clogging the path. You will probably need to open the door and look. If you hear nothing when you press the lever then it is either the switch or the motor.
Dec 05, 2017 | KitchenAid Architect® Series II KSRS25FT
Cleaning of whirlpool gnf 220x model
If your ice maker was leaking before and after the valve replacement, it is likely the ice maker that is at fault. The ice maker energizes the water solenoid, its not a pump, which then opens to allow the pressurized water flow up to the ice maker. If the valve solenoid has been replaced, the culprit is likely the ice maker itself. The valve should only be open for about 7-9 seconds, but if the ice maker motor is slow, or if there is some other malfunction with the ice maker, it will energize the valve for too long, causing it to then overflow. It could also be a hairline crack in the ice maker mold that is causing it to leak.
Oct 20, 2010 | Whirlpool Refrigerators
Ice maker makes no ices. I check ice maker water valve directly to 110 volts and it is opening.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 26, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
My ice maker over fills. The fill switch must not be working? You open the door and ice spills out.
heatman101
Aug 25, 2010 | GE Monogram ZDI15C Automatic Icemaker
The automatic ice maker quit working, but first the water control valve hung up open [the refill cycle did not end]. Fortunately, I was nearby and when I looked into the ice maker I saw a slow flow of...
I removed the wiring connectors from the two water control valves and when I reconnected the wires for the ice maker I heard the unit cycle. When I checked the ice maker, the ice maker shutoff arm was now completely down, operational position. Previously, I could see that the arm was up, but not at the top of the cycle. I'm not sure what caused the ice maker to cycle, but I am assuming that there was corrosion on the wiring connectors which was wiped off when unplugging/replugging the connectors.
Dec 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not working
Pour about 2/3 cup of water into the ice maker . Also , check the black fill hose that fill the ice maker , to make sure it is not frozen . If the ice maker dumps the cubes , then replace the water inlet valve . If the ice maker holds the ice , and does not dump , replace the ice maker . When you open the freezer door , the laser light , should blink twice , then pause ,repeatedly . If you close the flap on the left side , the laser should go off . These are indication that the optics are good . If you open the door , and no laser light , then that means that the ice maker is in the harvest (dump) mode . If it stays this way , ice maker is bad .
Sep 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
132 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
