Question about Car Audio & Video
No stereo!! I bought a second hand honda civic and they cut the wires out to put a stereo in. I have bought the wiring harness to replace the one they ripped out but I dont know what colors go to what. It is a 1992 honda Civic n the UK. Can any one help??? Thanks, Vinnie
Google it! no need to pay these guys to find something out for free!!!! You can find anything on google!!
Posted on Apr 13, 2008
I dnt know how to hook my sony explode cdx gt 200 to my honda civic hatchback 94
The Honda Civic requires a dash adaptor you need this wiring harness to install the stereo it dont seem a dash adaptor is required for the 94 model you use the cage/sleeve to install the sony in your car you will also need this removal tool and either wire nuts, heat shrink tubing, crimp caps and crimp tool or the common solder and wrap in electrical tape method to connect the wiring harness for the honda to the wiring harness for the stereo
Oct 14, 2010 | Sony XPLOD CDX-GT200 CD Player
I need the radio wiring diagram for 88 honda civic hatchback
1988 Honda Civic Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: White/Blue
Radio Switched Ignition 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: N/A
Radio Amplifier Turn On Wire: N/A
Front Speaker Size: N/A
Front Speaker Location: N/A
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speaker Size: N/A
Rear Speaker Location: N/A
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Here can find the Stereo Wire Harness OEM Honda Civic 86 87 88 89 90 (car radio wiring installation parts)
Hope help with this.
Apr 26, 2010 | 1988 Honda Civic 2 Door
1992 honda civic stereo and clock don't work whats wrong?
Yeah, the ground. ALWAYS, make sure the ground is good. When that switch was cut out, the ground was disconnected also. That's why the stuff don't work and and the chronometer resets and is dim. ALWAYS check the ground before ANYTHING else is done.
May 12, 2017 | Honda Civic Cars & Trucks
I CUT THE RED N BLACK WIRE ON MY 2002 HONDA CIVIC N TRYING TO ADD LIGHTS WIRE N SOMEHOW I'M NOT GETTING ENOUGH POWER FOR MY HEADLIGHTS. PUT EVERYTHING BACK, N NEW BULB N STILL NOT WORKING ? DO I NEED TO...
If it was the Red/Black wire at the right headlamp, you cut the headlamp ground that grounds through the Daytime Running Light Module. If you then added more lights onto this circuit, you could have overloaded the drivers in the module and burned them out.
Oct 24, 2009 | 2002 Honda Civic
Identification of original wiring to car radio/stereo
no wiring diagram needed go cut a plug from a junk yard and wire it into the cut wires then buy the adapter kit for you car and wire that to the car plug and the radio plug.
Mar 19, 2009 | 1986 Honda Civic
I have a honda civic 1992 and i buy a sony car stero i have problem with de wiring like red goes with red black goes with black but de others color from my honda civic are difent can i have an ide
Battery
White/Yellow Stripe
or White/Blue Stripe
Accessory Yellow/Red Stripe Ground Black Illumination Red Dimmer Red/Black Stripe Power Antenna Yellow/White Stripe Left Front Speaker (+) Blue/Green Stripe Left Front Speaker (-) Gray/Black Stripe Right Front Speaker (+) Red/Green Stripe Right Front Speaker (-) Brown/Black Stripe Left Rear Speaker (+) Blue/Yellow Stripe Left Rear Speaker (-) Gray/White Stripe Right Rear Speaker (+) Red/Yellow Stripe Right Rear Speaker (-) Brown/White Stripe
Oct 19, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Wiring harness
you should never cut the wires on your factory harness... metra and other companys have harnesses that fit your car and would provide you with a correct wire color code you need to hook up a aftermarket stereo keep that in mind but i will post the wire diagram u are looking for
Aug 08, 2008 | 2002 Honda Civic
Car Audio & Video Logo
66 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
