Question about RCA P52960 52" Rear Projection Television
Where is located STK730-010 on a RCA p52960
Could you please help me....
  • 4,889 Answers
Will post the pics as soon as i get back home..
Posted on Apr 12, 2008
My rca projection 52" tv
http://www.partstore.com/OpenSearch/Model/Thomson/RCA.aspx
Jul 07, 2011 | RCA P52960 52" Rear Projection Television
Where is the convergence power supply located on a RCA P52960?
TAKE A CLOSE LOOK AT THE LABEL ON THE BACK OF THE SET WITH THE MODEL NUMBER, IS IT MARKED PTK195?
THE PTK 195 uses a power supply mounted above the main boards and is about 10 inches wide and 4 inches deep.
It is very common on this model for one of the ten diodes to be shorted; confirm it is a 195 chassis and I will tell you how to locate the two diodes that fail. They supply voltage to the convergence circuit and I have seen dozens where one of them shorts.
Let me know what you find; is it a 195 chassis?
If this information has helped you rate this solution as I do this here for free, rate it "very helpful".
If it is a 195 chassis let me know and I will pinpoint the location of the two diodes and tell you how to check them.
REGARDS, SD TECH
Aug 10, 2010 | RCA P52960 52" Rear Projection Television
My rca p52960 tv will not turn on at all. What can
I would disconect the front control panel you can do it by opening the back of the unit on top of the light box there is a couple plugs just unplug the one going to the front panel then try to turn it on with the remote
Jan 25, 2010 | RCA P52960 52" Rear Projection Television
Could use some help with a "bowed" picture on my RCA P52960
Is the convcergence ( Alignment) also off which gives the TV a 3D look around items on the screen? If so replace the STK730-130 on the convergence power supply
Jun 23, 2009 | RCA P52960 52" Rear Projection Television
Rca p52731wk wont power on
check for bad or broken connections around the high voltage transformer......
Feb 24, 2009 | RCA P52960 52" Rear Projection Television
My rca p52731wk projection television will not power on
We are available for conference Today and Everyday. Wewill assist you in repairing your set. The Part you need is Transformer 226094. Please joinin conference for part price and location
LOGIN
Circuitcity
Dec 26, 2008 | RCA P52960 52" Rear Projection Television
RCA P52960 Problem (bowed picture)
Normally this is either bad connections on the convergence ICs or defective ICs. If you can solder, you should be able to fix this. First locate the convergence ICs: large black ICs attached to a heat sink that shouldbe marked STKxxx. Try resoldering the pins on these ICs first. If that fails, replace the ICs.
Keep me posted.
Dan
Nov 20, 2008 | RCA P52960 52" Rear Projection Television
RCA P52960
try a combonation of buttons on front of tv-- hold vol up & chan up fo four seconds?? try menu & vol up for four seconds,etc. Consult o/manual?
Sep 05, 2007 | RCA P52960 52" Rear Projection Television
How would I locate the IC's
hi this model rca sounds framilure but model num on rca are more for cometic purpuses look on back and post chassis num ctc ext. and simpton mybe i can help with your convergence prob doc
Aug 14, 2006 | RCA P52960 52" Rear Projection Television
RCA P52960 52" Rear Projection Television Logo
51 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
