Question about Dryers
Receiver for ceiling fan
Where do I put it and what wires do the acn and acl connect to
  • john101d Oct 28, 2008
    dont have directions in hooking up the fan. and what wires need to be placed where. need help.....
Thank you for getting back to me. And yes I did solve the issue I wrote to you about. After much agonizing I  did come to the conclusion that if you read the directions about a hundred times the answer(s) will finally come to you. So it is now "All Good" and the fan works wonderfully. Have to admit I'm pretty proud of myself on this one (smiling). Thanks again.               Donna
Posted on Apr 13, 2008
How to eliminate receiver/transmitter in hunter 28425
Open the box at the bottom of the ceiling fan, where the switch is. You should find the receiver inside there. You'll find one white wire connected to it, and two black wires also connected to it. Remove the white wire completely or cap it off with a wire nut. Connect the two black wires to each other with a wire nut. Reassemble the ceiling fan. If the problem was the receiver, then the problem is now gone because the receiver is gone.
Aug 01, 2014 | Hunter 52" Ceiling Fan With Light And...
Is it easy to change our the receiver for Hampton Bay fans
Yes it is not that hard to replace an existing receiver with a new one. Caution: Turn off the power to the fan at the service panel. Remove the cover next to the ceiling which normally will have screws on the side or on the bottom under a plastic cover you remove by turning or pulling off. Inside the mounting bracket you will see the receiver. Carefully pull it out and take notice of how the wires from the receiver are connected and how the receiver was placed inside the mount. Look at the dip settings on the old receiver and set the new receiver exactly the same. The transmitter and receiver dip settings must be the same or it will not work so it is critical the new receiver settings are set exactly as the one you are removing. Now, remove one wire nut at a time and connect the new receiver exactly as the old one was connected. Make sure to tighten the wire nut securely with no bare wires showing. Slightly pull on the wires to make sure they are secure. Tape this up with electrical tape as a security measure. Once you get all the wires connected put the receiver back inside the mount just like it was. Replace the cover and then go turn the power back on. You are done.
Nov 07, 2009 | Hampton Bay 13087 70450 Carousel II...
Receiver installation issue
Most of these fans locate the receiver on the mounting plate (metal part fixed to electrical box where ball hangs). The canopy (decorative part that covers the wiring on ceiling's electrical box) has enough space to hide it. I presume you're missing the manual, so install the fan and slip the receiver in the plate, right between the electrical box and the ball, everything's color coded, securely wire cables from ceiling to power cables in receiver and cables from the receiver to the fan. Slide canopy up and securely fasten with provided screws. Good luck!
Nov 01, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Im installing a hunter remote control receiver in the ceiling mount. I have a red, black, white and ground wire from the ceiling. Which wire on the reciever do I connect the red wire to?
The red wire in the ceiling is probably used in a shared neutral circuit and not needed for the fan. If it's not capped off already, it should be.
Just use black, white and ground from the ceiling.
Charlie
Aug 16, 2009 | Hunter 52" Ceiling Fan With Light And...
Receiver won't fit Model 52-CS
Turn the breaker off first.
You'll have to take the fan down and of course disconnect the wires. I run into this a lot. What I do is take a razor knife and cut carefully into the ceiling on the side of the box, Then connect the wires from the box to the remote module with wire nuts. I always wrap them in a couple turns of eletricians tape.
Then connect the long wires to the other end of the module and push it up through the slot I cut out and lay it flat on the top side of the ceiling.
When you put it back together the part that goes against the ceiling will cover the hole in the sheet rock. Pain in the rear, huh?
Sirwriter
May 15, 2009 | Hampton Bay 13087 70450 Carousel II...
Wall switches do not control fan
Some fans will not operate without the remote, however, I'm not sure if the Hampton Bay brand is one of these or not. Below is how you will bypass the remote if the fan will operate without the remote.
You can try disconnecting the receiver in the canopy of the van (the cover that fits snug to the ceiling) once you have shut off the power source remove the canopy and find the remote receiver.
Most likely it will be a rectangular box with white, black, and blue or red wires attached. Disconnect all wires from the receiver and lay it to the side.
Now reconnect the wires directly to the fan, white to white, black to black, if you have a red wire (or a second black wire) in the ceiling box connect it to the blue wire from the fan.
If you do not have a red wire (or second black wire) in the ceiling box, connect the black and blue wire from the fan to the single black wire in the ceiling box. This method will require you to pull the chain to operate the fan separately.
Dec 12, 2008 | Hampton Bay 52 In. White Redington...
Remote Control Ceiling Fan Problem
OK, first off, there have been some problems with those remote units. That said, let me tell you what the wires should be doing and you can see if that is happening.
Normally they take a "Hot Wire" and attach it to the white wire that goes to the switch. It is hooked through the switch to the black wire to bring the "Hot" back up to the light/fan. The whites in the ceiling box are the neutral. A "Hot" and a neutral are required to make anything work. The copper is a ground, or added safety. It usually is attached to the same spot as the neutral in the breaker box, so it is not a big deal. If you have a hot going to the switch which works as the off/on valve, and back up to the box. The hot and a neutral make what ever you hook it to work. Now, if you have a remote, it uses a connection at ceiling box to turn it on and off. You can have a switch to turn the whole thing off and on, but if that switch is on, the remote is just a different way to turn it off.
If you have a way for the electricity to make the big circle, it should work, unless a part some where is not letting it through. I imagine in your situation it is the remote.
If this is new, you may want to see if you can get another, and take the remote part out (Up in the fan) and replace it. You would not have to re-assemble the whole fan. I have replaced several of these lately, and even put a different kind of remote on a few.
Nov 30, 2008 | Oasis Hunter 54' Ceiling Fan
Ceiling fans..
Are you talking about the receiver? If so connect wires from fan, White, black,blue to receiver white, black, blue. White to white and so on. Then connect the two wires from other side of receiver, white and black(or Red) to corresponding colors from ceiling. Then store receiver just above the ball in the ceiling mount plate, you will have to move the wires to the side and push it in. Hope this helps
Aug 16, 2008 | Dryers
Installation
I assume that you're talking about a remote-controlled ceiling fan.
There are two parts to a remote-control setup -- the transmitter (the switch which you use to operate the fan and/or light), and the receiver (which receives the signals sent by the transmitter, and directly controls the fan and/or light).
The receiver -- which should look like a plastic rectangle, usually white, grey, or orange-brown in color -- can be identified by the fact that it has several colored wires coming out of it, and doesn't have any buttons. This is mounted in the ceiling fan itself. On nearly all setups, it goes inside the canopy (the decorative part of the ceiling fan, up by the ceiling, which hides the fan's electrical wires).
The transmitter may be either hand-held like a television remote control, or in-wall mounted like a light switch. If you have the hand-held variety, there is nothing to install in a wall box. The wall-box wires should be appropriately connected up, and a blank cover plate should be put on top of the gang box.
If, on the other hand, you have the in-wall variety of transmitter, then yes -- it gets mounted in the wall, in a gang box, like a normal light switch or outlet.
If you need any further clarification, please feel free to ask!
Jun 17, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay 54in. Covington with remote control
Make sure the power wires from the ceiling mount are still in the electric box. Then have them come from the side near the screw mounting area. In otherwords, not through the center hole. In the center of the black metal part - there is where you put the reciever. It will fit literally resting on the black metal.
Aug 31, 2007 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Dryers Logo
144 people viewed this question
Top Dryers Experts
