Question about Canon PowerShot S45 Digital Camera
No Power up
Will not power up with sliding lens cover or replay button - new battery fitted - tested OK in another camera and battery from that camera does not make mine power up either......is there a fuse? How do I get at it?
  • bikemommy May 06, 2008
    my camera won't power up when i open the shell. problem started suddenly.
  • fred-dog Oct 31, 2008
    My S45 just stopped working also. Same thing. It was working fine. Turned it off for a few minutes. Tried to turn it back on and nothing. Use the review switch on the back and still nothing. It just died. Tried playing with the switch on the battery/card door, no help. Any advice would be greatly appreciated. Thanks!
    Scholar:
  • 46 Answers
Dear ianaird:
There is no fuse or anything to jump-start a dead camera unfortunately. If you have tried a different battery and you are sure it was good, then check your battery and memory card door to make sure they are completely closed.
If still no power, try removing the battery and gently wiping with an eraser and then a clean dry cloth all battery contact areas that you can reach. Reinstall the battery and try again.
If you still get no power you will likely need to send the unit in for service. Contact Canon's Tech support at 1-800-828-4040.
Hope that helps.
Sincerely,
HeavyDLB
Posted on Jun 01, 2008
I have a canon sx30 IS. I can no longer get it to play back. The camera still takes photos and video as I can take the card and see them on computer. Any idea what is wrong?
First test to see if the Replay (single right arrow) button actually works. That may be the problem. That button does two jobs. 1st it is supposed to enter the replay mode to show the last picture taken first. Apparently, from your description of the problem, that is not happening. To verify it is that switch that is dirty or defective, power up the camera, press the Replay button firmly just once, press the left arrow on the circular switch once. Wait until the lens retracts (about one minute). Then press the Replay button firmly once more. The camera should power down. If it doesn't, that proves the Replay switch is dirty or defective. Post the results of this test if possible.
Nov 03, 2013 | Canon PowerShot SX30 IS Digital Camera
My screen is blank can not see anything
do you have the lens cover open? do you get any error code or warning message? do this: make sure you have fully charged battery. close the lens cover.make sure cam is off.open lens cover by sliding it down until click is heard.if no go.close lens cover.make sure cam is off.remove the battery from cam for at least 15secs.reinsert battery.open lens cover until you hear the click.if no go try this. can you see the operational buttons and icons on the screen? if you do try to initialize the camera. touch HOME ->settings (looks like a toolbox icon) -> Main Settings (touch OK) -> [Initialize] -> [OK]. if it doesn't work service might be required.thanks :)
Mar 19, 2010 | Sony Cyber-shot DSC-T9 Digital Camera
Fujifilm finepix A330 switches off after trying to take a picture fitted 2 new 1.5v batteries,and an external power supply
The sliding lens cover is also the on/off...... be carefull you are not moving it as you take picture.
Dec 29, 2009 | Fuji FinePix A330 Digital Camera
MJU 300 battery charged .slide open no power
This may be a repair issue with the sensor that is located behind the front sliding lens cover. You may want to call Olympus Customer Service to discuss repair policies and procedures. Their telephone number is 800-622-6372 option 2 and then option 3
Feb 11, 2009 | Olympus MJU 300 Digital Camera
Doesn't work at all!
Daft question, but are the batteries fully charged?
Lens cap off?
When you hit the menu/ok centre button, do you get the menu screen up?
Aug 27, 2008 | Fuji FinePix S5700 Digital Camera
Lens cover does not operate correctly
I fixed this problem on my Fuji FinePix A303 (though it took some hard work).
The problem:
Camera Lens Cover stuck open or stuck closed.
Power on, and get !LENS COVER error.
Lens fails to extend.
The solution:
Short answer: The motor driving the lens cover is weak and eventually breaks down. I manually open the cover now. This took a manual modification to the camera (and some work).
1. Take the camera apart. See here for details, and be careful around the flash, as you'll get a nasty shock otherwise! http://www.mathematik.uni-marburg.de/~haim/focuserr.htm
2. Once you can see this, you're just about there:
3. Take off the battery cover (in the picture above).
4. Wrap a wire around the sliding pin for the lens cover, and drill 2 small holes through the black structure underneath the battery case, and then to the outside. The wire goes from the pin to the outside via the two holes. You should be able to manually open and close the camera cover COMPLETELY now with the wire.
5. Reassemble the camera (actually, you can test that it's working when it's all apart, if you're careful).
6. To operate the camera now, close the shutter first while off. Power on the camera, and very soon after open the shutter all the way by pulling on the wire (from step 4). This basically mimics the action of the little lens cover motor. If you timed it right (you have about a second margin), the lens should extend and everything functions perfectly.
It would have been nice to have been able to simply buy a new motor, but that would probably be a pain and cost some money.
Hope this helps!
Matt Van Dyken.
http://mattvd.googlepages.com
Aug 16, 2008 | Cameras
Camera doesn't recognize lens cover...
I rednecked the crap out of mine. I pulled off the slide cover and placed a small piece of paper clip in the area of the copper to make a permanent contact. Then duct taped it secure and then cover the whole slide mechanism. I would not recommend this method but it worked.
Apr 28, 2007 | Sony Cyber-Shot DSC-T5 Digital Camera
Camera powers up but lens cover fails to open
It could be some grit or sand causing the lens cover to not open, so the camera won't initialize. Try cutting a slip of paper narrow enough to slide between the lens opening frame and the lens cover. Move it in and out to clear any grit that might cause the spring-loaded cover to bind. Good luck !
Dec 14, 2006 | Sony Cyber-Shot DSC-P41 Digital Camera
Canon PowerShot S45 Digital Camera Logo
150 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
