How to remove write protected from drive?
How to remove write protected from pen drive please help me?
  • Mumait Apr 12, 2008
    How to remove write protected from pen drive?
    Genius:
  • 1,447 Answers
At the bottom part of your pen drive there is a little switch that ypu can actually toggle, its a little white switch, its either on the side of it or at the other end from where you remove the cover. Hope that helps
Posted on Apr 14, 2008
  • Mr. Rasel May 31, 2013
    it has no any little switch. but it showing light. help me.
    New Friend:
It has no any little switch. help me please
Posted on May 31, 2013
Hello ,i have problem with my 4 GB kingston pen drive. whenever i try to copy or delete something it gives me an error that 'The disk is write protected.remove the write protection or use another...
If you have just been taking the pen drive out without going through the "safely remove hardware" option then you have probably corrupted it. you could try the below technique, however, my feeling is that you will have to replace it and try to be more careful how you remove the pen in future.
http://techsalsa.com/solution-to-remove-write-protection-from-usb-pen-drive/
Jan 30, 2011 | Fuji (MAP3367NP) 36.7 GB Hard Drive
My pen drive has become write protected and now I want to remove write protection from my pen drive,please help me.
Hi Sir.
Please look carefully at your usb pen-drive to see if there is a small switch on there somewhere that is used to lock and unlock the drive. perhaps you may have accidentally put it in the lock position.
If there is a laser pointer on the drive then using the laser pointer may have caused you to accidentally switch to the write protected mode. most drives have a lock/unlock switch on the pen-drive itself...unless it has a program installed on the drive that has encrypted and locked the drives read/write ability. Please let me know if you have success.
Thank you!
Dec 03, 2010 | Generic Memory USB 2.0 128MB Black Pen...
I have 8 gb trancend pen drive and it is showing
This can be simply removed by changing the position of the write protect lock on the pen drive body. Please refer the figure.
Please come back and rate my solution if turns to be helpful for you or also if you need more clarification. Thnx :)
Apr 07, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
WRITE PROTECT ERRORS IN PEN/FLASH DRIVE
Please open the link below and follow the instructions there to resolve the issue if the problem persist after following the instructions then pen drive is defective.
Feb 08, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Write Protected Problem
Hi Sir myself piyush gajera sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection. sir my email id is piyush_gajera147@yahoo.com kindly mail me as soon as possible. my Pen Drive is transced d33193. and it has no any stick to remove write protected. Thanks in advance. i have the same error while deleting or formating my pen drive My transcend 4GB pen drive when deliting data it ask to remove the write protection while formating the disk it shows write protected. when copying data it ask to remove the write protect
Jul 09, 2009 | PNY 2GB microSD Memory Card
How to remove write protection from my pen drive
Dear,
Just do one thing
Copy the data of Pen drive to PC and format the drive. Now paste the data back to the pen drive.
It may work fine onward.
Please try it.
Regards,
Rakesh Kumar
Apr 07, 2009 | Kingston 4GB Secure Digital High Capacity...
Remove Write Protection
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
Nov 06, 2008 | Transcend (589307) Media
Removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
Oct 31, 2008 | iLO (2 GB) MP3 Player
How to remove write protect from pen drive
I OWN A TRANSCEND pen drive of 8gb when i try to copy or format the command it shows is "cannot create,remove the write protected"what shall i do .the pen drive is very new
Jan 12, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Computers & Internet Logo
270 people viewed this question
David Payne
David Payne
