Question about Hansol H750 17" LCD Monitor
How long do they last?
Just a quick question. whats the usual life span of a LCD 17" monitor?
  • borisbullet Apr 13, 2008
    kwl ours is 4 years old how big is your monitor btw?
  • Hansol Master
  • 13,433 Answers
Id say over 3 years. My lcd has a 3 year warranty so Id say atleast 3years. well I did pay 525euro / over 700 usd to for this display.
Posted on Apr 12, 2008
  • Ekse Apr 13, 2008
    it is asus pg221 - 22" with all kinds of special features.
I have a Gucci watch which cost £630.00 and the battery lasted 17 months, is that the usual life span for a battery
it can be--their is no definite life span of a battery because everything has a different draw of power a simple watch can last years while more complex such as date/stop watch /backlight etc will draw and kill battery quicker
Jul 19, 2016 | Gucci Watches
Tip
The CCFL or LED light source are claimed to have 50,000 hours or more, but the...
Flat-panel LCD TVs have a lifespan newly approaching 100,000 hours on average. The lifespan of an LCD TV is generally longer than that of similar-sized plasma televisions. Some manufacturers even claim that their LCDs can last upwards of 100,000 hours when used continuously under controlled conditions (e.g., in a room with "standard" lighting conditions and 77&deg; temperatures throughout). Just how realistic such claims are is debatable. After all, whose living room has no windows and remains at a perfectly comfortable 77 degrees year-round? <br /> In any case, the pictures on fluorescent backlit LCD TVs will show some "wear" because they are generated by powerful lamps, which, like any lighting appliance, will dim over time and with use. The picture you see will dim ever so slightly as the backlighting bulbs dim. One other consideration is that CFL fluorescent backlighting will change colors over time. This will change the white balance on your TV and cause color calibrations to be thrown off. <br /> Therefore, the most important thing to consider when it comes to the lifespan of your LCD TV is the actual lifespan of the light source in your LCD. LCD TVs last as long as their lightsources do. So, the lightsource in your LCD TV is the critical component of your LCD display unit. Newly introduced LED backlit LCD TVs will have the best long term performance. LED backlighting is superior in that the white balance of the TV will not be affected by changing bulb color over time. It's a more consistent bulb technology and will also maintain its brightness longer. <br /> The edge lit version of LED TVs will use far less energy while local dimming LED backlighting will be more accurate and present a better picture while using more power. We believe that local dimming LED backlighting will be slightly less stable from a life span standpoint. <br /> To ensure the integrity of your lightsource for the duration of your LCD display's lifespan, you will definitely want to adjust the CONTRAST setting of your LCD TV. Too high of a CONTRAST level will prematurely age your lightsource because it will have to work harder to maintain such light intensities. Your best bet is to keep your CONTRAST set appropriately for the conditions under which your view your LCD display. Brighter ambient light levels require slightly higher CONTRAST levels, while lower ambient light levels demand less CONTRAST <br /> If there is sound but no picture, only sound it has more chances of faulty back light repairable from Service Support. <br /> Hope this helps, if so do rate the solution. <br />
on Jun 21, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Dell Ultrasharp 2407 monitor - Vertical lines
most likely capacitor problem as these caps only have a 25000-40000 hour life span. when you do replaace the monitor , turn it off when not at the computer. even though it goes into sleep mode there is still a current running through the unit cuz if you move the mouse or hit button on keyboard display wakes up. I know this because I have done boad level repair on panels
Feb 04, 2013 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
E176FPb REPLACED C703 AND C704 STILL FAILS DISPLAY AFTER 3 SECONDS POWER LIGHT REMAINS ON
You need to find out if you do have 12vdc and 5vdc for the inverter circuits and logic board, I usually repalce the caps in a set not just the bulging one since bad cap can look normal but has high ESR, you need to use low ESR type cap in switching power supply, generic Radio Shack will not work or last very long. I use Panasonic FM/FC series for all my repair works because it has low ESR, 105c and high ripple current and high rated life.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Please post back what you find.
Nov 10, 2010 | Dell E176FP 17" LCD Monitor
My screen is totally black and will not turn on the computer but the green light is on???
Most likely a screen problem. Are you able to try another monitor with your PC? If a different monitor works, then the problem is your monitor. Most LCD monitors have a rather short life span (well, much shorter than the heavy old CRT monitors). But whichever kind of monitor you have, it seems to be getting power but is unable to display an image.
If your monitor is an LCD monitor, then the problem could be the backlight. If you take it to a computer repair shop, they should be able to replace the backlight - if it's cost effective to do so. Without knowing more about your monitor it's difficult to judge what the best solution might be. Sometimes it's cheaper and easier to get a second hand screen from Ebay rather than fix an obsolete LCD screen. On the other hand, if you bought the monitor within the last 12 months and spent a lot of money on it, it may well be worth getting it fixed.
Oct 10, 2010 | Computers & Internet
A friend gave me the Kogi 17 eh-ta ko 17 in Flat panel LCD monitor. We got it installed and the screen has a pinkish tinge to it. Don't have the manual and would like to find out where the tint control is....
communikay, The pink tint means that the cold-cathode-fluorescent-lamps are just about at their "end of life" and will need replacing!! I would be surprised if it lasts another month or two and then you might need to rebuild the inverter circuit that also might die from being overstressed due to the fact that old (many "ON" hours) CCFL's draw excessive current making the switch-mode-power-supply/inverter circuit work harder to light the lamps? 12fixlouie
Apr 03, 2010 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Gateway FPD 1730 Monitor
What has happened is part of your back lighting circuitry has gone out. Yes it is repairable but can cost most of what a replacement monitor will cost these days. Check that out before spending the money. If the problem is only in the back lighting circuit then expect to spend about $100 for a replacement board.
LCD monitors lifespan depends on the quality. Normal use and you should get 2-3 years of reliable service minimum. The display itself is good for about 4000 or so hours of use or more. The problems that show up are always (well 99.99% of the time) are back lighting problems like you have experienced. You should turn it off by the switch when not using it as every hour it runs the screen save is an hour of usable life. Heat is not good for it so if your computer gets the dust cleaned out to keep it cool do the monitor at the same time. Once a year at least more if you smoke use gas heat and have pets.
Tube monitors have a much longer life but you have the size weight and poorer display to go with them. If you have to go back to a tube monitor don't go back to your 14 ask around and you should be able to get a 17 or 19 crt for free. Or expect to pay no more than $10-20 for one.
Jul 10, 2009 | Gateway FPD1775W Monitor
After power outages my monitor will not come back on right away. It only blinks in the background.
GET YOURSELF UR UPS,IT WILL AVOID YOUR PC FROM CRASHING,AND YOU WILL NEED A NEW MONITOR WITHIN 6 MONTHS,ITS REACHING THE END OF ITS LIFE SPAN
Jul 04, 2009 | MegaVision Hyvision MV177 17" LCD Monitor
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
Hansol H750 17" LCD Monitor Logo
96 people viewed this question
Top Hansol Computers & Internet Experts
ray gallant
Andre van Wyk
Andre van Wyk
Level 1 Expert
Zakari Elothmani
Zakari Elothmani
Are you a Hansol Computer and Internet Expert? Answer questions, earn points and help others
