I have a Toshiba Equium a100 that wouldn't recognise any usb2 devices. So i deleted all the usb controllers and hubs etc, downloaded the uptodate chipset drivers from Intel and expected the computer to recognise that it needed drivers for USB but I just have the dreaded yellow markers in device manager. Any simple ideas to get the USB working again?
  • Anonymous Apr 15, 2009
    i have same problem
  • Viv Vek
    Viv Vek May 11, 2010
    You have the XP SP2?
  • 156 Answers
Posted on Apr 22, 2008
I an not have driver usb for hdd2193 for fix problem
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you dont have a motherboard disk you will need to download the drivers
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html
Intel PCI to USB Enhanced Host Controller NEC PCI to USB Enhanced Host Controller B0 NEC PCI to USB Enhanced Host Controller B1 USB 2.0 Root Hub Generic USB Hub VIA PCI to USB Enhanced Host Controller
http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html
http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
hope this helps you
Sep 11, 2011 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
Toshiba equium a100-147 service manual
This is the path:
http://eu.computers.toshiba-europe.com -> Support & Download -> Toshiba User Manual
Feb 07, 2011 | Computers & Internet
Does a Toshiba Equium A200 have a built in microphone?
Here are two different spec sheets for the A200-1V0 & A200-196. Neither one lists a "built-in mic" but both support external mics via 3/8 jack. Also there's always the possibility of using a USB mic.
A200-1V0
A200-196
Hope this helps, if so please comment, vote, etc.
Thank you.
Jun 03, 2010 | Toshiba Satellite A100-S8111TD Notebook
Equium 100 PC Desktop: my sscreen has rotated on my Toshiba EQUIUM A100-0...
hold ctrl+alt and press the up or down key to change the screen to its original position
May 05, 2010 | Toshiba Equium 100 PC Desktop
Toshiba Equium 2000 does not recognise USB keyboard
check bios settings and enable kboard usb settings is ok, save to cmos and reboot
Feb 18, 2010 | Toshiba Equium 2000 (PV1065E0-011FR) PC...
USB Port Speeds
Usually it's best to consult manufacturer's info on your computer. If not available, you can check it by going to start menu>settings>control panel>system>device manager and then look for "universal serial bus controllers" - several devices should be visible here and if you have USB2 it will be clearly stated (e.g. something along the lines of "USB2 Enhanced Host Controller").
Generally I would say if your computer is less than 4-5 years old, it will probably have USB2.
Hope this helps,
Raf
Nov 13, 2009 | Belkin (F5U237) 7-Port USB Hub
Drive not recognised
Sounds like a possible problem with the usb ports. Does the usb drive work on other pc's? If so, does your laptop recognize other usb devices (flash drives, mouse, keyboard etc.)?
If your laptop won't recognize other usb devices all the time, try this: go into device manager, go to the bottom, expand 'universal serial bus controllers'. Starting at the bottom of the list, right click on each item and left-click 'delete'. At some point you will likely lose your mouse/tochpad as it is probably an internal usb device. If this happens, press the power button on the laptop once to shut it down. Restart it, and windows will re-detect the deleted usb hubs and hopefully fix the problem. If this doesn't do it, go back and delete the other usb root hubs and host controllers. This is totally safe for your system and often fixes this issue. Windows will always re-detect hardware at boot time.
let me know if this helps or not :)
Aug 18, 2009 | LG GSA-H10A Burner
USB DRIVERS FOY DELL INSPIRON 1501
To reinstall USB drivers, you need to reinstall the system, as USB root hub drivers are built in on Windows.
Tray first removing laptop battery and unplugging AC charger for ten or fifteen minutes, this will get rid of static charges that can cause USB not to work.
If that does not solve the problem then you need to reinstall Windows. Try a system restore first.
Jan 02, 2009 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
